Re: Cherry Pi III Is Available February 02, 2015 06:00AM |
Now it's running smoother and quieter.
Re: Cherry Pi III Is Available February 02, 2015 06:39AM |
Pointy
Thanks Andy.
I have never got on with Pronterface to be honest, I remember having issues with it and my Ormerod. Once I switched to Daves firmware and the web interface, I never looked back.
I will maybe give Cura/Repetier Host a try and at some point down the road I may look at doing a custom web interface for the Smoothieboard.
As for the CP, it's at least printing, just needs some more tweaking.
(I did find another stupid error that I had made, and I probably shouldn't admit this, but I had assembled the mini v wheels incorrectly, I hadn't put the washer between the two bearings so they were binding when tightened.Now it's running smoother and quieter.
Regards,
Les
Re: Cherry Pi III Is Available February 02, 2015 07:26AM |
Re: Cherry Pi III Is Available February 02, 2015 07:32AM |
Re: Cherry Pi III Is Available February 02, 2015 09:29AM |
AndyCart
I did a very similar same thing when I first started using them. I bought just the delrin wheel from OpenBuilds as I had the bearings in stock. I tried to use a normal washer. It didn't work! I ended up buying the correct shim and spacer and all was well but it ended up costing me more than buying the kit in the first place due to shipping and customs costs. We live and learn! Glad you sorted it out.
I've just uploaded Rich Cattell's new 'testing' version of Marlin into one of my Cherry Pi builds. I took advantage of the fact that I now use an all metal hotend and a Mk3 aluminium build plate. I made a lead from a couple of croc clips. Clipped one to the hot end and one to the bed and the other ends went to the Z Min connector on my RAMPS. When the nozzle touches the bed the 'switch' closes. I successfully ran Rich's G30 A auto calibration routine and it was spot on.
I'm a great believer in the fact that once a delta is properly calibrated it shouldn't need auto bed leveling routines. Just the odd tweak to the Z height using M666 H should be all that's required.
It's saved me an hour or so of manual calibration too!
Andy
Re: Cherry Pi III Is Available February 02, 2015 10:29AM |
Re: Cherry Pi III Is Available February 02, 2015 01:50PM |
mrorange26
Hi Andy what all metal hotend do you use and do you have a modified holder for it .
Re: Cherry Pi III Is Available February 02, 2015 01:52PM |
Re: Cherry Pi III Is Available February 02, 2015 01:56PM |
mrorange26
Re: Cherry Pi III Is Available February 02, 2015 01:58PM |
Re: Cherry Pi III Is Available February 02, 2015 01:59PM |
Re: Cherry Pi III Is Available February 02, 2015 02:00PM |
Re: Cherry Pi III Is Available February 02, 2015 02:02PM |
Re: Cherry Pi III Is Available February 02, 2015 02:07PM |
mrorange26
Also can you post a picture of it completely setup thanks.
Re: Cherry Pi III Is Available February 02, 2015 02:09PM |
Re: Cherry Pi III Is Available February 02, 2015 02:15PM |
Re: Cherry Pi III Is Available February 02, 2015 02:24PM |
Re: Cherry Pi III Is Available February 02, 2015 03:05PM |
Re: Cherry Pi III Is Available February 02, 2015 03:08PM |
Re: Cherry Pi III Is Available February 02, 2015 03:19PM |
Re: Cherry Pi III Is Available February 02, 2015 04:43PM |
Re: Cherry Pi III Is Available February 03, 2015 10:14AM |
Re: Cherry Pi III Is Available February 03, 2015 05:25PM |
Pointy
What's the diameter of that heated bed Andy?
Regards,
Les
Re: Cherry Pi III Is Available February 03, 2015 06:22PM |
Re: Cherry Pi III Is Available February 04, 2015 05:50AM |
Re: Cherry Pi III Is Available February 04, 2015 06:19AM |
Re: Cherry Pi III Is Available February 04, 2015 06:38AM |
Matt,Wheatley
ABS Help
Has anybody managed to print ABS with their cherry pi. I want to print the new all metal hot end mount and appear to be having issues with layers being a little bitty. I was wondering if people had used ABS and if so what there print settings might be.
I have tried temp at 240, bed 110 with the fan off but the layers don't appear very even.
Thanks
Matt
Re: Cherry Pi III Is Available February 04, 2015 07:15AM |
mrorange26
Do you need a fan for the alu fins and also a separate one to blow onto the plastic as it comes out.
Re: Cherry Pi III Is Available February 04, 2015 09:28AM |
Re: Cherry Pi III Is Available February 04, 2015 09:51AM |
