Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 05, 2015 09:29PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 05, 2015 09:36PM |
msaeger
Thanks again animoose I tried to check that using the method called out in this video where he has you mark the shafts and measure. I checked X and it was off so using his formula I tried setting the X value to 81.09 and it still moved the same distance. After I edited the configuration.h I just uploaded it to the arduino again and disconnected / reconnected usb. Do I need to do something else after changing the value?
[youtu.be]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 05, 2015 10:18PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 10:01AM |
mel0n
Aridad
mel0n
Just curious, is anybody else's printer really loud? Mine has been really loud, and getting progressively louder the more I print with it. Its completely related to the X-Axis and its a really loud vibration. I have tried messing with belt tension to make sure its not too tight, but the sound is still loud...My Y is nice and quiet even during rapid movements that usually have my X axis screaming.
This is the one of the only complaints I have about this printer. My printer performs and prints beautifully. My wife and I have run it probably 16 hours a day for the last three weeks!
My printer rapids in x perfectly, but at fill speed in the X direction, it resonates super loud. It'll wake me up if I'm printing overnight.
My Y-axis got really noisy for a bit, but I printed and installed this: ytensioner and I tensioned it to what I felt was appropriate, and the noise went away. (Great part, difficult to assemble/install)
I also had to put foam in between the Y-bearing carriages and the aluminum plate (I actually used ear plugs cut in half). The printed carriages are not perfect and put twist into the aluminum plate when tightened completely. I placed the foam and tightened the screws until the distance between the O.D. of the bearings and the top of the aluminum plate were within 0.002". I also had to increase the size of the clearance holes in the printed carriages for the same reason. The screws were so tight in the holes, that they created a bind in the assembly when tightened.
I'm thinking of installing this to tension X appropriately: xtensioner but I'm not sure I like the design yet. I think it needs a slot for the stock bolt for more stability.
The only other thing is that it doesn't come close to the advertised max print height. Like someone else said, it's max is somewhere around 145mm.
The better (more accurately) set up the machine is, the better it will print!
Thanks for the response/reassurance that its not just my printer that's loud. I am very greatful that we have such great people in the community and i have been giving back as much as I can. That was actually me who said that 140mm was the "comfortable max" and 145mm was the absolute max. I have an x axis tensioner in my print queue that i am waiting on my abs spools in the mail for. I dont think that will help much though as the vibration seems to be coming from the motor on the x axis. I will probably use some foam board cut to size for now. But i will eventually make a 3d model to be printed in ninja flex and then upload it for you all. I also have found some lm8uu printable bushings that look. Good as well a nce half the noise comes from the bearings.
Also i saw where they m recommended using one zip tie and it makes sense. But i haven't tried it yet.
On a side note, i am confident in my ability to get my printer printing well at this point and have learned a lot through trying to help other people out that i think my next priority is cable chains and quietness. I may also be condensing current information on known issues and fixes, along with current upgrades.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 10:42AM |
problems with laying down PLA July 06, 2015 12:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 12:26PM |
robodog
I am very pleased with my new 2020 i3 printer. There is an issue with the X axis logistics. When homing the X axis, my print head would travel about 10 MM and then declare that it had hit the home switch even though it was a great distance from it. I believe that the head actually travelled away from the end stop switch when "detecting" home. On this forum, I read many solutions of others who were having similar issues and arranged to get a new RAMPS 1.4 to be sent to me, because all diagnostic tests pointed to a hardware issue on that board (like swapping X for Y - motor drive plug & end stop plugs only to have the problem migrate to the Y axis).
While waiting for the new RAMPS board, I did some additional fiddling to circumvent the cold solder joint (or whatever). I moved the X endstop plug from its prescribled location one set of pins towards the Y endstop plug (X-MAX position). This solved the problem, after changing the X-HOME printer configuration to MAX rather than MON. So I now have a functioning
HOWEVER .... I now have a printer that mechanically travels properly, 3 home commands work as expected BUT I have yet to be able to lay down any filament, after many hours of fiddling. I have tried two brands of PLA. Both behave in a similar fashion. With the head elevated above the table, with both heaters up to requirements, I can squirt a stream of liquid PLA out the nozzle using the manual command in Repetier-Host (hitting the up portion of that tool). When I attempt to print, no filament gets deposited. HELP!!!
How close to the table should the nozzle be when at elevation Z=0 MM. Should it be touching? I assume that there needs to be a gap of about 0.4 MM between the tip of the hot end and the layer below (or the table on the first layer). I have tried printing on glass, on wide masking tape and on wide Kapton tape. All produce the same results - nothing gets deposited. Any suggestions that you may have will greatly be appreciated. I'll even purchase a set of feeler guages, if that will help with establishing the proper Z axis position.
Bill
Re: problems with laying down PLA July 06, 2015 03:27PM |
robodog
Bill
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 06:11PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 08:04PM |
nonfish
Are you sure your extruder isn't turning the wrong way? When I set my printer up, the extruder direction was reversed, so it retracted instead of printing. Have you tried switching the polarity on the extruder motor?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 08:48PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 08:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 09:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 09:24PM |
robodog
Today is actually my birthday. That was a wonderful birthday gift. My first print went way better than anticipated. So now, it is time to play with the "head to table spacing" & some other parameters so that the remaining prints come out as best as can be expected.
Bill
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 09:43PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 10:09PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 10:36PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 11:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 11:06PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 11:30PM |
msaeger
I watched that video too but I figured it wouldn't hurt to try changing the value.
I think I will take the sections apart and check it out mechanically wise some more. The way the infill is diagonal to the shell makes me think maybe Y axis isn't perpendicular to the X.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2015 11:55PM |
animoose
I haven't seen any sign of it moving, but I did have some similar thoughts. I was wondering if you could mount the motor on one side of the X carriage and the rest of the mechanism on the other, to bring the center of mass closer to the x rods. I think it's possible, but then you'd need a longer shaft from the motor to the filament drive, and you would have to carefully lay it out so that it didn't interfere with the drive belt. It's beyond my design skill, I think.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 07, 2015 02:32AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 07, 2015 04:34AM |
arxidon
Does anyone know of a way to easily turn on/off the power supply? There doesn't seem to be any switch that I can see. I'm just asking because the extruder fan is continually on the way the guide says to wire it. I suppose the alternative is to wire the fan into the RAMPS board?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 07, 2015 09:19AM |
therippa
Speaking of auto-level (which is something that requires the updated firmware), I forked the latest release of Marlin and made all the Folgertech/Prusa changes to the configuration files. I just loaded it on my printer and everything works as expected. You can find it here.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 07, 2015 10:07AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 07, 2015 10:18AM |
wderoxas
It requires extra hardware which is a servo and a few settings to modify on the firmware to enable this feature as well as to set the correct offsets from the extruder tip to the z endstop. Basically, your z endstop will be relocated on the servo which is attached at the X carriage/extruder motor or wherever it can be practically placed. During bed levelling/calibration, the servo will extend and retract this z endstop on different calibration points of the bed to get the its plane. That's the gist of it. For detailed instructions, this Guide from Zenmaster was my reference.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 07, 2015 10:29AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 07, 2015 10:35AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 07, 2015 10:42AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 07, 2015 11:04AM |
