Re: Duet development news June 11, 2016 07:52PM |
dc42
drmaestro
I'd like to use the new duet however there are two problems. The first one is about PayPal. Unfortunately they had to stop their activities in my country due to licensing problems since the beginning of june. Are you going to offer another option for paying (credit card). The second problem is about customs. If the declared value is over 75 euros, the board is going to be examined by customs. While this is ok and I am willing to pay for the tax, anything related to 3d printing is considered to be an industrial item and I need to be a company to be able to pick it fron the customs. Is there a way to declare it under 75 euros?
I suggest you get in touch with ThinkDPrint3D - they will be taking payment and dispatching the boards.
Which country are you in?
Re: Duet development news June 13, 2016 11:22AM |
Re: Duet development news June 13, 2016 12:41PM |
Re: Duet development news June 14, 2016 04:51PM |
Re: Duet development news June 14, 2016 08:20PM |
uvarovkv
Hi David. Is there any news about the release date and final specs?
Re: Duet development news June 15, 2016 04:25PM |
Re: Duet development news June 15, 2016 04:39PM |
Re: Duet development news June 15, 2016 04:50PM |
Re: Duet development news June 15, 2016 05:07PM |
Re: Duet development news June 15, 2016 05:16PM |
uvarovkv
Wow! TMC2660 stepper drivers!
Re: Duet development news June 15, 2016 05:19PM |
roboprint
David, is there any chances that FTP will be supported again? How to edit Web UI files now?
Re: Duet development news June 15, 2016 06:26PM |
Re: Duet development news June 16, 2016 07:33AM |
Re: Duet development news June 16, 2016 08:43AM |
Re: Duet development news June 16, 2016 09:39AM |
Re: Duet development news June 16, 2016 12:36PM |
Re: Duet development news June 16, 2016 03:15PM |
deckingman
Should I be looking at anything special in the way of extruder stepper motors to take advantage of any of this? I'll shortly be ordering 3 off E3D titans (thanks for the idea DC42 although initially I thought they were too expensive) and I was just going add whatever steppers they (E3d) supply.
Re: Duet development news June 16, 2016 03:20PM |
sgawad
Just preordered
Is there a way to get X,Y,Z,E0,and E1 (enable, step and dir) out? That would require 15 extra connectors pins obviously or are the test points large enough?
I was thinking for my large build that if 2 amps are not enough I would get some gecko or such.
I guess it would be relevant at least for x, y and z since it's a delta that would mean a total of 3x3 connections and I guess this could be just the through holes pads, no need to actually solder a connector on the shipped version.
Sorry if it's a stupid question but, on the ramps... it's quite is easy to get access to those pins from the drivers sockets.
Re: Duet development news June 16, 2016 03:24PM |
dc42
sgawad
Just preordered
There is no easy way to get access to the signals for the on-board XYZ E0 E1 drivers. However, there are signals for the 5 additional stepper motors on the expansion connector. You can remap the XYZ signals to three of those if you want to use external drivers, and remap the on-board XYZ drivers to drive extruders.
We hope to push the current beyond 2A in the future, but it will require some firmware changes to control the driver temperatures.
Re: Duet development news June 16, 2016 03:47PM |
Re: Duet development news June 16, 2016 04:56PM |
Masterjuggler
Is it possible right now in firmware to have two or three z axes (think one lead screw centered at the back of the bed, one at each front corner), and have each with its own endstop? This way each z motor would home independently, but work in unison during the actual print. I've never really liked the probe and software compensation (limits you to a non-reflective surface, an make matters worse if you have a multi leadscrew setup and the motors gradually get out of sync, and puts the nozzle at an angle to the print surface), but would still like to have automatic bed leveling.
My setup right now consists of two motors in series to a single driver, and a single endstop with the four corner bed leveling. The problem with this is I have to worry about both the bed leveling and the motors running in sync at the same time. Of course this would require extra drivers on the expansion header.
Re: Duet development news June 16, 2016 05:00PM |
Re: Duet development news June 16, 2016 05:37PM |
T3P3
dc42
sgawad
Just preordered
Just to add, we have a customer experimenting with exactly this using the massmind THB6064 based drivers and the expansion header on the Duet 0.8.5. Once her has his setup up and running i am hoping he will publish more info.
Would there be interest in an expansion connector breakout PCB that made the 5 stepper drive signals available either for IDC compatible pin headers or Pololu style drivers?
Re: Duet development news June 16, 2016 05:57PM |
deckingman
Re: Duet development news June 16, 2016 06:09PM |
Re: Duet development news June 16, 2016 06:10PM |
dc42
sgawad
Just preordered
Re: Duet development news June 16, 2016 09:42PM |
Re: Duet development news June 17, 2016 02:15AM |
deckingman
Re: Duet development news June 17, 2016 02:39AM |
Re: Duet development news June 17, 2016 04:01AM |
dougal1957
I Would Echo the concerns with the Titan I put one on My delta and struggled with it to get a decent print without jamming/Stripping.
Went back to the original Mendel Mini extruder and issues disappeared I think the issue came down to the Length of the Bowden Tube (Mine is 800 mm long).
I think as the pressure builds up and the friction of the tube is just to much for the Titan to cope with it seems to lay down the first few layers ok but then starts to skip and then strips the filament unless I slow the whole printer down ie down to something like 25mm/s print speeds It normally runs nearer to 120 (and is capable of faster).
I haven't yet experimented with shorter tube as I am at the minimum really that I can get away with (Printer is 1 mtr tall with 500 mm sides)
on Smaller Deltas with more modest Bowden setups it may be OK.
Doug
