Re: New RAMPS design August 28, 2018 08:32AM |
The quality from seeedstudio is good. Over the years I have ordered many PCB's from seeedstudio, and they have all beed good.Quote
kabelfrikkler
how was the quality of the seestudio PCBs? and mostly: what quantetys and price range are we talking?
Always good to know of a place with reasonable prices for boards with one side larger than 10cm.Quote
kabelfrikkler
ALLPCB would be more interesting if we (you) say to order 10/20pcs and all go and try and test them out.
Those boards look nice.
Re: New RAMPS design August 28, 2018 03:14PM |
Re: New RAMPS design August 28, 2018 03:19PM |
Re: New RAMPS design August 28, 2018 03:21PM |
Re: New RAMPS design August 28, 2018 03:27PM |
Re: New RAMPS design August 28, 2018 03:33PM |
Re: New RAMPS design August 28, 2018 04:03PM |
Re: New RAMPS design August 29, 2018 02:24AM |
kabelfrikkler
I had a bord with these, (or i do sell a bord that use these in work) they are good but you do need the right angle to insert the cable and triger the releas mechanics, but they grip to everything if it fits in.
for high current i would recomend [www.reichelt.de]
(sorry i dont have a english suplier)
they ar availible for "in house instalations" dirt cheep and i use them for all my prototyping, no tools reqired and they dont care if i use 4mm² or 0.2mm² cable, thined or not. very fast an easy.
and now that you mentioned it, i thing i will be using these [www.reichelt.de] for my board as it has RM2.54 for my fans and leds thermistors..
Re: New RAMPS design August 30, 2018 03:50PM |
Re: New RAMPS design August 31, 2018 03:08AM |
kabelfrikkler
@ kadah
in a not PCB enviroment like construction sides in Germany they are the standart and srews are forbidden for mains power and the "push connectors" widly used are about to get forbidden, on commercial use.
Re: New RAMPS design September 02, 2018 07:26AM |
Re: New RAMPS design September 02, 2018 07:35AM |
Re: New RAMPS design September 03, 2018 12:54AM |
Re: New RAMPS design September 03, 2018 05:29AM |
o_lampe
AFAIK, the LCD has a 5V_to_3.3V regulator onboard. With this bypassed regulator ( shorted ) it should work without any levelshifting.
Re: New RAMPS design September 11, 2018 10:11AM |
Re: New RAMPS design September 11, 2018 11:15AM |
Re: New RAMPS design September 11, 2018 11:34AM |
Re: New RAMPS design October 23, 2018 03:06AM |
Re: New RAMPS design October 23, 2018 04:27PM |
Re: New RAMPS design October 25, 2018 04:36PM |
Re: New RAMPS design October 31, 2018 05:53AM |
Re: New RAMPS design November 03, 2018 08:19PM |
Re: New RAMPS design January 07, 2019 10:55PM |
Re: New RAMPS design January 20, 2019 06:18AM |
Re: New RAMPS design January 20, 2019 06:23AM |
dc42
......have you considered using it with the SAME70-XPLD board? It has a 300MHz ARM Cortex M7 processor, on-board Ethernet, and SD card with high speed interface. RepRapFirmware has been running on it for over a year (including the network interface, of course) because we used it to prototype parts of Duet 3. It's just $38.82 from Digikey, see [www.digikey.com]. It has Arduino-layout expansion pads, although you need to add the socket strips yourself.
Re: New RAMPS design January 20, 2019 06:43AM |
shimondoodkin
maybe for esp and raspberry pi add this idea:
[github.com]
maybe to add two shift registers
Re: New RAMPS design January 20, 2019 08:39AM |
HomeGamer_Engineer
If i am following correctly, it seems like the 1.7 would be compatible with the up coming "Grand Central" release from Ada Fruit?
Grand Central
It seems like a very powerful board, but it 3.3V. In some of their tweets about it, they mention #Ramps, but your work here is the only Ramps i know of that will work with 3.3V.
I am very excited that with the release of this powerful new board in the mega format, the Ramps form factor may make a resurgence. It is also exciting that you are leading the wave with this awesome work!!!
Re: New RAMPS design January 23, 2019 06:31PM |
Re: New RAMPS design January 24, 2019 09:14AM |
HammerDown
Ill pay to play for 1
Re: New RAMPS design January 24, 2019 02:35PM |
