Re: [Sammelthread] Druck optimieren - Der Parameterthread 10. March 2016 14:37 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 193 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 14. March 2016 21:14 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 34 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 15. March 2016 13:34 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 12 |
#define DEFAULT_MAX_FEEDRATE {160, 160, 2, 22} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {800,800,5,1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 800 // X, Y, Z and E max acceleration in mm/s^2 for retracts
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
Re: [Sammelthread] Druck optimieren - Der Parameterthread 15. March 2016 14:15 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 214 |
#define DEFAULT_MAX_FEEDRATE {200.00, 200.00, 2.80, 50.00} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {1000.00,1000.00,100.00,6000.00} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 1000.00 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000.00 // X, Y, Z and E max acceleration in mm/s^2 for retracts
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
// #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
// #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 15.0 // (mm/sec)
Re: [Sammelthread] Druck optimieren - Der Parameterthread 15. March 2016 15:35 |
Mr.Coffee89
Warum so niedrige Werte in der Firmware?
Mr.Coffee89
Und warum Infill: 10% 3D Honeycomb ? Nimm doch lieber Rectilinear
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 06:53 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 07:04 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 3.385 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 07:07 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 1.807 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 07:27 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 310 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 07:37 |
Skimmy
Er erkennt das als "bridge". Du hast bei bridge-multiplier wahrscheinlich einen kleineren Wert als 1 stehen.
. Die Schärfe der Details hat sie leicht verbessert, aber die Ecken am Bug haben sich weiterhin hochgewölbt und der Rest ist fast gleich geblieben.|
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 08:08 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 47 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 08:12 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 08:13 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 08:23 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 08:46 |
nicht, dass sie sich von der Druckplatte lösen, sondern sich während dem Drucken ab, ca. 3mm über der Platte nach oben wölben.Quote
JasperZ
... aber die Ecken am Bug haben sich weiterhin hochgewölbt...
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 09:27 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 18:16 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 16. March 2016 18:29 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 4.977 |
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 17. March 2016 05:49 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 102 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 17. March 2016 06:58 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 966 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 17. March 2016 07:26 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 17. March 2016 08:38 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 17. March 2016 10:12 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 17. March 2016 10:13 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 17. March 2016 11:28 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 18. March 2016 13:19 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 3.973 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 19. March 2016 06:35 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 36 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 19. March 2016 07:44 |
Re: [Sammelthread] Druck optimieren - Der Parameterthread 19. March 2016 13:14 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 99 |
