Re: Laser cut Aluminium X-Arm & Rib kits.... October 02, 2015 06:49AM |
BriComp
If it's "Pretty Good as it Comes" then why are you modifying the stock that you have for the latest Ormerod 2?
Re: Laser cut Aluminium X-Arm & Rib kits.... October 19, 2015 01:37PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 31, 2015 04:26AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 21, 2015 03:23AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 21, 2015 05:41AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... November 21, 2015 11:07AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 14, 2015 07:29AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 15, 2015 09:44AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 15, 2015 10:34AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 15, 2015 10:47AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 15, 2015 11:37AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 15, 2015 12:27PM |
Treito
My X-arm kit of my Ormerod 1 got damaged
Re: Laser cut Aluminium X-Arm & Rib kits.... December 15, 2015 01:34PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... December 15, 2015 01:37PM |
Treito
Maybe there is a fix which looks of course somehow like a fix. As Electrician I would never have thought that something like this may happen, but it happened:
[forums.reprap.org]
Re: Laser cut Aluminium X-Arm & Rib kits.... December 15, 2015 01:40PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 03, 2016 02:03PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 03, 2016 02:15PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 10, 2016 04:18AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 10, 2016 02:04PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 10, 2016 02:21PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 10, 2016 03:03PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 10, 2016 03:05PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 01:16AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 01:56AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 02:16AM |
Roffern
You you ship to Norway im interested in the alu x-arm kit
Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 02:17AM |
Treito
I am still quite unsure. For my second machine I use a solution somehow between the original Acrylic arm and the Aluminium arm. This is a lot of money especially when adding VAT and shipping to Germany and I will have to add a shim again.
So are there any pictures that shows a direct comparison before and after?
Unfortunately I cannot compare with my Ormerod 1 as it still has some undetected mechanical issues and also another nozzle so the printing quality of my MK2 is higher than the MK1.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 03:37AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 03:39AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 05:20AM |
Treito
Regarding the pictures I meant printed parts. For example the 3DBenchy printed with the Acrylic arm and printed with the Aluminium arm.
Re: Laser cut Aluminium X-Arm & Rib kits.... January 11, 2016 05:38AM |
