Re: Ebay SINTRON Kossel Mini full kit
November 04, 2015 02:46AM
Don't take the nozzle diameter for granted.
I got 0.3 nozzles from china, which are 0.4 and vise versa...
-Olaf
November 04, 2015 02:49AM
o_lampe
-Olaf
What's a good way to test this?
Also while we're on the subject, I read somewhere that you should have an extrusion width that is slightly larger than the nozzle size. I've always just used an extrusion width equal to the nozzle size. Can you confirm/deny?
Anonymous User
November 04, 2015 03:24AM
Sir_Death
Nozzle was free before printing - could see through. PTFE tube is down all the way through heatbreake - there was a Problem after building the printer, so I had to disassemble and
reassemble it, therefore I'm sure, how it is assembled now.
Nozzle was jammed this morning after unattended night-print...
I think - or at least hope - I found the problem. - The screw which is pressing the heatblock onto the heatcartridge broke in the middle, so it was not correctly pressing the two parts together anymore... hot smiley
Will have to drill it out this afternoon and reassemble.
Nozzle got jammed, because PTFE-Tube got widened at the end, and so PLA crystalized.. angry smileyangry smiley (Thats why I started dissasembling, because cold pull did not work anymore - so I found the broken screw...)
November 04, 2015 03:32AM
Sir_Death
Sir_Death
Broken screw should've reduced the thing's ability to heat, whereas overheating filament in supposedly cold areas sounds more like not enough cooling? (or decoupling of thermistor and therefore not knowing how hot we are). At any rate, you confuse me winking smiley
Anonymous User
November 04, 2015 03:44AM
The PTFE Tube should reach down through the heatbreak until touching the back of the Nozzle (in the heatblock), so 1.75mm Filament is directed to the nozzle correctly.
So this is not an area to stay cold - because it is in the heatblock spinning smiley sticking its tongue out So now there is crysalized Filament with outer Diameter of the PTFE Tube at the End of the Heatbreak, and fresh filament has to pass through the crystalized one - which is only possible in melted condition... i think, this is one of the points why I had to use such great heat, but still not extruding very much. (second Point might be the broken screw)
We will see, when I've cleaned it up and reassembled, if it works as it should...
Would it be a good Idea to apply some thermal compound on the heatcartridge to ensure best thermal Transfer to the heatblock?
November 04, 2015 04:19AM
nebbian
o_lampe
-Olaf
Find a piece of wire which is 0.4mm (0.3, 0.5, etc) and just check if it fits. I used a bunch of packing wires (they usually used to pack device wires, such as mouses, computer cables, etc). I was able to found 0.3, 0.4, 0.45 and 0.5 wires and they are strong enough to push through the hole.
nebbian
I left it as "auto" in slicer. Because, I think, the extrusion width also depends on layer height, at least.
Edited 1 time(s). Last edit at 11/04/2015 05:14AM by GrAndAG.
November 04, 2015 04:50AM
Sir_Death
I do not think that the problem is in not good heater contact. It can affect the time of heating and wasting energy to heat air. But if the head is able to reach desired temperature, which is measured by thermistor (which is still installed properly), it means the head has requested temperature.
If the filament is overheated, it starts melting not in the nozzle only, but higher, in heat-breaker tube and even in cold zone. At least it may to become wider due to softness on high temperature (PLA becomes soft @ 60C) on overly long distance and the friction will be too strong for extruder.
Anonymous User
November 04, 2015 05:00AM
Desired temperature is one Thing (maybe not even reached while unattended printing) - but for melting, the transferable amount of energy is important.
If to low amount of heat energy is transferred, while keeping Extrusion up, Filament is getting squeezed (wider) and gets stuck. while stuck, heated and keeping preasure up, less melted Filament is brought forward. More melted Filament outside the main path will start to crystalize and slow down less melted Filament in the middle (main path) - perfect conditions for jammed...
November 04, 2015 05:11AM
Sir_Death
I thought it ends halfway in the heatbreak? I need to check that once I'm home, because I happen to have original hotend lying around ready for disassembling winking smiley I'd say PTFT tube *is* kinda cold zone wherever it is, maybe not too cold ;-)
Perhaps I'd try some thermal compound on heatbreak threading to improve thermal transfer to heatsink. And would triple check how well heatsink is colled.
Anonymous User
November 04, 2015 05:21AM
hacker
Sir_Death
Consulting E3D Assembly Instruction at
http://wiki.e3d-online.com/wiki/E3D-v6_Assembly#1.75mm_Universal_.28with_Bowden.29´
it tells you:
"The tubing should be inserted from the top of the now assembled hotend and pushed as far down into the hotend as possible."
With the chinese hotend PTFE Tube is able to go down till the end of the heatbreak.
November 04, 2015 05:23AM
hacker
Just FYI.. Regular (usually for computer coolers) thermal compound is not designed for high temperature, such as in our case. It will degrade rapidly. But it worth to try, if it solves the problem (at least for short time) - you found the problem.
November 04, 2015 05:26AM
Sir_Death
hacker
Sir_Death
it tells you:
You absolutely need to push it as far as possible, I was just hoping it's not all the way. Like it's not with E3D — [RAWING-V6-175-BREAK.png" target="_blank" rel="nofollow">wiki.e3d-online.com] According to what you say, it's not the case, though.
Anonymous User
GrAndAG
hacker
That is exactly the Point which worries me...
So first I'll just reassemble it, as it should be, and check again...
November 04, 2015 05:28AM
GrAndAG
hacker
I'm not sure if it should be *that* hot there, but then I don't know for sure either.
November 04, 2015 05:38AM
Sir_Death
GrAndAG
hacker
Don't think you need to worry to much about it, where the fins are it shouldn't be such extreme temperatures.
It would be another matter if you tried putting thermal compound where the heatblock is (threads to nozzle, around heating cartridge).
E3D actually recommends putting thermal compound on the heatbreak where the fins are.
November 04, 2015 05:49AM
Koenig
Sir_Death
GrAndAG
hacker
Oh yeah, sorry if I wasn't clear (and I almost wasn't), I meant heatbreak threading where it goes into heatsink, of course.
November 04, 2015 05:54AM
hacker
Koenig
Sir_Death
GrAndAG
hacker
That would not be very smart to do that as you really want as little heat transfer between those two parts as possible.
It would be much better if there was a thermal insulator compound to put there.
November 04, 2015 06:31AM
Koenig
hacker
Koenig
Sir_Death
GrAndAG
hacker
But you also don't want the heat to creep up to the PTFE tube and start melting plastic higher up...
Anonymous User
November 04, 2015 06:48AM
Tha_Reaper
Koenig
Some guys even apply PTFE foil on the part of the heatbreak going into the heatblock, to stop the heat from going into the heatbreak.
I was thinking of the possibility of appliying thermal compound on the heatcartridge - so the hottest place! - That's why I'm Little worried about thermal stability of the compound...
November 04, 2015 06:55AM
Tha_Reaper
Koenig
hacker
Koenig
Sir_Death
GrAndAG
hacker
Not very likely to creep up the PTFE tube as it is a very poor thermal conductor, what you want to prevent is the heat creeping up the heatbreak so that plastic starts to melt higher up.
November 04, 2015 07:38AM
Sir_Death
Tha_Reaper
Koenig
I considered that, but I'm also worried that it might be a bit too hot for PTFE? Gotta do the research perhaps.
November 04, 2015 08:01AM
In my hotend I replaced all-metal heatbreak to one with PTFE tube inside. So, PTFE ends even touching brass nozzle inside heat block.
Anonymous User
November 04, 2015 08:04AM
hacker
Sir_Death
Wikipedia tells me PTFE has its melting Point at 327°C
https://de.wikipedia.org/wiki/Polytetrafluorethylen
November 04, 2015 01:45PM
Sir_Death
hacker
Sir_Death
Oh, thanks for doing my homework! Yes, I don't think I'm going above that ;-)
November 04, 2015 03:14PM
BTW, my design of endstops mount plate - [www.thingiverse.com]
It has cavern for soldered pins from back side of endstop PCB. And also has pin for precise mount.
November 04, 2015 04:57PM
nebbian
Have you adjusted the motor driver currents? You stick a jewellers screwdriver in the little trimpot, and measure the voltage between the screwdriver and earth, while slowly nudging the screwdriver back and forth. Mine is set to 0.45V.
Checked mine, it was 0.3V. Had a lot of skipping so I cranked it up to 0.45v. Much less skipping, but now on a longer print my PLA bent inside the extruder after the gear and before the PTFE tube. Created an ugly mess... I suspect a hot extruder is at fault for making the PLA more plyable.
Any way to combat this?
November 04, 2015 07:30PM
Tha_Reaper
nebbian
Like this?
Add some aluminium or PTFE tube like this:
November 05, 2015 12:46AM
nebbian
Tha_Reaper
nebbian
Like this?
[attachment 65335 IMG_4506.jpeg]
[attachment 65336 IMG_4507.jpeg]
Exactly! I just discovered it 30 minutes later, and it turned into a bird's nest up there.
What's that part that you used? Can I buy that somewhere?
November 05, 2015 02:15AM
Tha_Reaper
That part is called "Bit of aluminium tube I had lying around".
I've since replaced it with a part called "1 cm offcut of PTFE tubing, exactly the same stuff as is in your bowden tube". The easiest way to do this is to press the little button on your extruder and pop off the bowden tube. Cut off 1 cm and replace. Now put some tape around that offcut and screw it into the threaded hole. You might have to take some parts of the extruder off to do this, because the idler bearing gets in the way. Then trim the tubing so that it's just proud of the gear and idler bearing.
Alternatively if you're feeling brave you could disassemble the push fit connector and drill it out the same as the one on the hotend, which would allow you to push the bowden cable all the way through the hole in the extruder until it's almost touching the extruder gear and idler bearing.
Edited 1 time(s). Last edit at 11/05/2015 02:18AM by nebbian.
Anonymous User
November 05, 2015 03:41AM
nebbian
Tha_Reaper
I'm using a long 2,5mm² wire end ferrule...
But I'm thinking of removing it again, because this behavior appeared only, when trying to extrude at higher Speed than the nozzle can handle...
I got a really bad "jammed" with about 5mm Long crystalized PLA in the Heatbreak - had to drill it out yesterday...
Now Printer is working again - I've a strange roll of PLA - more than about 10-15mm/sek printing speed is not possible.. (Volumetric 1,3mm³/sek)..
But who cares.... printing slow gives good Quality...
