Re: Laser cut Aluminium X-Arm & Rib kits.... August 23, 2014 07:55AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 23, 2014 09:08AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 23, 2014 09:16AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 23, 2014 09:40AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 23, 2014 10:12AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 23, 2014 11:18AM |
Mercnik
I would love to buy it, but i think that just shipping costs more than i would pay to get it cut out here.
But if i have any problems geting it here i will get back to you.
THen i will probably purchase also x ribs.
Thank's
Re: Laser cut Aluminium X-Arm & Rib kits.... September 01, 2014 05:17PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 02, 2014 01:59PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 02, 2014 02:28PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 02, 2014 03:10PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 05, 2014 07:38AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 05, 2014 02:12PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 05, 2014 03:09PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 06, 2014 07:28AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 06, 2014 08:02AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 13, 2014 03:24AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 13, 2014 06:13AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 18, 2014 10:20AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 18, 2014 12:00PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 18, 2014 12:25PM |
dc42
From the images I have seen, I think that the Ormerod 2 x-rib may have cutouts in it for a longer tab on the extruder drive to fit into.
Re: Laser cut Aluminium X-Arm & Rib kits.... September 18, 2014 12:35PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 18, 2014 01:44PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 18, 2014 03:10PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 05, 2014 03:20AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 07, 2014 04:45PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 10, 2014 05:00PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 11, 2014 03:31AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 11, 2014 03:51AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 11, 2014 05:06AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 11, 2014 05:21AM |
Amsterdamman
I'm still working on my Ormerod2, but the X-arms are basically the same. The small cutouts on the new arm allow the extruder tab to lock into the arm. So the old Ormerod1 kit won't even notice the new cutouts as they are lower than the extruder tab. My extruder has been solid and has no need to be more secure.
Amsterdamman
I am getting more wear on my Z rod than I would like. Already replaced it twice and now I have a normal height brass nut on it and can already see brass left behind on the screw threads. Not sure if the added weight of the metal arms is part of the problem. I am looking for a local shop to get a set cut and anodized blue or red!
