Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 02:46AM |
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 02:49AM |
o_lampe
Don't take the nozzle diameter for granted.
I got 0.3 nozzles from china, which are 0.4 and vise versa...
-Olaf
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 03:24AM |
Sir_Death
Nozzle was free before printing - could see through. PTFE tube is down all the way through heatbreake - there was a Problem after building the printer, so I had to disassemble and
reassemble it, therefore I'm sure, how it is assembled now.
(Thats why I started dissasembling, because cold pull did not work anymore - so I found the broken screw...)
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 03:32AM |
Sir_Death
Sir_Death
Nozzle was jammed this morning after unattended night-print...
I think - or at least hope - I found the problem. - The screw which is pressing the heatblock onto the heatcartridge broke in the middle, so it was not correctly pressing the two parts together anymore...
Will have to drill it out this afternoon and reassemble.
Nozzle got jammed, because PTFE-Tube got widened at the end, and so PLA crystalized..(Thats why I started dissasembling, because cold pull did not work anymore - so I found the broken screw...)
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 03:44AM |
So now there is crysalized Filament with outer Diameter of the PTFE Tube at the End of the Heatbreak, and fresh filament has to pass through the crystalized one - which is only possible in melted condition... i think, this is one of the points why I had to use such great heat, but still not extruding very much. (second Point might be the broken screw)|
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 04:19AM |
nebbian
o_lampe
-Olaf
What's a good way to test this?
nebbian
Also while we're on the subject, I read somewhere that you should have an extrusion width that is slightly larger than the nozzle size. I've always just used an extrusion width equal to the nozzle size. Can you confirm/deny?
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 04:50AM |
I do not think that the problem is in not good heater contact. It can affect the time of heating and wasting energy to heat air. But if the head is able to reach desired temperature, which is measured by thermistor (which is still installed properly), it means the head has requested temperature.Quote
Sir_Death
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 05:00AM |
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 05:11AM |
Sir_Death
The PTFE Tube should reach down through the heatbreak until touching the back of the Nozzle (in the heatblock), so 1.75mm Filament is directed to the nozzle correctly.
We will see, when I've cleaned it up and reassembled, if it works as it should...
Would it be a good Idea to apply some thermal compound on the heatcartridge to ensure best thermal Transfer to the heatblock?
I'd say PTFT tube *is* kinda cold zone wherever it is, maybe not too cold ;-)|
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 05:21AM |
hacker
Sir_Death
I thought it ends halfway in the heatbreak? I need to check that once I'm home, because I happen to have original hotend lying around ready for disassemblingI'd say PTFT tube *is* kinda cold zone wherever it is, maybe not too cold ;-)
Perhaps I'd try some thermal compound on heatbreak threading to improve thermal transfer to heatsink. And would triple check how well heatsink is colled.
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 05:23AM |
hacker
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 05:26AM |
Sir_Death
hacker
Sir_Death
Consulting E3D Assembly Instruction at
http://wiki.e3d-online.com/wiki/E3D-v6_Assembly#1.75mm_Universal_.28with_Bowden.29´
it tells you:
"The tubing should be inserted from the top of the now assembled hotend and pushed as far down into the hotend as possible."
With the chinese hotend PTFE Tube is able to go down till the end of the heatbreak.
Anonymous User
GrAndAG
hacker
Just FYI.. Regular (usually for computer coolers) thermal compound is not designed for high temperature, such as in our case. It will degrade rapidly. But it worth to try, if it solves the problem (at least for short time) - you found the problem.
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 05:28AM |
GrAndAG
hacker
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 05:38AM |
Sir_Death
GrAndAG
hacker
That is exactly the Point which worries me...
So first I'll just reassemble it, as it should be, and check again...
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 05:49AM |
Koenig
Sir_Death
GrAndAG
hacker
Don't think you need to worry to much about it, where the fins are it shouldn't be such extreme temperatures.
It would be another matter if you tried putting thermal compound where the heatblock is (threads to nozzle, around heating cartridge).
E3D actually recommends putting thermal compound on the heatbreak where the fins are.
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 05:54AM |
hacker
Koenig
Sir_Death
GrAndAG
hacker
Oh yeah, sorry if I wasn't clear (and I almost wasn't), I meant heatbreak threading where it goes into heatsink, of course.
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 06:31AM |
But you also don't want the heat to creep up to the PTFE tube and start melting plastic higher up...Quote
Koenig
hacker
Koenig
Sir_Death
GrAndAG
hacker
That would not be very smart to do that as you really want as little heat transfer between those two parts as possible.
It would be much better if there was a thermal insulator compound to put there.
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 06:48AM |
Tha_Reaper
Koenig
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 06:55AM |
Tha_Reaper
Koenig
hacker
Koenig
Sir_Death
GrAndAG
hacker
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 07:38AM |
Sir_Death
Tha_Reaper
Koenig
Some guys even apply PTFE foil on the part of the heatbreak going into the heatblock, to stop the heat from going into the heatbreak.
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 08:01AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 08:04AM |
hacker
Sir_Death
I considered that, but I'm also worried that it might be a bit too hot for PTFE? Gotta do the research perhaps.
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 01:45PM |
Sir_Death
hacker
Sir_Death
Wikipedia tells me PTFE has its melting Point at 327°C
https://de.wikipedia.org/wiki/Polytetrafluorethylen
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 03:14PM |
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 04:57PM |
nebbian
Have you adjusted the motor driver currents? You stick a jewellers screwdriver in the little trimpot, and measure the voltage between the screwdriver and earth, while slowly nudging the screwdriver back and forth. Mine is set to 0.45V.
Re: Ebay SINTRON Kossel Mini full kit November 04, 2015 07:30PM |
Tha_Reaper
nebbian
Checked mine, it was 0.3V. Had a lot of skipping so I cranked it up to 0.45v. Much less skipping, but now on a longer print my PLA bent inside the extruder after the gear and before the PTFE tube. Created an ugly mess... I suspect a hot extruder is at fault for making the PLA more plyable.
Any way to combat this?
Re: Ebay SINTRON Kossel Mini full kit November 05, 2015 12:46AM |
Exactly! I just discovered it 30 minutes later, and it turned into a bird's nest up there.Quote
nebbian
Tha_Reaper
nebbian
Like this?
[attachment 65335 IMG_4506.jpeg]
Add some aluminium or PTFE tube like this:
[attachment 65336 IMG_4507.jpeg]
Re: Ebay SINTRON Kossel Mini full kit November 05, 2015 02:15AM |
Tha_Reaper
What's that part that you used? Can I buy that somewhere?
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 05, 2015 03:41AM |
nebbian
Tha_Reaper
That part is called "Bit of aluminium tube I had lying around".
I've since replaced it with a part called "1 cm offcut of PTFE tubing, exactly the same stuff as is in your bowden tube". The easiest way to do this is to press the little button on your extruder and pop off the bowden tube. Cut off 1 cm and replace. Now put some tape around that offcut and screw it into the threaded hole. You might have to take some parts of the extruder off to do this, because the idler bearing gets in the way. Then trim the tubing so that it's just proud of the gear and idler bearing.
Alternatively if you're feeling brave you could disassemble the push fit connector and drill it out the same as the one on the hotend, which would allow you to push the bowden cable all the way through the hole in the extruder until it's almost touching the extruder gear and idler bearing.
