Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 11:01AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 11:09AM |
Sir_Death
Legrand
Sorry. Should have been more detailed.
I'm using the FT marlin firmware.
I do not know FT Marlin, but I assume this function similar in all Marlin Versions.
search for line like this in configuration.h:
#define DELTA_PRINTABLE_RADIUS 100
The value at the end of the line is what you have to change...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 05:44PM |
Legrand
I had this same problem. Try uncommenting this line in your configuration.h settings: #define DISABLE_MIN_ENDSTOPS
Gingerbreadman
Having problems when I run g29.
The head moves as though it is scanning the bed, in the x and y but steps up incrementally on the z until it hits the endstops at home. At that point I have to kill switch it or it will jam against the end stops.
I'm using repetier host v1.6.0, folgertech kossel rev b with the inductive probe, and the folgertech configuration rev.b file. I've set bed height and the z probe register correctly (lights up and shows in the log) . The g28 code works well, and the printer responded correctly when I ran a test calibration spiral print, though that was a sad print to say the least.
I'm sure I have wired or miscoded something since I am thrashing in the dark here and would like to preemptively apologize if the solution to this problem was offered earlier in this thread . My sad excuse for a 3d vocabulary hinders my search and comprehension of what little I have found and "understood"...thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 07:24AM |
Gingerbreadman
Thanks for the quick feedback. I opened up my configuration.h file to follow your directions only to find the line already uncommented it reads as,
//#define DISABLE_MIN_ENDSTOPS
The line above it reads exactly the same except it refers to the max endstops, if that matters.
Legrand
Gingerbreadman
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 09:54AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 10:24AM |
Sven.L
I really like the idea of replacing the probe in this case. Is Folger Tech selling a better probe type now? Or what probes could you and the others here recommend? Please post URLS, too. Thanks.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 10:42AM |
Sven.L
Paul, thanks.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 11:24AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 11:56AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 01:01PM |
paul_delta
Here is another "hot end as probe" solution if you want to have a fun [www.thingiverse.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 01:07PM |
spiffcow
That effector doesn't look like it holds in the hot end by anything other than gravity.. do you know if this is the case? If so I might switch to it. That would make my probing process a lot easier
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 01:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 01:20PM |
paul_delta
This is just one of variants. Usually the central part has a spring between the sensor and surface to hold it in place.
I was going to redesign this probe for my needs but after success with my zero offset probe mount I decided to stop my research.
spiffcow
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 01:27PM |
spiffcow
I really need to start putting some effort into OpenSCAD. What I *really* want is a clip-into-place hot end so that I can switch it out with the Z probe whenever I need to re-calibrate.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 01:29PM |
Legrand
MAX should be commented out.
Gingerbreadman
Legrand
Gingerbreadman
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 08:17PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 09:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 09:09PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2016 09:17PM |
nebbian
Hi Tim,
Don't sweat it if you're off by 0.1mm or so. This can often be caused by plastic slumping, pressing the calipers too hard, extrusion miscalibration, and a host of other factors.
A good way to tell if you're well calibrated is to print something a lot bigger, like for instance a 100mm square with 1mm sides. Another way is to print something with multiple squares on it, and you measure the difference in position between the north faces of each square. Only then can you tell if your dimensions are well set up, without getting side tracked by other factors such as over extrusion.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2016 12:43AM |
Captain_Tim
Printed my first print last night, a 20mm calibration cube. Turned out better than I expected, but my printer needs a lot of work soon. Using my calipers, I know the sides aren't 20mm, I know the Z is off by about 0.2mm, and I can't remember which axis is which but the X and Y are off by 0.18mm and 0.07mm. The layers also seem to be having issue, maybe it's speed, heat, or extruder that need to change. I'd love your guys help to finalize the calibration. I've attached photos of the cube from above, below, and sides. As the bottom of the cube did come off, so it's hard to actually tell how much the z axis is off by, but my rough estimate is the 0.2mm value. I'll reprint and after I modify the print settings to hopefully get better layer adhesion.
My phone can not take photos with a small enough size, so please accept my imgur links instead
Corner
Bottom (Sorry for not having a direct shot)
Side
Top
I would love some suggestions of things to change. If you guys need more information to help, just ask.
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2016 03:21AM |
Captain_Tim
Corner
Side
Top
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2016 10:14AM |
spiffcow
That print looks a bit rough. Have you calibrated your extruder and/or your stepper drivers? If not I would suggest doing it now to save yourself a lot of frustration later.
Sir_Death
as already suggested start with calibrating Extruder.
It could be you are printing to cold, and / or to fast, or you might have a nozzle that is partly clogged... just to give you some hints, where to start researching.
Don't try to calibrate your size with this print - it is useless. As soon as you have solved the layer-issue, all size-parameters might Change....
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2016 04:28PM |
Captain_Tim
I have yet to calibrate my extruder. This would be a very wise decision to do so. I completely forgot to do this. I'm still happy that it even printed the cube, as I was expecting it to fail pretty hard first try.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2016 04:54PM |
spiffcow
Captain_Tim
No shame in being excited to see something print I'm serious about the steppers though. If you don't tune them, they *will* overheat and skip steps. Make sure all belts and pulleys are tight. Make sure the gear on the extruder is in full contact with the filament (it wasn't by default on mine). Make sure your endstops are as close to even as you can get them. Make sure the width of the carriages is the same as the width of the effector (this was a big problem for me, and I assume anyone who recently ordered from Folgertech). Then, when all of that is complete, start calibrating your software. I reccomend printing a new effector and placing your probe in the hot end slot, and just calibrate until the error is as low as you can possibly get. Then start printing calibration objects and make sure you perfect your retraction settings (and if you figure out some good ones, let me know...).
And then.. Well, then you can start printing parts for your own custom build with all the things you wish your Folgertech Kossel had
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2016 08:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2016 08:53PM |
Captain_Tim
My extruder doesn't catch the filament very well, so that may be where my problem lies. Is there a way to tighten the extruder so more pressure is put on the bearing to push the filament against the gear so it will go in?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2016 09:07PM |
spiffcow
On mine I had to disassemble the extruder, loosen the set screws, and move the gear further out. It's still a crappy choice of gears though, and tends to deform the filament
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2016 09:23PM |
Captain_Tim
spiffcow
I'll try that. Is there a different gear that I can buy that you guys recommend to replace the current gear?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 02:50AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 06:14AM |
EvilBetty
This is one of my prints when I set the extrusion width too low...
