Re: Cherry Pi III Is Available February 09, 2015 12:25PM |
Re: Cherry Pi III Is Available February 09, 2015 11:32PM |
Re: Cherry Pi III Is Available February 09, 2015 11:35PM |
Re: Cherry Pi III Is Available February 10, 2015 03:48AM |
maso
For what it's worth, I've made a design that does exactly that.
Re: Cherry Pi III Is Available February 10, 2015 11:36AM |
Pointy
- What effect does raising the ball sockets from the carrier have if any? (I had to raise them up 5mm, so the spring wire hole clears the belt guide)
- What is the optimum angle for the sockets? (mine are currently at 45 degrees, the same as the effector)
Re: Cherry Pi III Is Available February 10, 2015 03:28PM |
Re: Cherry Pi III Is Available February 11, 2015 11:16AM |
Pointy
maso
Thanks maso.
I started tweaking my design to have the rod holders at the top and it made me curious about a couple of things.
Regards,
Les
Re: Cherry Pi III Is Available February 11, 2015 01:47PM |
Re: Cherry Pi III Is Available February 11, 2015 02:19PM |
Re: Cherry Pi III Is Available February 11, 2015 02:56PM |
Re: Cherry Pi III Is Available February 11, 2015 03:08PM |
Re: Cherry Pi III Is Available February 11, 2015 07:51PM |
mrorange26
Received my new E3D clone today,All together just got to install it in my printer and calibrate.
Re: Cherry Pi III Is Available February 12, 2015 02:19AM |
Re: Cherry Pi III Is Available February 12, 2015 07:00AM |
AndyCart
The 30 x 30 x 10 cooling fan fits to the topside of the effector between two of the metal spacers. It's held n place with a dab of Cherry Pi 'secret sauce'
Re: Cherry Pi III Is Available February 12, 2015 12:37PM |
vreihen
Speaking of the CP not-so-secret sauce, has anyone tried to attach un-tapped steel bearings directly to the rods (CF or aluminum) on the non-magnetic spring setup using CA? Just curious how it would work, since I have a hundred 5/16" (7.93mm) balls left over from my attempt at Johann's recirculating ball carriages. I was thinking that an automotive brake line flaring tool might be able to create a decent contact area for the ball to be glued.....
Re: Cherry Pi III Is Available February 12, 2015 12:44PM |
AndyCart
vreihen
It maybe that all that is required is a tube with a larger, maybe 6mm, ID. As everything is held in tension by the spring the end of the tube may be a suitable 'housing' for the ball
Re: Cherry Pi III Is Available February 13, 2015 03:48AM |
Re: Cherry Pi III Is Available February 13, 2015 01:13PM |
Re: Cherry Pi III Is Available February 13, 2015 01:41PM |
Re: Cherry Pi III Is Available February 13, 2015 02:27PM |
mrorange26
Just received my 12v mk3 heated bed.I was going to use a xbox 360 power supply to power it,Do I just connect the xbox supply on the second lot of power input connections and leave my existing 6a power supply still connected.
Re: Cherry Pi III Is Available February 13, 2015 03:19PM |
Re: Cherry Pi III Is Available February 13, 2015 03:43PM |
AndyCart
You will also need a thermistor for the bed and a tweak to the firmware to enable it
Re: Cherry Pi III Is Available February 13, 2015 03:45PM |
Re: Cherry Pi III Is Available February 13, 2015 04:52PM |
Re: Cherry Pi III Is Available February 13, 2015 07:20PM |
Re: Cherry Pi III Is Available February 13, 2015 07:23PM |
Re: Cherry Pi III Is Available February 13, 2015 07:29PM |
Re: Cherry Pi III Is Available February 13, 2015 07:39PM |
Re: Cherry Pi III Is Available February 14, 2015 12:24PM |
Re: Cherry Pi III Is Available February 14, 2015 09:19PM |
Pointy
The new carriages work, and I have gained 30mm with the flipped design. I also seem to be able to print via USB now, thanks to a new cable. (should always try the obvious things first)
The carriage is designed for Bosch Rexroth/Motedis aluminium extrusion, but could be tweaked for other makes. I am using the following fittings with mine....
M3 x25mm Socket Head Cap Screw & M3 Nut (Wheel tension adjustment)
M3 x 20mm Hex Head Screw & M3 Nut (Belt adjustment, If you don't have a M3 hex bolt, a normal SHCS will probably work if you glue it in place.)
4 x No 4 x 1/2" Pozi Flanged Self Tappering Screws (Fixings for rod carrier/carriage)
3 x M5 30mm Socket Low Head Cap Screw (to replace the M5 screws supplied with the mini v wheel kit)
2 x M2 x 6mm Socket Head Cap Screw (to hold the belt loops in place)
Regards,
Les
