Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 02:46PM |
Mach
msaeger
Mach
So I just found out that Folger Tech came out with a new printer a month ago, thought anyone on it?
This one? [folgertech.com] I saw an ad for this one and didn't know if it was new or not.
That's the one.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 04:23PM |
It Looks to be a Replicator/Flashforge Creator clone.Quote
sonnylowe
Mach
msaeger
Mach
That's the one.
Love the look of that printer, I wonder what it's a copy of...also wonder how up-gradable it would be!?!?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 05:53PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 06:12PM |
watlooazn
Trying to print my first ever calibration cube.
When I load the 20 mm cube stl file into the repetier host, click slice, then click print. Nothing happens. All of a sudden the image of the cube disappears.
I can see the heat bed temperature rising but the extruder temperature doesn't rise at all (it does but very very slowly). I've already tested my extruder at 230 C so I know it works. But when I try to print an actual part, nothing happens.
My printer is supposed to home first and then start printing but it doesnt even do that. Does the reprap wait for the right temperature settings of the bed and extruder and then home and then print?
Am I missing any steps for trying to print my first part/cube??
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 06:13PM |
Kariko83
sonnylowe
Mach
msaeger
Mach
That's the one.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 08:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 08:51PM |
watlooazn
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 10:07PM |
Mach
msaeger
Mach
That's the one.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 10:35PM |
watlooazn
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 27, 2015 11:24PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 07:25AM |
john-i
I hope everyone had a wonderful Christmas!!
My 2020 I3 arrived and I have completed the mechanical assembly. I am having one problem, the bottom LM8UU bearings that I installed in step 10 on the right side that holds the Z carriage keeps falling out. The upper one stays in but the bottom one keeps dropping.... any suggestions?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 12:50PM |
tjnamtiw
Mach
msaeger
Mach
That's the one.
There are several things that excite me about the FT Clone machine. First all the parts that were printed are now injection molded, which should be a big improvement in accuracy and strength. Then in the pictures, it sure looks like there are Zerk fittings on the bearing holders, which would allow some real lubing of the bearings periodically. While the bed is narrower, it's much longer meaning, there are some parts that I could print that presently I can't. Since I'm a wood working hobbyist for most of my life, I'd have to go for the oak frame! Also, I see that they have upgraded to the 2mm pitch 8mm lead screws.
The only thing missing is auto bed leveling. Too bad Christmas is over!!!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 01:22PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 01:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 02:51PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 03:21PM |
lejohn91
Hi all,
I am very new to 3D printing and I recently purchased and assembled the FT Prusa i3. I have been running into an issue where I cannot get the printer to respond to ANY of the commands (stepper motors, extruder temperature, heat bed temperature, fan) in Repetier-Host. I am currently working in the manual control mode trying to calibrate the printer.
Some of the observations I've made are:
- Repetier-Host is able to get the temperature reading from the bed (i.e. if I touch the heat bed temperature sensor with my finger, I can see the temperature reading going up in Repetier-Host)
- When I give commands to the stepper motors, Repetier-Host's status shows "Idle" and my printer's LCD display reflects the amount of displacement I commanded (but there is no actual movement in the stepper motors)
So it looks like there's some sort of communication going on between the printer and the software, but I just cannot get the printer to actually respond to any of the commands I give. I am using the firmware that was given by FT via Google Drive. Please, any help would be appreciated as I've spent hours trying to troubleshoot and haven't come up with a solution.
Thanks!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 03:40PM |
Mach
seabass07
Anyone know if the single A4988 driver that runs both z axis motors can support two Nema 17's? Is that too much for a single driver?
I have never had a problem with it, so I guess it can.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 06:02PM |
tjnamtiw
lejohn91
Hi all,
Thanks!
Don't forget that you have to tell the printer to go HOME first. If it doesn't know where it is, it won't move away from where it knows HOME is.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 07:57PM |
Mach
seabass07
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 08:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 09:24PM |
watlooazn
Still trying to print my first calibration cube.
I load the part, slice, click print and now it's weird
I see my heat bed heating up but it took it 50 mins!! To reach 60 deg. After that it stopped heating up even thought it's supposed to reach 80 to print.
Maybe it's a bad solder job? My wires are solidly attached to contacts 1 2 and 3 on the bed. What could be the issue here?
Another key thing is that only the FRONT half of the bed (the side which faces me) heats up. The back half doesn't feel hot when I touch it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 10:13PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 28, 2015 10:18PM |
timbrady
Hello I just set up my new i3 and im having a problem. The x axis is only moving in one direction when i start to print, I've check all settings and wires multiple times. Anyone have a solution. Thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 29, 2015 11:54AM |
sonnylowe
tjnamtiw
sonnylowe
GrouchoDuke
I'm building my order list for a Folgertech 2020 i3 and I'm narrowing down the best auto leveling solution. From this thread so far, it looks like the most common thing to do is an 8mm-capable prox sensor with an aluminum bed (or foil or tape). There's some good hype out there for the BLTouch though. Has anyone used it? The reddit user "hoangsta82" raves about it, but he seems to be the only one.
So, what's the best solution out there? (assuming therippa's Marlin software)
Thanks!
I am currently running the BLtouch (yellow version), but if you've seen hoangasta82 post over on reddit you most likely know that already.
Where did you buy the BLTouch? From the promotion site or elsewhere? I haven't found it anywhere else.
You can purchase the White (updated) version directly from Charles, it's $33.00 shipped. I followed the instructions below. Charles was quick to respond and provided tracking info quickly as well. It took about 2 weeks to get here...
From the comment section of their Indigogo page
"Hello, everyone who are interested in BLTouch!
Since eBay's policy and we are beginner of eBay, it is very difficult to sell the products at eBay.
So while we finding the way to sell BLTouch at online shopping site, please send us an e-mail including the quantity, your address, zip code, phone number and name who want to buy BLTouch.
And, we are keep the retail price policy.
Price : $33
PayPal Account & E-mail adress : charlesleeok@naver.com
Thank you,
BLTouch Team"
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 29, 2015 11:58AM |
srcga
timbrady
I hate being this guy, but, you really need to read through the thread. It's been discussed quite a few times, even a page or two back.
It's worth reading and picking one of the many solutions, so long as you stick with one of the solutions (there are many correct ones). It'll give you some basic knowledge on the printer's movement and manipulating the firmware that is well worth it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 29, 2015 01:53PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 29, 2015 03:04PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) December 29, 2015 03:06PM |
