Re: Migbot Prusa i3 Unofficial Support Thread August 26, 2015 05:09PM |
jbehan
I will try a higher nozzle temp, I think I'm at 240 C already, will bump it up 5 C. I do have an enclosure in place and I've been using a bed temp of 110 C, lowering to 90 C after 1 mm. Are you doing anything with the cooling fan?
Thanks for your feedback.
Josh
Re: Migbot Prusa i3 Unofficial Support Thread August 27, 2015 08:30AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 27, 2015 12:55PM |
jbehan
gatorNic,
Tried again at 245 C and it's better but still had some separation of layers, makes sense about having no fan. I will give it another try tonight without fan. I haven't taken the temp inside my enclosure but I haven't had any warping since I started using it. My enclosure is just some 1/4" foam sheet (FFF foam from HD) taped together with aluminum tape used for duct work. I'm trying to print new X axis parts, specifically the right side with an adjustable belt tensioner. Maybe I have something else messed up, I'm printing at 60 mm/min, 245 C nozzle, 110 C bed, 0.2 mm layer height, 20% in-fill with a 20 line skirt. Does the amount of in-fill affect layer adhesion? Also, I have an in-fill/shell overlap of 18%, maybe that's too high as well....guess this is part of the fun!
Josh
Re: Migbot Prusa i3 Unofficial Support Thread August 27, 2015 10:10PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 28, 2015 04:11AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 28, 2015 08:22AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 28, 2015 08:25AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 28, 2015 04:48PM |
kareem613
Having some trouble with a brand new build. The electron 3D variant. All the instructions say migbot though.
When I turn it on, the extruder temp reports 358 and I get a MAXTEMP error.
I tried flashing the firmware from the 1st post in this thread and it still behaves the same. Thermistor is plugged in properly. I triple checked.
Any ideas on what I can try next?
How do I confirm what type of thermistor is being used to make sure the configuration,h file is right?
Thanks!
EDIT: I just tested the thermistor with a multimeter. Zero resistant. Does that mean my thermistor is dead? If so, now what?
Re: Migbot Prusa i3 Unofficial Support Thread August 28, 2015 04:51PM |
jbehan
gatorNic, you rock!
Thanks for the advice, it worked like a charm. No separation of layers, no corner melting....awesome. Thanks for helping me over that little hurdle.245 C nozzle - 110 C bed and no fan.
Josh
Re: Migbot Prusa i3 Unofficial Support Thread August 30, 2015 05:41AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 30, 2015 05:50AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 31, 2015 04:44AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 31, 2015 02:58PM |
Re: Migbot Prusa i3 Unofficial Support Thread September 01, 2015 05:13AM |
ansisl
Hi guys!
I've also just finished assembling this printer. Got two problems :/
1. imo my proximity sensor is faulty - light comes up then it's close to plate but it never stops the Z motor :/ ('old' Z endstop does when using with G29). I've tested it from a quite safe height with different aluminum 'targets' - it just keeps going down. I did shorten its original cable quite much but I soldered wires exactly right as they where. Can anyone give me e.g. multimeter reading from working proximity sensor? Thx
Re: Migbot Prusa i3 Unofficial Support Thread September 01, 2015 05:16AM |
Re: Migbot Prusa i3 Unofficial Support Thread September 03, 2015 08:18AM |
Re: Migbot Prusa i3 Unofficial Support Thread September 05, 2015 07:44AM |
Re: Migbot Prusa i3 Unofficial Support Thread September 05, 2015 09:42AM |
Re: Migbot Prusa i3 Unofficial Support Thread September 05, 2015 01:48PM |
I dont have a solution but im guessing you are printing with a computer not from a sd-card. First i would try printing from a sd-card. If it works without problems the issue lies in your computer.Quote
veaceonee
Interesting issue is showing its evil head.
Printer is working great. Except when it starts getting to about 14 hrs into a print, then it starts creating stairs in the print, and at exactly 15 hrs 36 minutes (every time) I get a Serial Comm error and it shuts down the print. Any suggestions?
Re: Migbot Prusa i3 Unofficial Support Thread September 05, 2015 02:14PM |
ansisl
Hi guys!
2. as I expected with those thin wires I can get my alu plate till ~98C at best (when not printing) and it takes forever. To get ~120C on my old prusa i3 I had to use SevenSwitch to power build plate separately :/ Now when bed is turned on its hardly 10v (where it should be 12v).
Re: Migbot Prusa i3 Unofficial Support Thread September 05, 2015 03:06PM |
kaffemustasj
So I just assembled a variant of the migbot, and I have some starting questions. I didn't get auto leveling with the kit, so Ill probably buy this sensor later, now I'm just using an end stop on the z-axis.
It's a good thing this helpful community exists, otherwise I would be dead in the waters.
How do I find out at what height to put the z-axis end stop?
What settings do I need to take a look at in the marlin firmware?
How do I calibrate the printer, specifically how much the motors move?
How do you add the migbot specific settings to the new version of cura?
Re: Migbot Prusa i3 Unofficial Support Thread September 05, 2015 03:18PM |
w4rdaddy
I dont know about others but my migbot has pretty robust cables imho for the bed(maybe 2.0m2 or 2.5m2) but it still took ages (+1h) to reach 100c. Solution was to insulate the underside of the heatbed and before printing put something fireproof on the printbed so that the heat wont dissipate. I use a fire blanket folded, and remove it just before printing. Now its about 15-20min to 110-120c for abs.
Re: Migbot Prusa i3 Unofficial Support Thread September 05, 2015 03:22PM |
Re: Migbot Prusa i3 Unofficial Support Thread September 05, 2015 03:23PM |
gatorNic
w4rdaddy
Woah an hour! Mine is not insulated and takes about 10-15mins to reach 105. Although insulation is not a bad idea, it would probably help keep the acrylic from warping on long abs prints.
What did you insulate it with?
Re: Migbot Prusa i3 Unofficial Support Thread September 05, 2015 03:31PM |
gatorNic
w4rdaddy
Re: Migbot Prusa i3 Unofficial Support Thread September 06, 2015 08:43AM |
gatorNic
kareem613
Thanks!
Those wires in the thermister are so tiny they easily get pinched or broken. Mine has a small pinch and gives that warning sometimes, but I just fiddle with it and turn off/on again and it works.
Did they not send you an extra thermistor in the migbot box? They did with mine, and I remember somebody else mentioning it too. They are real cheap if not. I would just buy a bunch since the are so breakable.
Re: Migbot Prusa i3 Unofficial Support Thread September 06, 2015 02:06PM |
Re: Migbot Prusa i3 Unofficial Support Thread September 06, 2015 05:36PM |
Re: Migbot Prusa i3 Unofficial Support Thread September 06, 2015 09:07PM |
w4rdaddy
veaceonee
Check the usb-hibernation settings and everything that could possibly affect the usb-ports etc..and make sure you have enough processing power on your computer. If the computer priorizes power to high level tasks the printer can start skipping steps if it cant get data fast enough. Printing from a sd-card should fix that problem. Or a faster computer.
Killing all unnecessary backround processes, surfing, and other programs while printing is the way to go with an older computer.
Someone correct me if i am wrong...
And if you are printing with a card, forget all the things you just read
Re: Migbot Prusa i3 Unofficial Support Thread September 06, 2015 10:07PM |
