Prusa i3 Hephestos
Description | |
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Translation in progress. Please visit Spanish version.
http://reprap.org/wiki/Prusa_i3_Hephestos/es
- 1 Introduction
- 2 Galery
- 3 Thecnical specifications
- 4 Changes with respect to other models Prusa i3
- 5 Printed pieces
- 6 Bill of Materials
- 7 Assembly Guide
- 7.1 Required tools not included in the BOM
- 7.2 Preparation before assembly
- 7.3 Axis assembly
- 7.3.1 X Axis
- 7.3.1.1 Enter bearings
- 7.3.1.2 Prepare the tensor X Axis
- 7.3.1.3 Enter the X Axis tensor
- 7.3.1.4 Introduce smooth rod bearings
- 7.3.1.5 Prepare the X Axis Endstop sensor
- 7.3.1.6 Introduce the X Axis Endstop sensor in the smooth rod
- 7.3.1.7 Introduce the smooth rod in the side parts
- 7.3.1.8 Mount the X Axis motor
- 7.3.1.9 Introduce the adjustment screw for the X Axis Endstop
- 7.3.1.10 Introduce the pulley on the X Axis motor
- 7.3.2 Z Axis
- 7.3.2.1 Couple the motor hold on the frame
- 7.3.2.2 Couple the Z motors
- 7.3.2.3 Attach the top tether of smooth rods
- 7.3.2.4 Prepare the Z Axis Endstop
- 7.3.2.5 Union X Axis with Z Axis: Insert threaded rods
- 7.3.2.6 Union X Axis with Z Axis: Introduce smooth rod
- 7.3.2.7 Union X Axis with Z Axis: Union with X Axis:
- 7.3.2.8 Union X Axis with Z Axis: Flexible coupling
- 7.3.2.9 Union X Axis with Z Axis: Z Axis Endstop
- 7.3.3 Y Axis
- 7.3.3.1 Preparation of M10 threaded rod
- 7.3.3.2 Preparation of smooth rods
- 7.3.3.3 Union of smooth rods with threaded rods
- 7.3.3.4 Secure with nuts
- 7.3.3.5 Secure with flnages
- 7.3.3.6 Preparation of Y Axis tensioner
- 7.3.3.7 Preparation of Y Axis motor
- 7.3.3.8 Preparation of the threaded rods M8 - Part 1
- 7.3.3.9 Preparation M8 threaded rod - Part 2
- 7.3.3.10 Union of the rods
- 7.3.3.11 Secure with nuts the structure
- 7.3.3.12 Preparation of the aluminum base
- 7.3.3.13 Secure the base aluminum with flanges
- 7.3.3.14 Prepare the Endstop of the base
- 7.3.3.15 Secure the Endstop at the base
- 7.3.3.16 Place the belt of the Axis Y
- 7.3.3.17 Tighten all nuts
- 7.3.3.18 Place the methacrylate base
- 7.3.3.19 Prepare the Y Axis Endstop on the frame
- 7.3.3.20 Secure the Y Axis Endstop on the frame
- 7.3.3.21 Union Y Axis with the X and Z axes: Snap axes
- 7.3.3.22 Union Y Axis with the X and Z axes: Fit and tighten nuts
- 7.3.1 X Axis
Introduction
- Prusa 3D printer Hephestos is a free project 'designed and developed by the Department of Innovation and Robotics bq'. Hephestos is based on the Prusa i3 and adds several improvements learned from other printers as PowerCode users of the RepRap community, modifications to these parts and designs own department.
- This project has sought to offer a robust printer design that solves many of the shortcomings of earlier designs such as the subjection of the limit switches and cable routing. We have placed particular emphasis on providing good documentation to facilitate and more comfortable to the user installation and commissioning of the printer.
- The complete kit can be purchased from July 7, 2014 on the website http://store.bqreaders.com/es/diy/ 499 Euros with VAT in EU (European Union) Free shipping expenses.
Mounting Video (Youtube):
<videoflash type="youtube">eb74i006XIw</videoflash>
Galery
Dimensions
- -Dimensions printer: (x) 460 x (y) x 370 (without roll z) 510 (with roll z) 583 mm
- -Dimensions printer area : (x) 215 x (y) 210 x (z) 180 mm
- -Dimensions box: (x) 400 x (y) 400 x (z) 250mm
Mechanical
- -Frame aluminum base and powder coated
- -Bars X cars for hard chrome, Y, Z
- -Linear ball bearing LM8UU for X, Y, Z
- -Axial B623ZZ bearing pulleys balls for X, Y
- -Igus Energy Chains
- -Flexible Couplings threaded rods of Z axis
- -System level print base with 4 points and cushioning
- -System quick change print base with Clips
- -Fans brushless axial ball bearings.
Print resolution
- -Very high: 60 microns
- -High 100 microns
- -Media 200 microns
- -Low 300 microns
Extruder Mechanics
- -Extruder own
- -0.4mm nozzle
- -Sink fins with axial fan
- -Irrigation Nozzle Part
Print speed
- -Recommended speed: 50 mm / s
- -Maximum recommended speed: 80 mm / s
Electronics
- -1.4 Ramps
- -Mega 2560
- -Display LCD and rotary encoder with pushbutton navigation
- -Cold Base Glass size 220 x 220 x 3 mm
- -Power supply 220 AC 12 DC 100W
- -Thermistor 100k extruder
- -Heating element 12V 40W
Software
- -Firmware derivative Marlin
- -Recommended environment: Cura Software
- -Supported Files:. Gcode
- -OS supported:
- Windows XP and above
- Mac OS X and above
- Linux
Communications
- -Reader Standard SD cards
- -Port USB Type B
Materials
- PLA Filament 1.75-mm
- Limit switch clamping:
- Designed by the department specifically for this model.
- Belt tensioners
- Tensor X axis identical to the Power Code. Tensor Axis And http://www.thingiverse.com/thing:6818 downloaded from Thingiverse.
- Support for RAMPS
- Designed by the department specifically for this model. Includes three anchors to collect the wires on one side flanged.
- Support LCD
- Designed by the department specifically for this model. The design has been inspired by http://www.thingiverse.com/thing:121640
- Support Fan
- Chain Stitch
- Pieces modified to include the chain stitch on all axes, avoiding pinching, cuts and caught the cable axis movement.
- Power supply
- Pc power supply
- Extruder
- Witbox extruder.
- Frame
- Official modified Prusa. It has a recess in the Y axis area to prevent friction may exist once the leveling of the base if the screw protrudes. File:Frame&base Hephestos.dxf.zip
- Volume Printing
- 215x210x180 mm
Printed pieces
Thingiverse page: http://www.thingiverse.com/thing:371842
Own desings
X Axis coupling chain stitch
Piece Downloads File:Acople cadeneta Eje X.zip
Mechanical Endstop clamping X axis
Piece Downloads
File:EjeX final de carrera.zip
Mechanical Endstop clamping Y axis
Pieces Downloads File:EjeY final carrera marco.zip File:EjeY final carrera base.zip
Mechanical Endstop clamping Z axis
Piece Downloads File:Eje Z final carrera.zip
Hot End security
Piece Downloads File:Seguridad Hot end.zip
Tools
Piece Downloads File:Llave fija impresa archivos.zip
LCD support
Piece Downloads File:Soporte lcd.stl File:Bisagra lcd.stl
Fan support
Piece Downloads File:Soporte ventilador archivos.zip
Filament holder
Modified
X Axis carriage
- The original carriage will have made the following changes:
- -Attach to rewind Igus chain stitch at the top (above the bearings).
- -Addition of a small cap to ensure contact with the limit of X axis (on the side, next to the linear bearing carriage below)
Original Modified X Axis carriage (Power CODE) X Axis carriage (Hephestos) File:Eje X carro A archcivos.zip
Clamping the left Z Axis motor
- -Incorporated hitch chainstitch.
Original Modified Clamping the left Z Axis motor (Power CODE) Clamping the left Z Axis motor (Hephestos) File:I3-zbottom izq.stl File:Eje Z soporte inferior izquierda archivos.zip
End of the X Axis motor
- To provide robustness to the screw to adjust the height in Z.
- -The base is elongated and has reduced the looseness of the nut to prevent the screw from moving.
- -Has shifted the screw hole out to get a better accuracy in mechanical Endstop activation.
Original Modified X Axis left (Power CODE) X Axis left (Hephestos) File:EjeX izquierda.zip
RAMPS support
- They have added three hooks. Each hook allows through a bridle, hold and collect all the cables connected to the RAMPS. By guiding the cables through the side and into the plate at the top left corner promotes cooling of drivers having no cables above the sinks.
Original Modified RAMPS support (Witbox) RAMPS support (Hephestos) File:Suplemento RAMPS(original).stl File:Soporte RAMPS archivos.zip
Complete Kit
Complete Kit pieces to Hephestos:
Bill of Materials
Tools
Electronic
Extruder
X Axis
Y Axis
Piece Name Quantity
Chromed smooth rod 8mm x 340mm 2 Black threaded rod M10x370mm 2 Black threaded rod M8 x 205mm 4 M3 x10 Screw - DIN-912 8.8 Class Black 7 M3 x16 Screw - DIN-912 8.8 Class Black 1 M3 x20 Screw - DIN-912 8.8 Class Black 1 M3 x25 Screw - DIN-912 8.8 Class Black 6 M3 Nut - DIN 934 Class 8 Black 7 M8 Nut - DIN 934 Class 8 Black 22 M10 Nut - DIN 934 Class 8 Black 12 M8 Washer - DIN-125 Class 6 Black 22 M10 Washer - DIN-125 Class 6 Black 12 Y Axis B623ZZ bearing Pulley 2 Y Axis belt holder 1 Y Axis tensor B623ZZ bearing http://www.thingiverse.com/thing:68185 1 Y Axis motor 1 Y Axis Corner 1 Y Axis base Endstop 1 Y Axis frame Endstop 1 GT2 pulley (20 teeth) 1 LM8UU Linear bearing 3 Black bridle 100x2.5mm 11 GT2 belt 6mmx1m 1 Aluminum base 1 Methacrylate base 220x220x8mm holes 3.5mm 1 B623ZZ axial bearing 1 Spring (long: 30,5mm ; Outside diameter: 4,5mm; Wire thickness: 0.45mm) 4 Glass 220x220x3mm 1 Black Biinder Clip (35x10mm) 4 Black bridle 100x2.5mm 11
Z Axis
Assembly Guide
Prepare pulleys
- Materials Needed:
- Mounting:
Preparation of the motors
- Materials Needed:
- Mounting:
Embed nuts
- Materials Needed:
- 'Mounting:
- Parts to be embed with nut:
Preparation of motor cables
- Materials Needed:
- Cable length (from base of engine to end of connector)
Motor Total length (cm) Motor length (cm) Extesnion lenght(cm) X 85 30 55 Y 50 20 30 Z Right 45 15 30 Z Left 65 30 35
- Note: Cut four pieces of heat shrink tubing Motor wire 2cm long.
- Note: Prepare motors X and Y axes before mounting the engines and Prusa Z Axis after mounting.
- Mounting:
- Note: Before welding cables Z axis motors, pass the bare wire through the motor hole.
- Mounting:
Power supply cable preparation
- Materials Needed:
- Mounting:
Axis assembly
X Axis
Enter bearings
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- The objective of the tensor is load or unload a belt comfortably once set.
- Note: It is necessary to sand the pieces. The tensioner should slide perfectly with the piece that holds it.
- Mounting:
- Note: The two nuts are to be tightened in the end together. To do this with the aid of a nut wrench against the other, in this way it is achieved that these nuts are integral with the screw tightened. Now introducing the wrench as shown in the picture, a crank to slide linearly tensor is achieved.
- Note: With the help of the key nut and tighten nut to get a wing nut on the screw.
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- The length of the rod once joined in the side pieces, should be approximately 31 cm.
- Materials Needed:
- Mounting:
- Note: Orient the motor cable from the top.
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Note: Use the 2mm Allen wrench to tighten the pulley to the motor axis by the chamfered area.
Z Axis
- Materials Needed:
- Mounting:
Couple the Z motors
- Materials Needed:
- Mounting:
Note: Orient the motor cable to the frame
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Note: Paste with adhesive for plastics the step assembly 4 to the motor bracket.
Y Axis
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
Secure with nuts
- Materials Needed:
- Mounting:
Secure with flnages
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
Note: The 25 mm screw is used as shaft for the pulley and the 20mm screw for the tensioner.
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
Union of the rods
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Note: Turn the set
- Note: Tighten pulley with 2mm Allen wrench
- Note: Screw out screw to slacken the tensioner
- Note: Align belt
- Note: Tighten the belt tensioner bolt tightening
Tighten all nuts
- Materials Needed:
- Mounting:
- Note: It is necessary to file the burrs.
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
- Materials Needed:
- Mounting:
