Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 17, 2016 02:10AM |
thosmos
iknownothing
Same issue here. Have been struggling for a two weeks trying to figure out what's been happening. I've been doing the same thing, taking apart the extruder to get to the jam. I even tried letting the heater block hang without the heat sink at 240°, but I still couldn't get it cleared. I ended up having to take apart the nozzle, heater block and M6 collar and using a torch on the nozzle and collar to clear the filament. I also assembled those parts when the heater block is at 240° to reduce the possibility that those pieces would loosen due to heat expansion of the heater block ( this already happened to me during a first print ). I've just been trying PLA with a temp of 190°. Extruder is jammed as I type this and dread having to take it all apart again. I think the issue is heat creep, but don't know how to resolve it. I printed this: [www.thingiverse.com] (at 110% scale my newly acquired Monoprice Mini), to see if would help, but I still got a jam! I may try ABS to see if that makes a difference ( like meq123 ). Odd that since ABS requires higher temps and thosmos has been successful with 240° temps ....
After another catastrophic crash of the printhead into the print bed while trying out a different firmware, it started jamming just about every time. I ordered some replacement print heads (https://www.amazon.com/gp/product/B017OMRP5Y) and now it's workin great on the first print!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 19, 2016 11:38AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 20, 2016 08:28PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 21, 2016 07:51PM |
[email protected]
I have yet to print with mine. I got a E3dv6 clone so it does not fit with the sensor. So I played with tinker cad made a holder that would bolt onto the 30mm fan since the E3 has the clip on cooling fan, well now my sensor hits my arms. I have a Wanhoa I3 (clone) to print parts with. I am beginning to think about just removing the inductive sensor so I can use the printer.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 27, 2016 05:22PM |
spiffcow
meq123
I noticed a very novel idea in the way the Micromake effector is designed, where the effector plate is made as a kind of "A" shape with the top of the hot end raised much higher than the pivot points of the arms. That would seem to me that it would reduce the effects (amplitude) of tilt and backlash considerably on the movement of the nozzle tip.
I would think we/one/you could design and print a replacement effector for the FolgerTech unit to mount the hot end the same way - with the added advantage of greater Z-height.
It's not novel.. Similar designs have been around for years. The biggest downside is that it's a PITA to size it for your hotend. It might also be a bit difficult to get a perfect angle on it, since you'll have to make sure the hot end mount is parallel to the bottom of the effector.
If you are just looking for better quality, there's a ton of mods that will be more beneficial to you.. But I'd imagine it'd help out a bit.
docpayce
@meq123: Yeah, that design was around for quite some time. There wouldn't be any benefit when it comes to backlash, BUT it would resolve tilt-related issues very, very nicely. Also +50 mm or so build height. I was thinking about designing something like that (for E3D V6), but can't find the time right now. Another problem would be proper cooling of the print. The fan(s) would have to be mounted on top of the effector, with air channels going directly through the plate. btw: The upper part being not perfectly parallel to the lower part of the effector wouldn't result in problems: As long as thats a fixed angle, everything should still be very fine.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 27, 2016 05:41PM |
meq123
spiffcow
meq123
docpayce
So having come up to speed on OpenSCAD and playing with docpayce's magnetic effector design (how ironic ). I figured "why not convert it to a "raised hotend" design (if there isn't a better name?).
The screenshots below shows what I have now, based around a V6 hotend STL model I got off thingverse. This is designed to use cut-off carbon rods as the support pillars, either glued and/or screwed in place (former is easier, latter means you can pull it apart). The only fear I have is the proximity of the lower ring to some corners of the heat block. Other than that it seems very workable. If you want a filament cooler you could design a mount to attach to the support pillars, or even zip-ties.
Thoughts? Comments? Ideas?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2016 02:09PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2016 03:59PM |
docpayce
@meq123: Nice! I like it! Imho, you should thicken the walls holding the carbon rods. Using carbon rods is a really nice idea btw. Though, you could also print the upper part completely "with the carbon rods" if you know what I mean. i.e. not use carbon rods but plastic. Comparable to this design: [www.thingiverse.com]
I am really intrigued by the two-part design. Good idea! Makes adjustements much easier (e.g. other versions of the upper part - with additional fans or such). For that upper part: Get rid of the hotend fan and put that on the upper part! Know, what I mean? Another fan on the other edge + channels = print cooling. Like I said, really intrigued!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2016 04:27PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2016 01:52PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 23, 2016 07:52PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 23, 2016 11:09PM |
av8r1
@sharkicicles, no, the plastic didn't jam your threads. It's called an interference fit. As the nozzle got hot and cold, the threads tighten. If you have to disassemble a hot end, heat it to printing temperature before applying torque. Once the threads are broken loose, then cool the hot end and unscrew. Grip the hot block, not the cold end or heat sink.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 24, 2016 06:44PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 24, 2016 10:42PM |
av8r1
It may be that different industries use terms slightly differently. My aviation background associates threads which are heated, assembled and allowed to cool to lock them into place with the phrase "interference fit." Whatever we choose to call it, the physics are there.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 25, 2016 01:58AM |
UncleSas
av8r1
That use of "interference fit" is an interesting term of art which I speculate is specific to aviation.
I've done something like that with hoops and bands using a variety of materials; but never anything threaded. I've also gone the other way, with cold fit parts, where the inserted part is chilled first; usually seals and flexible rubber parts.
Boy, howdy... You're not getting those parts apart unless they're hot, as you said. For something as fragile as a brass hot end, breakage seems like it would be pretty much guaranteed.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 26, 2016 09:38AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 26, 2016 09:57AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 26, 2016 10:06AM |
docpayce
Hey guys! It's been a bit silent from my side, but I wanted to give an update on things. Primarily to avoid any redundant work:
1) In addition to a height probe with zero x/y offset (The V3 without pin of this thing: [www.thingiverse.com]) I used the easy interchangability of the magnetic effector to realize a zero x/y/z probe. I.e. the probing position is dead-on the same as the nozzle position - just on another (probe) effector, which is switched out for the actual (hot end) effector. Results were ... meh. Not to much of a difference - I would even say that a zero x/y probe is still better suited than using another probing effector - I do think changing the effector (and thus slightly changing rod pair separations) will induce more measurement errors than a 30 mm z offset will.
2) I pretty much nailed down the fabrication process of carbon rods with steel balls by investing a bunch of bucks into measurement & fabrication equipment. I consistently get to within +/- 0.10 mm of a target seperation value (i.e. I aim for 290 mm -> actual length will be 290 +/- 0.10 mm). But still better: The max deviation from one rod to any other rod of the same set is consistently +/- 0.02 mm. +/- 20 µm! Thats a length variation of half the width of a human hair within 6 carbon rods! (If you didn't guess already: I am really proud of that... ;D)
I am thinking about selling these, pls let me know whether you guys would be interested.
3) Just two words as preview: IKEA enclosure. Hopefully September. Similar to this: [makerhacks.com]
4) Still thinking about meq123's design to raise the hotend. I do think this would lessen some problems.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 26, 2016 03:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 26, 2016 07:08PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 28, 2016 10:28PM |
spiffcow
UncleSas
av8r1
So buy steel nozzles? They're cheap. I got like 5 of them for $2. I've broken a brass nozzle once, but only when I mixed up the direction I was turning, and even then I could tell something was seriously wrong. If you pay attention to what you're doing it's really not an issue.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 28, 2016 10:31PM |
docpayce
@UncleSas: (Late, but hey, whatever ) Yes, exactly. It was just about the (China) GT2 belt quality. There are a lot of MUCH better quality belts out there, both GT2's and others. The 3MR version I mentioned is just one possible solution, which is well known for its stiffness.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 28, 2016 10:46PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 29, 2016 10:56AM |
UncleSas
Do you have any hints for sourcing better quality GT2?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 29, 2016 12:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 29, 2016 03:18PM |
docpayce
@av8r1: What parts do you need specifically? I only ask, because I personally got rid of 90% of the plexiglas parts. They break SO easiliy and there is a better solution for nearly any Folgertech plexiglas part.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 30, 2016 02:47AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 30, 2016 06:59AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2016 05:21AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2016 06:09AM |
