Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 10:35AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 10:40AM |
Koenig
thevisad
For extrusion, you want to buy directly from Misumi. They will custom cut any size for you and give you price breaks on the overall length you buy. 2 pieces will be cheaper then 1, etc. Search the site for part number HFS5-2020-SIZEYOUWANTINMM (ie HFS5-2020-350 is 350 mm). That is series 5 20-20 which is what we use.
Seems I as a private person cannot shop from Misumi-Europe... "Please enter only the company address, private addresses are not accepted."
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 10:41AM |
fattmann
What is the fifth stepper driver specifically for?
Got the kit assembled, and was setting the voltages on the stepper drivers to the initial 0.35v (0.55 for the extruder motor) stated in the build manual, and discovered there isn't a recommended voltage setting for the fifth one. It would make sense that you would only have one per motor, but thought it was odd that they specifically instruct to install the fifth one at the beginning.
Does this fifth stepper driver serve a purpose, or is it just a spare? If it IS needed, what voltage should it be set at?
Side questions- is there a general diagnostic code/sequence list for the RAMPS board? Initially it would power on with two red LEDs, then shortly switch to green. At one point the green switched to red momentarily, then shut down. This was all without having it connected to the computer. I am unable to discern if there is an issue or not, as it will not stay powered on for more than about 10min before shutting down. I was going to get it connected to the computer tonight and get the FW all sorted out before I called it a bad board- gotta relocate the RAMPS/Arduino boards as the cable provided will not fit in the stock mounting location.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 10:48AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 10:50AM |
cislom
I am in the middle of replacing all the ball bearings with stainless steel ones (just ordered) to see if that helps on my rails. They seem to work fine if the are dripping with Super-Lube, but there are a few occasions when printing things with a lot of stop and starts that the rails will "studder" at a certain spot and the print will have a noticeable line where the layers are all moved over .5 to 1.5 mm in one direction. If this doesn't work I was going to look at using the plate and wheels as my final stab at the elusive "buttery smoothness"
So that being said, anybody try the plate and wheels yet? Any pros or cons? I am interested to hear any information - and Thanks Again - this forum is a wealth of information and if nothing else, a place to share the pain
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 10:59AM |
fattmann
Thanks! I was hoping so, as I think one of mine is shot...
The voltage will vary WILDLY. Like 1/32nd of a turn to the right will take you from .005v to 1.5, then another turn in the same direction will get you .6v. I assume the potentiometer is just bunk.
What is the general consensus on upgraded stepper drivers like the G3D versions? It won't be right away, but saw some positive discussions about those and the Stepstick build.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:01AM |
Koenig
thevisad
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:03AM |
thevisad
fattmann
All of the steppers are the same, regardless of whose you use, unless you buy real Polulu drivers. Geeetech would be the next best ones and they fiercely defend their brand. I have dozens of the drivers on the 4988 and 8825 and every one exhibits the issues you are describing. If you want the standard (most likely), then you would use these. for high voltage steppers in the 4988 family (just better ones) you would want to use these, and finally for the high performance steppers you want these 8825.
Note, there are only a few differences between the Polulu and the Chinese steppers. One is a better pot and different size resistors on the drivers and PCB color. There are a few fixes you can do (if you can solder) to your existing drivers, such as replacing the resistors.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:04AM |
thevisad
dc42
Koenig
thevisad
Would 350mm suffice to fit a 330mm bed?
I see it varies between the the different kits out there, Robotdigg (haver their corners) as an example uses 360mm but a 300mm bed, my thought is to fit a 330mm heated bed and a 300mm glass on top of that.
The printable area also depends on how close the effector can get to the towers. I use 355mm horizontals and a 330mm aluminium bed with a mains powered heater. Using a standard Mini Kossel effector, that gives me a little over 300mm printable diameter. I use 330mm glass so that the bed clips at the edges don't impact the printable area. See my blog entry at [miscsolutions.wordpress.com] for details.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:10AM |
dc42
thevisad
The Ice Blue stepper driver modules from T3P3 are also better than the cheap Chinese ones, especially at higher currents. They use A4982 chips and 4-layer PCBs for better cooling.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:21AM |
Koenig
thevisad
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:25AM |
fattmann
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:36AM |
thevisad
cislom
If the balls you are placing in there are not hardened you could make things worse as they get impacted by others. I think people have mentioned the wire bar is the cause of the stuttering on the rails.
I have not worked with the wheels myself; however, I have played with printers that have had them. They are awesome and incredibly smooth as long as you build it right and don't tighten them too much. A 3 wheeled design is all that's needed to get a stable platform. You can see them in this build on this printer, I talked to this guy at Makerfaire Detroit last weekend for a while. He had two different printers there, the tall one and the shorter air delta. One thing that can be noticed is when you tighten the delrin wheels too much, they get a "flat spot". This can be felt as a bump, bump, bump as the wheel hits this location. The effector on his printer is all aluminum milled out on a cnc machine, looks amazing.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 08:27PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 10:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:07PM |
Sven.L
I would need a URL where to download the latest version of the Build Manual (PDF).
And if anyone can supply an image (photo) of each kind of hardware that was included for this printer? That would make it easier to identify each of the bolts, nuts, washers and such. Thanks a lot!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:14PM |
fattmann
Well poop.
I seems my Arduino board has crapped out. I swapped one stepper driver with the super sensitive pot with the spare, and was dialing everything in when it went dark again.
I separated the two boards and connected the Arduino board to the computer with no luck on power- either USB or external. I found online a guide to test the voltage regulator, as my over current protection circuit was blazingly hot. I confirmed a short on pins 1 and 2 on the voltage regulator. As per that guide that means it's bad.
I sent Folger Tech a message through their "contact us" option, and mentioned the broken pin on the RAMPS board as well.
While I wait for response on whether I need to order a new board, is there any way to test the RAMPS board separately? I don't know if something with the RAMPS board took out the Arduino, or if vice versa.
I had also read on that guide that you can remove the voltage regulator from the Arduino board and still use the USB power. If I do that, will I be able to limp it along, as long as I have it connected to USB, until I get another board?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 11:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 01, 2015 12:55AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 01, 2015 12:17PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 01, 2015 01:07PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 01, 2015 02:23PM |
Koenig
cman8
What are people settings in Slic3r? I would like to comapare see if I can get my prints even better.
That all depends on what is to be printed, material used, if you aim for speed, looks, ridgidity
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 01, 2015 02:37PM |
Rattfink
Hello everyone -
i heard some talk about using the plates and bearings on the towers instead of the bearings. I have a CNC machine and i was wondering if any of you would know of a link that you could share?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 01, 2015 03:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 01, 2015 04:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 01, 2015 10:45PM |
dc42
The bearings are standard 623ZZ. My wheels came from here [www.think3dprint3d.com] but I have also seen them here [deltaprintr.com]. You need to make sure that the V-part of the wheel is wider than the slot in your extrusions, so that the V-part runs in the slots.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 02, 2015 09:23PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 02, 2015 09:31PM |
fattmann
Finally got the printer assembled, after having to order a new Arduino board.
Now I can't get the Arduino to talk to the computer. Before connecting the RAMPS shield, we ran Blink on just the Mega with success, powered only by USB. After we finished the final assembly and buttoned everything up- we started getting "The handle is invalid error" errors. I was running a Win 8 laptop, and had hell getting the driver uninstalled, and reinstalled without driver signing. Not sure why it just worked the first time, but never again.
So we moved it to my Win 7 desktop, now we get timeout errors.
On the Win 8 machine it would show up in Device Manager under COM3 or which ever USB port I had it in. On the Win 7 machine it shows up as both COM17 and COM1. Trying to flash or run Blink on COM1 fails, and COM17 gives timeout error.
This is the first Arduino device I've toyed with. Any suggestions? My troubleshooting toolbox just isn't there from lack of experience.
