Re: My coreXY design is progressing to the build stage January 22, 2018 03:25AM |
SydneyDesigner
What about just using the enclosure heater to heat the entire enclosure and bed together - up to say 60-80C, as required to best suit the material being printed? In other words, not use a bed heater at all.
Do people think this would work for a good range of printed materials?...including TPU, PLA, ABS etc.?
Re: My coreXY design is progressing to the build stage January 22, 2018 08:30AM |
Re: My coreXY design is progressing to the build stage January 23, 2018 05:08AM |
o_lampe
How would you spread the heat evenly across the bed? A thick plate of aluminum spreads the heat pretty good, but with a single heat source in the center of the bed, you'd still see a difference.
the_digital_dentist
I think there are several problems with that idea. First, ABS won't stick to the bed if the temperature is too low, and getting the enclosure up to 100C is going to create all sorts of other problems. Belts and motors aren't going to work well or last long, the hot end is going to need water cooling, etc.
You can do as stratasys used to do in older printers and print ABS on a sacrificial foam bed. We've tested PIR foam in Stratasys printers at the Milwaukee Makerspace and works, though it's a little softer than the foam stratasys normally uses for the purpose. Those printers heated the enclosure to 70C, and they pipe in and exhaust room air to cool the extruders.
In smaller printers with insulated enclosures, the bed heater alone (or with the addition of a lightbulb) is often adequate to heat the enclosure.
Re: My coreXY design is progressing to the build stage January 23, 2018 08:39AM |
Re: My coreXY design is progressing to the build stage January 24, 2018 06:51AM |
Re: My coreXY design is progressing to the build stage January 28, 2018 06:28PM |
Re: My coreXY design is progressing to the build stage January 29, 2018 02:54AM |
Re: My coreXY design is progressing to the build stage January 29, 2018 07:52AM |
Re: My coreXY design is progressing to the build stage January 29, 2018 07:53AM |
Re: My coreXY design is progressing to the build stage January 29, 2018 11:31AM |
Qdeathstar
Does a cpap pump move the air at low pressure? That’s a really big hose... takes up quite a bit of real estate. One of the advantages of a air pump is that it blows cool air instead of hot air in the build chamber..
Re: My coreXY design is progressing to the build stage January 29, 2018 03:53PM |
the_digital_dentist
I wouldn't put a filter on an axial or radial fan that's doing the same job, so why put one on the CPAP blower? I can open the blower up and clean the impeller a lot easier than cleaning off an axial fan blade or squirrel cage...
Re: My coreXY design is progressing to the build stage January 29, 2018 03:57PM |
Re: My coreXY design is progressing to the build stage February 02, 2018 08:37AM |
Re: My coreXY design is progressing to the build stage February 03, 2018 07:46PM |
Re: My coreXY design is progressing to the build stage February 04, 2018 09:17AM |
Re: My coreXY design is progressing to the build stage February 04, 2018 04:45PM |
Re: My coreXY design is progressing to the build stage February 04, 2018 06:35PM |
motor steps/rev 200 200 200 200 200 ustepping 16 16 16 16 16 gear reduction 30 30 30 30 30 pulley teeth 60 50 48 36 40 belt pitch 2 2 2 3 3 usteps/mm 800 960 1000 888.89 800 full steps/mm 50 60 62.5 55.56 50
layer thickness full steps 0.01 0.556 0.02 1.111 0.03 1.667 0.04 2.222 0.05 2.778 0.06 3.333 0.07 3.889 0.08 4.444 0.09 5.000 0.1 5.556 0.11 6.111 0.12 6.667 0.13 7.222 0.14 7.778 0.15 8.333 0.16 8.889 0.17 9.444 0.18 10.000 0.19 10.556 0.2 11.111 0.21 11.667 0.22 12.222 0.23 12.778 0.24 13.333 0.25 13.889 0.26 14.444 0.27 15.000 0.28 15.556 0.29 16.111 0.3 16.667 0.31 17.222 0.32 17.778 0.33 18.333 0.34 18.889 0.35 19.444 0.36 20.000 0.37 20.556 0.38 21.111 0.39 21.667 0.4 22.222 0.41 22.778 0.42 23.333 0.43 23.889 0.44 24.444 0.45 25.000 0.46 25.556 0.47 26.111 0.48 26.667 0.49 27.222 0.5 27.778 0.51 28.333 0.52 28.889 0.53 29.444 0.54 30.000
layer thickness full steps 0.01 0.500 0.02 1.000 0.03 1.500 0.04 2.000 0.05 2.500 0.06 3.000 0.07 3.500 0.08 4.000 0.09 4.500 0.1 5.000 0.11 5.500 0.12 6.000 0.13 6.500 0.14 7.000 0.15 7.500 0.16 8.000 0.17 8.500 0.18 9.000 0.19 9.500 0.2 10.000 0.21 10.500 0.22 11.000 0.23 11.500 0.24 12.000 0.25 12.500 0.26 13.000 0.27 13.500 0.28 14.000 0.29 14.500 0.3 15.000 0.31 15.500 0.32 16.000 0.33 16.500 0.34 17.000 0.35 17.500 0.36 18.000 0.37 18.500 0.38 19.000 0.39 19.500 0.4 20.000 0.41 20.500 0.42 21.000 0.43 21.500 0.44 22.000 0.45 22.500 0.46 23.000 0.47 23.500 0.48 24.000 0.49 24.500 0.5 25.000 0.51 25.500 0.52 26.000 0.53 26.500 0.54 27.000
Re: My coreXY design is progressing to the build stage February 07, 2018 09:10AM |
TDD
(200 steps/ 1 motor rev) x (16 usteps/step) x (30 motor revs/1 pulley rev) x (1 pulley rev/36 pulley teeth) x (1 pulley tooth/3mm) = 888.888888... usteps/mm
Re: My coreXY design is progressing to the build stage February 07, 2018 12:55PM |
Re: My coreXY design is progressing to the build stage February 07, 2018 04:51PM |
Re: My coreXY design is progressing to the build stage February 07, 2018 10:30PM |
Re: My coreXY design is progressing to the build stage February 08, 2018 07:59AM |
Re: My coreXY design is progressing to the build stage February 08, 2018 10:32AM |
Re: My coreXY design is progressing to the build stage February 10, 2018 05:12AM |
Re: My coreXY design is progressing to the build stage February 10, 2018 11:16AM |
Re: My coreXY design is progressing to the build stage February 14, 2018 08:25PM |
Re: My coreXY design is progressing to the build stage February 16, 2018 01:28AM |
Re: My coreXY design is progressing to the build stage February 16, 2018 02:47AM |
printman
@digital_dentist I looked at Rino block and not sure how you mounted the shaft to that. Rino has 8mm hole diameter with a little groove on it. Did you cut a groove to the shaft and put there a bar or something to connect the shaft with the Rino block?
Re: My coreXY design is progressing to the build stage February 16, 2018 07:42AM |
Re: My coreXY design is progressing to the build stage February 16, 2018 01:01PM |
