Re: My coreXY design is progressing to the build stage March 06, 2017 10:46PM |
Re: My coreXY design is progressing to the build stage March 12, 2017 11:50AM |
Re: My coreXY design is progressing to the build stage March 13, 2017 12:59AM |
Re: My coreXY design is progressing to the build stage March 13, 2017 10:23AM |
Re: My coreXY design is progressing to the build stage March 13, 2017 10:39AM |
Re: My coreXY design is progressing to the build stage March 13, 2017 10:42AM |
Re: My coreXY design is progressing to the build stage March 13, 2017 02:34PM |
the_digital_dentist
Some test video of a dry run at 150 mm/sec. Acceleration is 1000 mm/s/s. I used a large enough object that the thing will actually hit 150 mm/sec when running the infill at 45 and 135 degrees driven by a single motor. I set all speeds in the slicer, including small perimeters, to 150 mm/sec.
The Z axis is operating during all this, too. It lifts on retract and of course, steps 0.2 mm for each layer.
No matter what sort of crazy stuff the extruder carriage does, I don't see the edges of the bed plate bouncing or vibrating at all.
Here's the Z=0 switch in operation I added a lever because I have found (in my other printer) that bed zero position is just too hard to control when the adjuster screw pushes the switch directly. One turn of the screw results in almost 800 um of bed displacement. Since adjustments more typically need to be on the order of 50 um at a time, it's a little hard to know just how far the bed's going to move when you turn the screw. The lever provides about an 8:1 reduction in sensitivity, so one full turn of the 32 TPI screw results in about 100 um of bed movement. It tilts on a bearing removed from a HDD that press fits into the lever. The small spring ensures that the switch opens when the bed moves down (instead of relying on the weight of the lever alone to open the switch).
Here's the Zmax switch in operation The Z axis motion stops about 1/2 mm above the bright green rubber bumper.
Re: My coreXY design is progressing to the build stage March 16, 2017 07:24AM |
Re: My coreXY design is progressing to the build stage March 18, 2017 12:24AM |
Re: My coreXY design is progressing to the build stage March 18, 2017 04:07AM |
Re: My coreXY design is progressing to the build stage March 18, 2017 07:03AM |
Re: My coreXY design is progressing to the build stage March 18, 2017 09:53AM |
Re: My coreXY design is progressing to the build stage March 18, 2017 02:43PM |
Re: My coreXY design is progressing to the build stage March 19, 2017 01:22PM |
Re: My coreXY design is progressing to the build stage March 19, 2017 02:52PM |
Re: My coreXY design is progressing to the build stage March 20, 2017 12:59AM |
Re: My coreXY design is progressing to the build stage March 20, 2017 10:00AM |
Re: My coreXY design is progressing to the build stage March 22, 2017 08:01AM |
Re: My coreXY design is progressing to the build stage March 23, 2017 11:14PM |
Re: My coreXY design is progressing to the build stage March 24, 2017 10:08AM |
Re: My coreXY design is progressing to the build stage March 24, 2017 03:22PM |
Re: My coreXY design is progressing to the build stage March 26, 2017 12:42PM |
Re: My coreXY design is progressing to the build stage March 26, 2017 01:17PM |
Re: My coreXY design is progressing to the build stage March 26, 2017 01:56PM |
Re: My coreXY design is progressing to the build stage March 26, 2017 02:23PM |
Re: My coreXY design is progressing to the build stage March 26, 2017 09:58PM |
Re: My coreXY design is progressing to the build stage March 26, 2017 10:41PM |
Re: My coreXY design is progressing to the build stage March 26, 2017 10:46PM |
Re: My coreXY design is progressing to the build stage March 27, 2017 07:20AM |
I've been using OnShape and it feels very much like Solidworks. I can't say there's much functionality that I've been missing in my use. My only complaint is that some of the operations feel slow, as it has to be done on the server.Quote
Qdeathstar
Yeah, i have heard some nasty things about onshape as far as the functionality goes.
Why has the surface gotten so rough on the 0.036mm part ? There also seems to be some ringing on the second cube that wasn't there on the first.Quote
the_digital_dentist
I ran some tests on single walled cubes and got the layer registration to look better. I tightened up the XY belts, tweaked the extruder steps per mm, and adjusted the Z axis parameters of the prints. I crunched some numbers and came up with layer thicknesses and lift-on-retract heights that correspond to full steps in the Z axis motor. I ran a couple more tests to tweak the extruder motor steps per mm and I thinks it's working pretty well now.
Each full step of the Z axis motor moves the bed 0.018 mm. I ran new prints at 0.27 mm and 0.090 mm, and at 0.090 and 0.036 mm, all whole motor step intervals. At 0.036 mm the layer registration looks OK, but the surface gets a little rough. I think it's safe to say I probably won't be printing much at that layer thickness, certainly not anything 700mm tall.
Re: My coreXY design is progressing to the build stage March 27, 2017 07:36AM |
