Recycle symbols
December 18, 2009 05:00PM
Here is a question, should we be printing, or embedding a recycle symbol with the plastic type number or type in it when we start a print?
Cause with all the plastic around, and a recycle method to use old plastic, its better to have the plastic recycled at a plant than just biffed into a landfill.
Eg
Re: Recycle symbols
December 18, 2009 06:35PM
Excelent sugestion.. this should be built in to every print there is a note in this forum and on the main blog regarding the diffrent numbers to go in the symbol.
* 1 - Polyethylene terephthalate (PET)
* 2 - High-density polyethylene (HDPE)
* 3 - Polyvinyl chloride (PVC)
* 4 - Low-density polyethylene (LDPE)
* 5 - Polypropylene (PP)
* 6 - Polystyrene (PS)
* 7 - Other resins, like acrylonitrile butadine styrene (ABS)
A link here too :-
[www.bitsfrombytes.com]
Bodge It [reprap.org]
BIQ Sanguinololu SD LCD board BIQ Stepcon BIQ Opto Endstop
BIQ Heater Block PCB BIQ Extruder Peek clamp replacement BIQ Huxley Seedling
BIQ Sanguinololu mounting BIQ standalone Sanguinololu or Ramps mounting Print It Stick It Cut it
My rep strap: [repstrapbertha.blogspot.com]
Buy the bits from B&Q pipestrap [diyrepstrap.blogspot.com]
How to Build a Darwin without any Rep Rap Parts [repstrapdarwin.blogspot.com]
Web Site [www.takeaway3dtech.com]
Re: Recycle symbols
January 21, 2010 01:31PM
thats a good idea, though i think some sort of stamp might be better, more readable at least.
[mike-mack.blogspot.com]
Re: Recycle symbols
January 22, 2010 12:16AM
We might want a special mark for PLA to indicate that it should be composted..?
Re: Recycle symbols
January 22, 2010 12:30AM
I just created [[Plastic_Symbols]] up on the wiki
[objects.reprap.org]
for folk who want to upload images of these parts.
Regarding PLA and other compostables, perhaps a sprout growing out of a RepRap symbol or the recycling triangle?
Although if we're composting PLA, that means we need to do more work on [[Recycler]].
Re: Recycle symbols
January 22, 2010 09:15AM
i don't know if i am right about this or not but has far has i know even PLA need very warm temperatures to properly decompose so it will not decompose very well in your average back yard composter.
Re: Recycle symbols
January 22, 2010 03:57PM
Don´t forget to add the QA-barcode with the URL for thingiverse
for the object you printed right next to it.
(While you´re at it anyway.)
* homeprototype free 3d design repository
* Blog
* Google+
Re: Recycle symbols
January 23, 2010 10:56AM
> composter.
Your post promted me to do a quick google on composting PLA, and most links I found claimed that PLA was completely compostable, as long as the compostheap did contain less than 10% PLA.
e.g.
[agproducts.unl.edu]
[www.biobadge.com]
I did find one, claiming otherwise, but that site appears to be somewhat biased [www.plasticredesignproject.org]
I haven't done any testing on my own, so the usual precautions about information taken from the Internet should be applied.
Edit: modified the word "more" to "less", in "did contain less than"
Edited 1 time(s). Last edit at 01/23/2010 10:58AM by anton.
Re: Recycle symbols
January 23, 2010 02:31PM
good point i had to do some refreshing too, what i found was they say it is best in the warmer temperatures in a compost bin so i was not all that right, i wonder if i was not thinking about another plastic maybe. but thats good, so long has your compost bin is good and warm it will turn into water and co2
good news for us then
