Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 02, 2016 09:03AM |
stanger2k
I looked over that pdf and it answered a lot of my questions.. and no, I thought i could wire the power directly to the bltouch, not that I have to pass the power it into the board which sends it back to the sensor. If all goes well, I should have some time to hook it up this weekend.
tjnamtiw
stanger2k
So I've bought a bltouch and I already have therippa's code, my x stop is on the left and I'm planning to cut a usb cable and power it from a powered hub that I'll also will run octopi from. What I'm having problems understanding is what is the process of setting the correct needle height? With the manual control not normally working to set the extruder higher if I need to?
To be honest, I don't know what you are asking. You MOUNT the BLTOUCH so that when the pin is all the way up, it is HIGHER than the nozzle and when it is DOWN, it is lower than the nozzle. You can adjust the height somewhat with the set screw in the top but that is not the preferred way because if you go too far, then you lose magnetic force to pull the pin up. I have no idea what you mean by "with the manual control not normally working to set the extruder higher if I need to?"
You say you are going to power the BLTOUCH with the USB CABLE from a powered hub but you do realize that you have to send that power to a spare set of servo pins on the RAMPS board, right? AND you have to remove the jumper that normally sends power to the pins, right?
Maybe you need to read [www.antclabs.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 02, 2016 09:07AM |
sonnylowe
BTW: I designed some magnetic mounts for my print glass...I love this upgrade, no more crappy binder clips in the way, well worth the effort!!!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 02, 2016 02:03PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 02, 2016 04:42PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 02, 2016 05:08PM |
iamquestar
Would anyone who is running the E3D v6 with a Bowden care to share your retraction settings?
I am struggling to get it right. I've played with a number of different distances and speeds, but have been unhappy with the results at the start/stop point of each layer. I don't have stringing, but it seems that I either have blobs, or caves (or both!). What I mean by a cave is a divot at that point, where, obviously nothing was actually extruded at the very beginning of the layer. It results in a groove all the way up the print.
I know settings will vary based on filament type and tube length, but I'm wondering what settings others of you are using?
Right now I'm regretting going to the bowden, and may return to direct drive. (of course, to do that, I'd have to print a new hot-end/extruder/sendor mount for the v-slot gantry, and print quality is questionable right now...)
--Andrew
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 02, 2016 05:19PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 02, 2016 05:41PM |
iamquestar
--Andrew
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 02, 2016 11:03PM |
sonnylowe
WOW...it's been longer than I thought since my last post...way back on page 132!!! I've been letting work get in my way ;-) I just wanted to stop by and catch up. Looks like a lot is going on, I'll have to read through the nine pages of post I've missed!!!
Even though I haven't been on thread much lately I have been answering PM's, so if you have any specific question for me or if I can help at all please feel free to PM me...I get an email notification which reminds me to check the thread...
I was requested to post my X-Axis Gen-2 files a while back which I did, so if anyone is interested in trying it out please check my Thingi Page I am very happy with the result of Gen-2, I am currently running both the X motor and extruder on the gantry with no issues at all. I did reduce the rapid travel speed a bit through S3D as it was chattering a bit while making those moves. now it nice and quiet again![]()
Therippa, have you seen or checked these out yet...might be another option for a control board upgrade!?!? I plan to use one on my latest printer build (see below).
ZeroPi
Raspberry Pi CNC Board
It's a bit off subject but here's my build SL Cantilevered 3D Printer I'm designing it to be as simple as possible and use as fewest (Quality) parts possible, currently it will be setup for PLA only as I've not included a heated bed...yet ;-)
Here's a quick peak...the link above has all the details.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 03:53AM |
tjnamtiw
sonnylowe
What a great idea! Why didn't I think of that. I use the darn magnets for everything else!!!! Quick change glass!!! Thanks!!!
This took several tries to get right, but again, I'm very happy with the results...|
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 03:59AM |
msaeger
sonnylowe
ZeroPi
The printer design looks neat similar to the printrbot metal simple and the same idea keep it as simple as possible. I like the extrusions over the smooth rods they use. It will be fun to see it get built.
I wonder if on the magnetic glass mount you could just place magnets on the top of the glass and get enough pull through the glass to hold it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 06:30AM |
stanger2k
tjnamtiw
stanger2k
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 09:31AM |
buffcleb
So I installed TMC2100's on the X&Y axis. If I lower the voltage below 1.15 I get a high pitch squeal from the Steppers... at this voltage the steppers run pretty hot... reading online I saw that running the TMV2100 off of 18 volts or higher could eliminate this.
So my question is can I just remove these two pins :
and the install pins on the top and run the motors off of a step-up board? then I can run 18v-24v on those two drivers and hopefully lower the output voltage...
next question is about the jumpers... reading more online I am confused. I have all the cfg pins (cfg1, cfg2 & cfg3) soldered to the tmc2100 and plugged into my ramps board, I removed all the jumpers. Is this the correct setup to get the 256 spreadCycle mode enabled?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 10:36AM |
buffcleb
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 11:18AM |
flatlander
buffcleb
The internet is a mess concerning these boards. One of the instructables (http://www.instructables.com/id/Install-and-configure-SilentStepStick-in-RAMPS-TMC/step5/All-done/) goes through elaborate instructions, then in the comments section, last paragraph, admits that the jumper pin instructions are wrong. The manufacturer suggests a protection standoff board (SilentStepStick Protector) with flyback protection for these boards. Good luck finding this part. They also have some elaborate recommendation for powering down the SilentStepStick to avoid damage to their tmc2100 board.
If I were going to give this a go, (unlikely) I would remove the cfgx pins from the SilentStepStick, and leave all jumpers on the ramps board in place.
[www.instructables.com] (seems more correct than the instructable above.)
I guess if you get a 24V power supply you could run your heaterbed at 24V, and get your heater current off the ramps board....
I got my stepper noise pretty quiet by running my VREF for the Y-axis at 0.4V and VREF for all other steppers at 0.160V. These are the Folger Tech - stock steppers, the y-axis rated 3V - 1.512V and all others rated at 12V - 0.4 A. I suspect that hoops you will need to jump through, to keep the torque high, will introduce squeal somewhere. Good luck, you are blazing your own trail. Do you have links to the stuff recommending higher voltage?
You have me curious about the actual voltage the stock motor windings "see'. If the sound ever got to me I would look at low-tech solutions such as acoustic soundproofing wedge tile.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 04:03PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 05:10PM |
UltiFix
Im wondering why I need to move my X axis endstop to the left for auto level? I upgraded to therippas firmware and it works fine on the right. After I upgraded my extruder got reversed, so I switched the motor plug.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 05:13PM |
UltiFix
Im going to upgrade to the rippas firmware and setup autolevel, why do I need to move my x endstop to the left?
EDIT:
I upgraded and it's working fine on the right...
After the upgrade the extruder is no longer extruding, did my extruder get reversed?
EDIT:
I think it's reversed, how do I fix that?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 05:58PM |
jhitesma
UltiFix
Because autolevel only knows how to calculate the plane of the bed when referencing from the front left as 0,0
If you're not using autolevel yet then therippas will work just fine with the endstop on the right (assuming you configure it for such)
But if you want to use autolevel you'll need it on the left or it won't be able to actually...autolevel.
Bert3D
UltiFix
EDIT:
EDIT:
You can reverse any of the stepper motors by taking the plug off the ramps board and turning over and plugging it back in.
Many, if not most, versions of the Marlin firmware have bugs that show up in autolevel with the endstop on the right. Putting it on the left eliminates the possibility of running into any problems related to this. This is because the code is developed and debugged on machines that all have an X-Min endstop (on the left) instead of the rather rare X-max endstop.
The normal Prusa i3 configuration is with the X-Min endstop, which means on the left. Folger is the only prusa type printer I know of that puts it on the right.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 10:47PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 10:48PM |
jhitesma
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 03, 2016 11:18PM |
Agedashi
I'm trying to upgrade to therippa's new version of marlin so I can get the full graphics LCD working. I'm porting my settings over but i noticed that the Z-Step value changed from 3840 to 4000. Which one should I be using with the original threaded rods?
Thanks!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 04, 2016 12:19AM |
Mach
Agedashi
Thanks!
4000
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 04, 2016 02:58AM |
Agedashi
Mach
Agedashi
Thanks!
4000
Thanks for the quick reply. Any reason for the change? I assume the default was 3840 previously... I don't recall setting it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 04, 2016 03:06AM |
sonnylowe
iamquestar
--Andrew
Andrew,
I ran a bowden setup for a very long time with great success, even with dual extruders running a Cyclops (retract is even tougher on that hotend). I think my retract was 4mm on the filament and 1mm retract in Z. What exactly is going wrong with your quality that you think adjusting the retract will help...maybe you can post a photo or two!?!?
Sonny
Edit: I didn't fully read the post...my bad. It sounds like more of an issue with the Teflon tube than your retract. If it were the retract I think it would be a consistent problem of stringing, blobs or missing filament at the start. With it being either one or the other of the latter two I think the tube might be sliding in the fitting a bit. I ran these little beauties on mine Bowden Clips...they definitely keep the tube in place. If you aren't using them already give them a try...they might do the trick!?!?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 04, 2016 09:34AM |
iamquestar
sonnylowe
iamquestar
--Andrew
Andrew,
Sonny
Thanks for the reply, I appreciate it. I don't think I was clear in my post . I'm not getting both issues at the same time, it just seems I can't find a happy medium. I'll try to post a pic in a couple days. I'm going out of town for the weekend and won't have a chance to do it before I leave. ( I sure wish I could figure out a way to take the printer vwith me...:-)
BTW, I'm going to print out and give those clips a try. Thanks!
-Andrew
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 04, 2016 04:57PM |
flatlander
I've felt 3d printer separation anxiety.
Are you keeping your PLA dry? I put my PLA in a jumbo freezer bag with a few containers of desiccant overnight. Blobs have mostly gone away for me after I started keeping my PLA dry. ( As long as I set my extrusion multiplier to 1.03 and not 103, ha, ha, ha. That poor little stepper was trying to to 103.)
I purchased some vacuum bags from Harbor Freight and will at some point employ them. That reminds me, I need to bake my silica gel at 220F for a few hours today.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 04, 2016 10:43PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 04, 2016 11:43PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 04, 2016 11:50PM |
buffcleb
flatlander
buffcleb
The step up power board I'm planning to use ( [amzn.to] ) only has 6a output so I'm not planning on running the heatbed as I assume even at 24v I would be over that... I'm dedicating this to the steppers...
I based the higher voltage off the silentStepStick FAQ I found : [github.com]
right now it runs and my Y axis is dead silent... my X is where I'm seeing issues... Like I said I think it might be the motor so I'm going to install on of the Y axis motors on my X axis when it gets here on Saturday...
the second link you provided (http://www.instructables.com/id/Vulcanus-V1-3D-Printer/?ALLSTEPS) leaves the motors in stealth chop mode... I was looking to get into spreadCycle mode which needs cfg1 being brought to ground... I added a wire jumper on the face of my X axis to do this... the Y axis seems fine with stealth chop mode... when I install the new stepper motors I may remove the jumper and see if there is enough torque
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 05, 2016 10:38AM |
