Re: Design idea - fixation and tightening of the y-drive belt January 19, 2014 09:11AM |
Re: Design idea - fixation and tightening of the y-drive belt January 19, 2014 09:28AM |
Re: Design idea - fixation and tightening of the y-drive belt February 02, 2014 06:55PM |
iamburny
@dc42 - Yep I will be able to modify that part to have a straight slot for the right side of the bed rib, I'll get onto it later. I have removed the belt twist on my Y axis , the belt tension was easily applied and I've done a few prints now with no discernible difference in print quality, i'll still modify the right side part however just to give that as an alternative.
Re: Design idea - fixation and tightening of the y-drive belt February 03, 2014 07:52AM |
Re: Design idea - fixation and tightening of the y-drive belt February 06, 2014 11:04AM |
Re: Design idea - fixation and tightening of the y-drive belt February 06, 2014 11:28AM |
Re: Design idea - fixation and tightening of the y-drive belt February 07, 2014 05:06AM |
johneato
I've been doing a bit of parallel development, I was producing a two screw Y belt adjuster and then saw Ians reference to an hinged adjuster for the Y axis. So modified my design as can be seen in the attachment. Seems to work quite well.
[attachment 24807 IMG_0504.jpg]
Ormerod 096
Re: Design idea - fixation and tightening of the y-drive belt February 07, 2014 07:28AM |
iamburny
@dc42 - Finally got around to fixing the Y-Belt clamps so you can retain the twist in the belt if required.
Re: Design idea - fixation and tightening of the y-drive belt February 07, 2014 07:39AM |
Re: Design idea - fixation and tightening of the y-drive belt February 07, 2014 11:27AM |
Re: Design idea - fixation and tightening of the y-drive belt February 07, 2014 12:25PM |
Re: Design idea - fixation and tightening of the y-drive belt February 08, 2014 03:57AM |
I have attached a copy of all the bits I have made to modify the Y beltQuote
Mr.Burns
@johneato: Do you have any stl-files for me/us? I would like to try your version of the belt tensioner, if its ok for you. It would be very much appreciated. ;-)
Thanx, Sven
Re: Design idea - fixation and tightening of the y-drive belt February 09, 2014 04:20AM |
Re: Design idea - fixation and tightening of the y-drive belt February 11, 2014 04:21AM |
Re: Design idea - fixation and tightening of the y-drive belt February 12, 2014 12:07PM |
Re: Design idea - fixation and tightening of the y-drive belt February 12, 2014 12:33PM |
Re: Design idea - fixation and tightening of the y-drive belt February 12, 2014 01:40PM |
Re: Design idea - fixation and tightening of the y-drive belt February 12, 2014 02:16PM |
appjaws1
Matt
Just printed your y-belt-clamp version 7 but I think my printer is not quite good enough to print accurately. Although the 2 parts look good and are square in all directions the gap between the sections where the belt should grip the groves is so small that I can not get the belt inserted. I assume that they printed OK on your printer so I must have something wrong.
Have you any ideas what I could do to improve the quality of prints.
Re: Design idea - fixation and tightening of the y-drive belt February 12, 2014 02:33PM |
appjaws1
Is it possible for you to provide individual stl or g code files please.
Thank you for your help
Paul
Re: Design idea - fixation and tightening of the y-drive belt February 12, 2014 02:35PM |
Re: Design idea - fixation and tightening of the y-drive belt February 12, 2014 03:48PM |
Re: Design idea - fixation and tightening of the y-drive belt June 14, 2014 11:12AM |
Re: Design idea - fixation and tightening of the y-drive belt June 14, 2014 11:17AM |
Re: Design idea - fixation and tightening of the y-drive belt June 15, 2014 11:18AM |
