Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2016 11:32AM |
Captain_Tim
So I swapped my Arduino Mega out, and the LCD displayed squares. I thought it was a contrast issue, tried turning the contrast pot on the back of the LCD, blew the voltage regulator on the arduino... back to the old one for now. I'll just leave my raspberry pi plugged into it for now I suppose.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2016 01:50PM |
Legrand
Yeah. As I figured. This is the guy I got the voltage regulaors from. 20 of them came in a padded envelope for $3.50 and I had them in a couple of days.
AMS1117 on e-bay
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 07, 2016 11:00AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 09, 2016 06:02AM |
Captain_Tim
I think that at some point between last night and this morning, my Arduino got shorted. Worked fine last night, nothing this morning. No red flashing lights or anything. All I did was move it, and put on some feet dampeners. While I was putting the new feet on, the filament roll feel off from the top, but that shouldn't have done anything to the electronics while it was off, could it?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 09, 2016 02:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 09, 2016 03:05PM |
Legrand
I highly doubt that the filament falling off would cause a problem. Check the wires to make sure that all the screws are tight, both on your board and on the power supply. It's been my experience that they loosen up over time. Check your power supply and see if it's still working (should be a green light on it as well.) Make sure it's still plugged in
Captain_Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 11, 2016 12:13AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 11, 2016 08:29AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 11, 2016 12:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 11, 2016 05:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 09:53AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 10:11AM |
fredw
Repetier Host error message:
Error: Temperature heated bed switched off. MAXTEMP triggered!!
reporting also: Extruder 130.3 deg C/Off Bed: 137.1 deg C/Off
I pulled the thermistor connectors from the pin strip on the board. I
can measure the 100K Ohm thermistors from the connector end. I
used a free pin strip I had on my bench to connect and measure. I
did this to make sure the contacts were good. They seem fine
mechanically too.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 10:56AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 11:08AM |
fredw
They both show change when heated. I used a temperature controlled heat gun and quickly got each of them to 80K Ohms. I watched the resistance climb as they cooled down.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 06:47PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 09:40PM |
Captain_Tim
You most likely didn't do anything that'd require extra work. For my resistors, I didn't have big enough heat shrink at the time, so it got a good dose of hot glue instead.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 09:49PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 10:26PM |
Captain_Tim
You should be plugging the probe into the +12V and the -12V on the PSU, not the ground from the power cord. Not sure if that makes a difference though. That's how I have it. The probe is hooked up in the correct spot. Try moving that GND connection to the -12V on the PSU and see if that solves your issue.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 10:30PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 10:42PM |
UncleSas
I'm using Paul_Delta's firmware, but recall that he is using a mechanical Z probe, rather than the inductive one that ships with the Rev B. I also recall that there was some discussion about there being some pre-calibration changes to his Configuration.h in this thread related to using Paul_Delta's firmware on a stock Rev B, but my search-fu seems to be weak. If that was discussed here, I'll go RTFT more carefully to see if I can find it...
Otherwise, the thermistors are reporting properly now.
Thanks for your advice, Captain.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 11:06PM |
Captain_Tim
No problem. The Z-probe still reports high if it is touching the aluminum? It's always High? If it's always High, then something must be wrong with the wiring.
paul_delta
I use regular blue-tip inductive probe that comes with Rev.B kit. Check your wiring and resistors or try to connect it directly to RAMPS as discussed in this thread.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 11:10PM |
UncleSas
Captain_Tim
It's always high when I do M119. LED comes on at Z000.89, goes off at Z000.90, but M119 returns don't change.
paul_delta
Hmmm. 106 pages of thread read before building. I sit corrected. Time to look for the instructions for connecting directly to the RAMPS board.
Did you go to a magnetically attached mechanical Z probe on an earlier version of this printer, or was that someone else?
Thanks.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 12, 2016 11:17PM |
UncleSas
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 13, 2016 12:38AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 13, 2016 09:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 13, 2016 12:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 15, 2016 06:19PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 16, 2016 10:51AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 16, 2016 12:09PM |
UncleSas
Looks like my hotend thermistor is bad... And I probably broke it when I assembled the carriage...
I was talking to a local acquaintance (with a lot of experience) about setup and such and he said that I should probably keep hot end heater cartridge and thermistor spares on hand, because they get broken during regular maintenance and often during an initial build. (Imagine that...)
So, right off the bat, I'm thinking of switching to this:
[www.amazon.com]
Has anyone used one of those? If so, do you recommend the product?
Thanks,
-S
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 16, 2016 03:35PM |
Legrand
I have not used it but it does not appear to be a drop in replacement for the existing thermistor. You'll have to drill & tap the opening larger for the screw in mount, that is assuming there is enough room to do that.
You can also get the same thing from Banggood for a couple bucks (assuming you can wait a couple of weeks for them to come from China).
Banggood
