Prusa i3 Hephestos
Revision as of 10:24, 1 July 2014 by Pedro de Oro Martín (talk | contribs) (Hello world: TuYour first print)
Prusa i3 Hephestos
Translation in progress. Please visit Spanish version. http://reprap.org/wiki/Prusa_i3_Hephestos/es
Introduction
Prusa 3D printer Hephestos is a free projectdesigned and developed by the Department of Innovation and Robotics bq. Hephestos is based on the Prusa i3 and adds several improvements learned from other printers as PowerCode users of the RepRap community, modifications to these parts and designs own department.
This project has sought to offer a robust printer design that solves many of the shortcomings of earlier designs such as the subjection of the limit switches and cable routing. We have placed particular emphasis on providing good documentation to facilitate and more comfortable to the user installation and commissioning of the printer.
The complete kit can be purchased on the website http://store.bqreaders.com/es/diy/.
Mounting Video (Youtube):
<videoflash type="youtube">nvTeJvRi8Bo</videoflash>
Galery
  • Thecnical specifications
    Dimensions
    -Dimensions printer: (x) 460 x (y) x 370 (without roll z) 510 (with roll z) 583 mm
    -Dimensions printer area  : (x) 215 x (y) 210 x (z) 180 mm
    -Dimensions box: (x) 400 x (y) 400 x (z) 250mm
    Mechanical
    -Frame aluminum base and powder coated
    -Bars X cars for hard chrome, Y, Z
    -Linear ball bearing LM8UU for X, Y, Z
    -Axial B623ZZ bearing pulleys balls for X, Y
    -Igus Energy Chains
    -Flexible Couplings threaded rods of Z axis
    -System level print base with 4 points and cushioning
    -System quick change print base with Clips
    -Fans brushless axial ball bearings.
    Print resolution
    -Very high: 60 microns
    -High 100 microns
    -Media 200 microns
    -Low 300 microns
    Extruder Mechanics
    -Extruder own
    -0.4mm nozzle
    -Sink fins with axial fan
    -Irrigation Nozzle Part
    Print speed
    -Recommended speed: 50 mm / s
    -Maximum recommended speed: 80 mm / s
    Electronics
    Any RepRap electronics conforming to RepRap Interface Standard RIS 1.
    -Display LCD and rotary encoder with pushbutton navigation
    -Cold Base Glass size 220 ​​x 220 x 3 mm
    -Power supply 220 AC 12 DC 100W
    -Thermistor 100k extruder
    -Heating element 12V 40W
    Software
    -Firmware derivative Marlin
    -Recommended environment: Cura Software
    -Supported Files:. Gcode
    -OS supported:
    Windows XP and above
    Mac OS X and above
    Linux
    Communications
    -Reader Standard SD cards
    -Port USB Type B
    Materials
    PLA Filament 1.75-mm
    Changes with respect to other models Prusa i3
    Limit switch clamping:
    Designed by the department specifically for this model.
    Belt tensioners
    Tensor X axis identical to the Power Code. Tensor Axis And http://www.thingiverse.com/thing:6818 downloaded from Thingiverse.
    Support for RAMPS
    Designed by the department specifically for this model. Includes three anchors to collect the wires on one side flanged.
    Support LCD
    Designed by the department specifically for this model. The design has been inspired by http://www.thingiverse.com/thing:121640
    Support Fan
    Chain Stitch
    Pieces modified to include the chain stitch on all axes, avoiding pinching, cuts and caught the cable axis movement.
    Power supply
    Pc power supply
    Extruder
    Witbox extruder.
    Frame
    Official modified Prusa. It has a recess in the Y axis area to prevent friction may exist once the leveling of the base if the screw protrudes. File:Frame&base Hephestos.dxf.zip
    Volume Printing
    215x210x180 mm
    Printed pieces
    Thingiverse page: http://www.thingiverse.com/thing:371842
    Own desings
    X Axis coupling chain stitch
    Piece Downloads
    Acople cadeneta Eje X.png File:Acople cadeneta Eje X.zip
    Mechanical Endstop clamping X axis
    Piece Downloads
    Sujecion para final X.PNG File:EjeX final de carrera.zip
    Mechanical Endstop clamping Y axis
    Pieces Downloads
    Sujecion para ele final Y marco.PNG File:EjeY final carrera marco.zip
    Sujecion para ele final Y base.PNG File:EjeY final carrera base.zip
    Mechanical Endstop clamping Z axis
    Piece Downloads
    Sujecion para final Z.PNG File:Eje Z final carrera.zip
    Hot End security
    Piece Downloads
    Seguridad Hot End.PNG File:Seguridad Hot end.zip
    Tools
    Piece Downloads
    Llave fija impresa render.PNG File:Llave fija impresa archivos.zip
    LCD support
    Piece Downloads
    Soporte LCD.PNG File:Soporte lcd.stl
    Bisagra soporte LCD.PNG File:Bisagra lcd.stl
    Fan support
    Piece Downloads
    Soporte para el ventilador.PNG File:Soporte ventilador archivos.zip
    Filament holder
    Piece Downloads
    Soporte filamento derecha.PNG File:Soporte filamento derecha archivos.zip
    Soporte filamento izquierda.PNG File:Soporte filamento izquierda archivos.zip
    Soporte filamento union.PNG File:Soporte filamento union archivos.zip
    Modified
    X Axis carriage
    The original carriage will have made the following changes:
    -Attach to rewind Igus chain stitch at the top (above the bearings).
    -Addition of a small cap to ensure contact with the limit of X axis (on the side, next to the linear bearing carriage below)
    Original Modified
    X Axis carriage (Power CODE) X Axis carriage (Hephestos)
    File:Eje X carro A archcivos.zip
    Clamping the left Z Axis motor
    -Incorporated hitch chainstitch.
    Original Modified
    Clamping the left Z Axis motor (Power CODE) Clamping the left Z Axis motor (Hephestos)
    Eje Z soporte inferior izquierdo Prusa i3.PNG Eje Z soporte inferior izquierdo Hephestos.PNG
    File:I3-zbottom izq.stl File:Eje Z soporte inferior izquierda archivos.zip
    End of the X Axis motor
    To provide robustness to the screw to adjust the height in Z.
    -The base is elongated and has reduced the looseness of the nut to prevent the screw from moving.
    -Has shifted the screw hole out to get a better accuracy in mechanical Endstop activation.
    Original Modified
    X Axis left (Power CODE) X Axis left (Hephestos)
    File:EjeX izquierda.zip
    RAMPS support
    They have added three hooks. Each hook allows through a bridle, hold and collect all the cables connected to the RAMPS. By guiding the cables through the side and into the plate at the top left corner promotes cooling of drivers having no cables above the sinks.
    Original Modified
    RAMPS support (Witbox) RAMPS support (Hephestos)
    File:Suplemento RAMPS(original).stl File:Soporte RAMPS archivos.zip
    Complete Kit
    Complete Kit pieces to Hephestos:
    File:Piezas Hephestos.zip
    Bill of Materials
    Tools
    Piece Name Quantity
    Llave Allen 2mm.png Allen key s/long Ø 2 UNIOR Ø 2 mm 1
    Llave Allen 2,5mm.png Allen key s/long Ø 2.5 mm 1
    Destornillador trimmer.PNG Ceramic screw driver trimmer for electronics. 1
    Aguja acupuntura.png Precision Needle 0.4mm diameter
    Llave fija impresa.png Printed spanner 10 (M6) - 13 (M8) - 17 (M10) 1
    Electronic
    Piece Name Quantity
    RAMPS 1.4 bq.png Ramps 1.4 1
    Stepsitck Drivers A4988.png Stepstick Drivers A4988 4
    Final de carrera PCB.png Endstop
    Panel de Control LCD.PNG LCD control panel 1
    Cable USB tipo B 1,8 metros.png USB cable (type B), 1.8 m. 1
    Cable motor Nema 17.png Motor wire Nema 17 4
    Cable para final de carrera.png EndStop wire with click and female connector 40 cm 2
    Cable para final de carrera.png EndStop wire with click and female connector 85 cm 1
    Motor Nema 17.png Motor Nema 17 4
    Kit de cables Extrusor.PNG Wire kit extruder (Motor wire Nema (with connector) + Thermistor wire with connector + Fan and blower wire + Heater cartridge) 1
    150mm de cable flexible de dos hilos bicolor sección 1mm^2.png 150 mm of flexible wire of two bicolor threads by 1 mm² 1
    Fuente 220 AC 12 DC 100W.png Power supply 220 AC 12 DC 100W 1
    Cable fuente de alimentación.PNG Wire 220AC (European) 1
    Soporte LCD bq.png Printed support for lcd 1
    Bisagra LCD bq.png Printed support for lcd 1
    Soporte para RAMPS.PNG Printed support for ramps 1
    Soporte ventilador RAMPS.PNG Printed support for fan 1
    Tornillo M3x10.png M3x10 Screw - DIN-912 Class 8.8 Black 4
    Tornillo M3x12.png M3x12 Screw - DIN-912 Class 8.8 Black 2
    Tornillo M3x16.png M3x16 Screw - DIN-912 Class 8.8 Black 2
    Tornillo M3x20.png M3x20 Screw - DIN-912 Class 8.8 Black 4
    Tuerca M3.png M3 Nut - DIN 934 Class 8 Black 12
    Tubo termoretráctil.png Heat shrink tube 2.5 x 500 mm 1
    Brida Negra.png Black bridle 100 x 2.5 mm 10
    Ventilador 50x50mm.png Brushless DC Cooling Fan - RD5010B12H with 20cm wire without connector 1
    C05I070078.png Adapter/connector Jack-Ramps 1
    Eslabón cadeneta recogecables Igus.png Plastic Drag Chain Link 15x35 mm 52
    Extruder
    Piece Name Quantity
    Extrusor Witbox.png Witbox Extruder ( direct extruder for 1.75 mm filament, with 0.4mm nozzle) 1
    Soporte Extrusor Witbox.png Extruder support 1
    Seguridad hot End.png Hot End security 1
    Tornillo M4x6.png M4 x 6mm Screw DIN-912 8.8 Class (with head for Allen 2.5mm) 2
    Tornillo M3x10.png M3x10 Screw - DIN-912 8.8 Class Black 2
    Tornillo M3x12.png M3 x16 Screw - DIN-912 8.8 Class Black 1
    X Axis
    Piece Name Quantity
    Varilla lisa cromada 8x370.png Chromed smooth rod 8mm x 370mm 2
    Tornillo M3x10.png M3x10 Screw - DIN-912 8.8 Class Black 4
    Tornillo M3x16.png M3x16 Screw - DIN-912 8.8 Class Black 2
    Tornillo M3x20.png M3x20 Screw - DIN-912 8.8 Class Black 2
    Tornillo M3x25.png M3x25 Screw - DIN-912 8.8 Class Black 1
    Tornillo M6x40.png M6x40 Screw - DIN-912 8.8 Class Black 1
    Tuerca M3.png M3 Nut - DIN 934 Class 8 Black 7
    Tuerca M5.png M5 Nut - DIN 934 Class 8 Black 2
    Tuerca M6.png M6 Nut - DIN 934 Class 8 Black 3
    Eje x Carro A.PNG X Axis Carriage A 1
    Eje x Carro B.png X Axis Carriage B 1
    Polea rodamiento.png X Axis B623ZZ bearing Pulley 2
    Eje X derecha.png X Axis Right 1
    Tensor rodamiento B623ZZ.png X Axis tensor B623ZZ bearing 1
    Eje X Izquierda.png X Axis left 1
    Eje X acople cadenenta izquierda.png X Axis left thread chain coupling 1
    Eje X final de carrera.png X Axis Endstop 1
    Rodamiento axial de bolas B623ZZ.png B623ZZ axial bearing 1
    Polea de 20 dientes para correa GT2.png GT2 pulley (20 theet) 1
    Rodamiento lineal de bolas LM8UU.png LM8UU Linear bearing 1
    Brida Negra.png Black bridle 100x2.5mm 1
    Y Axis
    Piece Name Quantity
    Varilla lisa cromada 8x370.png Chromed smooth rod 8mm x 340mm 2
    Varillas roscada.png Black threaded rod M10x370mm 2
    Varillas roscada.png Black threaded rod M8 x 205mm 4
    Tornillo M3x10.png M3 x10 Screw - DIN-912 8.8 Class Black 7
    Tornillo M3x16.png M3 x16 Screw - DIN-912 8.8 Class Black 1
    Tornillo M3x20.png M3 x20 Screw - DIN-912 8.8 Class Black 1
    Tornillo M3x25.png M3 x25 Screw - DIN-912 8.8 Class Black 6
    Tuerca M8.png M8 Nut - DIN 934 Class 8 Black 22
    Tuerca M10.png M10 Nut - DIN 934 Class 8 Black 12
    Arandela M8.png M8 Washer - DIN-125 Class 6 Black 22
    Arandela M10.png M10 Washer - DIN-125 Class 6 Black 12
    Polea rodamiento.png Y Axis B623ZZ bearing Pulley 2
    Eje Y sujeta correa.png Y Axis belt holder 1
    Eje Y tensor rodamiento B623ZZ.png Y Axis tensor B623ZZ bearing http://www.thingiverse.com/thing:68185 1
    Eje Y motor.png Y Axis motor 1
    Eje Y esquina.png Y Axis Corner 1
    Eje Y final carrera base.png Y Axis base Endstop 1
    Eje Y final de carrera marco.png Y Axis frame Endstop 1
    Polea de 20 dientes para correa GT2.png GT2 pulley (20 teeth) 1
    Rodamiento lineal de bolas LM8UU.png LM8UU Linear bearing 3
    Brida Negra.png Black bridle 100x2.5mm 11
    Correa GT2 6mmx1m.png GT2 belt 6mmx1m 1
    Base y marco i3.png Aluminum base 1
    Base de metacrilato.png Methacrylate base 220x220x8mm holes 3.5mm 1
    Muele base.png Spring (long: 30,5mm ; Outside diameter: 4,5mm; Wire thickness: 0.45mm) 4
    C05I070083.png Glass 220x220x3mm 1
    Binder Clip Negro (35x10mm).png Black Biinder Clip (35x10mm) 4
    Z Axis
    Pieza Nombre Cantidad
    Varilla lisa cromada 8x370.png Chromed smooth rod 8mm x 320mm 2
    Varillas roscada.png Black threaded rod M5x300mm 2
    Tornillo M3x10.png M3x10 Screw - DIN-912 8.8 Class Black 16
    Tornillo M3x18.PNG M3 x18 Screw - DIN-912 8.8 Class Black 2
    Tuerca M3.png M3 Nut - DIN 934 Class 8 Black 2
    Eje Z soporte superior.png Z Axis top support 1
    Eje Z soporte inferior derecha.png Z Axis right bottom support 1
    Eje Z final de carrera.png Z Axis Endstop 1
    Eje Z soporte inferior izquierda.png Z Axis left bottom support 1
    Acoplamiento flexible de aluminio de 5 a 5 mm.png Flexible coupling aluminum 5 to 5 mm 2
    Base y marco i3.png Black aluminum frame 1
    Assembly Guide
    Required tools not included in the BOM
    Piece Picture
    Soldador y estaño.png Welder and tin
    Mordaza.png jaw
    Lima metal.png Metal lime
    Tijeras.png Scissors
    Preparation before assembly
    Prepare pulleys
    Materials Needed:
    Piece Name Description Quantity
    Rodamiento axial de bolas B623ZZ.png LM8UU Linear bearing -       1
    Polea rodamiento.png Polea Eje X y Eje Y rodamiento B623ZZ Pulley       2
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Preparation of the motors
    Materials Needed:
    Piece Name Quantity
    Lima metal.png Metal lime       1
    Mordaza.png Jaw       1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Embed nuts
    Materials Needed:
    Picure Name
    Soldador.png Welder
    Tensor rodamiento B623ZZ.png Piece
    - Nut
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Parts to be embed with nut:
    Picture Detail Picture Name Nut Quantity
    Eje X derecha.png Code Xend Idler A M6 TUERCA M5.png X Axis Right M5 Nut - DIN 934 Class 8 Black 1
    Eje X Izquierda.png Code Xend Motor Tornillo modificadoV2 TUERCA M3.png X Axis left M3 Nut - DIN 934 Class 8 Black 1
    Eje X Izquierda.png Code Xend Motor Tornillo modificadoV2 TUERCA M5.png X Axis left M5 Nut - DIN 934 Class 8 Black 1
    Tensor rodamiento B623ZZ.png Code Xend Idler B 623 M6 TUERCA M3.png X Axis tensor B623ZZ bearing M3 Nut - DIN 934 Class 8 Black 1
    Eje Y tensor rodamiento B623ZZ.png Y-idler-tensioner3-3mm TUERCA M3.png Y Axis tensor B623ZZ bearing M3 Nut - DIN 934 Class 8 Black 1
    Eje x Carro A.PNG CarroX con cadeneta girado TUERCA M3.png X Axis Carriage A M3 Nut - DIN 934 Class 8 Black 2
    Soporte ventilador RAMPS.PNG Soporte ventilador Tuerca M3.PNG Fan support M3 Nut - DIN 934 Class 8 Black 2
    Soporte ventilador RAMPS.PNG Soporte ventilador girado 2 TUERCA M3.png Fan support M3 Nut - DIN 934 Class 8 Black 2
    Y EndStop base.png Y EndStop base TUERCA M3.png Y Axis base Endstop M3 Nut - DIN 934 Class 8 Black 1
    Seguridad hot End.png Seguridad Hot End embutir.PNG Hot End Security M3 Nut - DIN 934 Class 8 Black 1
    Preparation of motor cables
    Materials Needed:
    Picture Name Quantity
    Cable motor Nema 17.png Motor Nema wire 17 4
    Soldador y estaño.png Welder and tin 1
    Cable length (from base of engine to end of connector)
    Motor Total length (cm) Motor length (cm) Extesnion lenght(cm)
    X 85 30 55
    Y 50 20 30
    Z Right 45 15 30
    Z Left 65 30 35
    Note: Cut four pieces of heat shrink tubing Motor wire 2cm long.
    Note: Prepare motors X and Y axes before mounting the engines and Prusa Z Axis after mounting.
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Step G
  • Step H
  • Step I
  • Step J
  • Note: Before welding cables Z axis motors, pass the bare wire through the motor hole.
    Assembly:
  • Step A
  • Step B
  • Power supply cable preparation
    Materials Needed:
    Tijeras.png Scissors 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Step G
  • Axis assembly
    X Axis
    Enter bearings
    Materials Needed:
    Rodamiento lineal de bolas LM8UU.png LM8UU Linear bearing - 4
    Eje X Izquierda.png X Axis left Part of the left end of the X axis where will subject the said axis Nema 17 motor. 1
    Eje X derecha.png X Axis Right Part of the right end of the x axis is attached where the belt tensioner to said axis. 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Prepare the tensor X Axis
    Materials Needed:
    Tensor rodamiento B623ZZ.png X Axis tensor B623ZZ bearing X Axis belt tensioner where is housed together with the pulley axial ball bearing B623ZZ 1
    Preprarar poleas D.png Pulley Pulley mounted on the previous preparation 1
    Tornillo M3x20.png M3x20 Screw - DIN-912 8.8 Class Black 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Enter the X Axis tensor
    Materials Needed:
    Piece Name Quantity
    Eje X-Paso 1 C.png Assembly step 1 1
    Eje X-Paso 2 D.png Assembly step 2 1
    The objective of the tensor is load or unload a belt comfortably once set.
    Note: It is necessary to sand the pieces. The tensioner should slide perfectly with the piece that holds it.
    Assembly:
  • Step A
  • Step B
  • Step C
  • Note: The two nuts are to be tightened in the end together. To do this with the aid of a nut wrench against the other, in this way it is achieved that these nuts are integral with the screw tightened. Now introducing the wrench as shown in the picture, a crank to slide linearly tensor is achieved.
  • Step D
  • Step E
  • Step F
  • Note: With the help of the key nut and tighten nut to get a wing nut on the screw.
    Introduce smooth rod bearings
    Materials Needed:
    Piece Name Quantity
    Varilla lisa cromada 8x370.png Chromed smooth rod Ø 8mm x 370mm 2
    Assembly:
  • Step A
  • Step B
  • Prepare the X Axis Endstop sensor
    Materials Needed:
    Piece Name Quantity
    Final de carrera PCB.png Endstop 1
    Assembly:
  • Step A
  • Step B
  • Introduce the X Axis Endstop sensor in the smooth rod
    Materials Needed:
    Piece Name Quantity
    Eje X-Paso 4 B.png Assembly step 4 1
    Eje X-Paso 5 B.png Assembly step 5 1
    Assembly:
  • Step A
  • Step B
  • Introduce the smooth rod in the side parts
    Materials Needed:
    Piece Name Quantity
    Eje X Izquierda.png Assembly step 1 1
    Eje X-Paso 3 D.PNG Assembly step 3 1
    Eje X-Paso 4 B.png Assembly step 6 2
    Assembly:
    The length of the rod once joined in the side pieces, should be approximately 31 cm.
  • Step A
  • Step B
  • Mount the X Axis motor
    Materials Needed:
    Piece Name Quantity
    Motor Nema 17.png Motor Nema 17 1
    Eje X-Paso 7 C.png Assembly step 7 1
    Assembly:
    Note: Orient the motor cable from the top.
  • Step A
  • Step B
  • Step C
  • Introduce the adjustment screw for the X Axis Endstop
    Materials Needed:
    Piece Name Quantity
    Eje X-Paso 8 C.png Assembly step 8 8
    Assembly:
  • Step A
  • Step B
  • Introduce the pulley on the X Axis motor
    Materials Needed:
    Piece Name Quantity
    Assembly:
    Note: Use the 2mm Allen wrench to tighten the pulley to the motor axis by the chamfered area.
  • Step A
  • Step B
  • Step C
  • Z Axis
    Couple the motor hold on the frame
    Materials Needed:
    Piece Name Quantity
    Marco negro.png Black aluminum frame 1
    Tornillo M3x10.png M3x10 Screw - DIN-912 8.8 Class Black 6
    Assembly:
  • Step A
  • Step B
  • Couple the Z motors
    Materials Needed:
    Piece Name Quantity
    Motor Nema 17.png Motor Nema 17 2
    Eje Z-Paso 1 B.png Assembly step 1 1
    Assembly:
    Note: Orient the motor cable to the frame
  • Step A
  • Step B
  • Attach the top tether of smooth rods
    Materials Needed:
    Piece Name Quantity
    Eje Z soporte superior.png Z Axis top support 2
    Tornillo M3x18.PNG M3x18 Screw - DIN-912 8.8 Class Black 2
    Assembly:
  • Step A
  • Step B
  • Prepare the Z Axis Endstop
    Materials Needed:
    Piece Name Quantity
    Assembly:
  • Step A
  • Step B
  • Step C
  • Union X Axis with Z Axis: Insert threaded rods
    Materials Needed:
    Piece Name Quantity
    Eje X hephestos.png X Axis 1
    Varilla roscada M5x300mm.png Z Axis Endstop 1
    Assembly:
  • Step A
  • Step B
  • Union X Axis with Z Axis: Introduce smooth rod
    Materials Needed:
    Piece Name Quantity
    Eje Z-Paso 3 C.png Eje Z-Paso 2 B.png Assembly step 2 and 3 1
    Varilla lisa cromada 8mm x 320mm.png Chromed smooth rod 8mm x 320mm 2
    Assembly:
  • Step A
  • Step B
  • Union X Axis with Z Axis: Union with X Axis:
    Materials Needed:
    Piece Name Quantity
    Eje Z-Paso 6 B.png Assembly step 6 1
    Eje Z paso 5.PNG Assembly step 5 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Union X Axis with Z Axis: Flexible coupling
    Materials Needed:
    Piece Name Quantity
    Eje Z-Paso 8 A.png Assembly step 7 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Union X Axis with Z Axis: Z Axis Endstop
    Materials Needed:
    Piece Name Quantity
    Eje Z-Paso 8 A.png Assembly step 8 1
    Eje Z-Paso 4 C.png Assembly step 4 1
    Assembly:
    Note: Paste with adhesive for plastics the step assembly 4 to the motor bracket.
  • Step A
  • Step B
  • Y Axis
    Preparation of M10 threaded rod
    Materials Needed:
    Piece Name Quantity
    Tuerca M10.png M10 Nut - DIN 934 Class 8 Black 4
    Arandela M10.png M10 Washer - DIN-125 Class 6 Black 4
    [[File:|100px|]] M10 Washer -(Ø 30 mm) DIN-9021 Negra 4
    [[File:|100px|]] M10 Nut - DIN 934 Class 8 Black 4
    Assembly:
  • Step A
  • Step B
  • Preparation of smooth rods
    Materials Needed:
    Piece Name Quantity
    Varilla lisa cromada 8x370.png Chromed smooth rod Ø 8mm x 340mm 2
    Assembly:
  • Step A
  • Step B
  • Union of smooth rods with threaded rods
    Materials Needed:
    Piece Name Quantity
    Eje Y esquina.png Y Axis Corner 4
    Eje Y-Paso 1 B.png Assembly step 1 1
    Eje Y-Paso 2 B.png Assembly step 2 1
    Assembly:
  • Step A
  • Step B
  • Secure with nuts
    Materials Needed:
    Piece Name Quantity
    Assembly:
  • Step A
  • Step B
  • Step C
  • Secure with flnages
    Materials Needed:
    Piece Name Quantity
    Bridas negras 100x2,5mm x4.png Black bridle 100x2.5mm 4
    Assembly:
  • Step A
  • Step B
  • Step C
  • Preparation of Y Axis tensioner
    Materials Needed:
    Piece Name Quantity
    Preprarar poleas D.png Pulley 1
    Eje Y tensor rodamiento B623ZZ.png Y Axis tensor B623ZZ bearing 1
    Tornillo M3x25.png M3 x25 Screw - DIN-912 8.8 Class Black 1
    Assembly:
    Note: The 25 mm screw is used as shaft for the pulley and the 20mm screw for the tensioner.
  • Step A
  • Step B
  • Preparation of Y Axis motor
    Materials Needed:
    Piece Name Quantity
    Tornillo M3x10.png M3 x10 Screw - DIN-912 8.8 Class Black 3
    Assembly:
  • Step A
  • Step B
  • Preparation of the threaded rods M8 - Part 1
    Materials Needed:
    Piece Name Quantity
    Varillas roscada.png Varilla roscada negra M8 x 205mm 4
    Arandela M8.png M8 Washer - DIN-125 Class 6 Black 6
    Tuerca M8.png M8 Nut - DIN 934 Class 8 Black 6
    Eje Y-Paso 6 B.png Assembly step 6 1
    Eje Y-Paso 7 B.png Assembly step 7 1
    Assembly:
  • Step A
  • Step B
  • Preparation M8 threaded rod - Part 2
    Materials Needed:
    Piece Name Quantity
    Arandela M8.png M8 Washer - DIN-125 Class 6 Black 8
    Tuerca M8.png M8 Nut - DIN 934 Class 8 Black 8
    Eje Y-Paso 8 B.png Assembly step 8 1
    Assembly:
  • Step A
  • Step B
  • Union of the rods
    Materials Needed:
    Piece Name Quantity
    Eje Y-Paso 4 B.png Assembly step 5 1
    Eje Y-Paso 9 A.png Assembly step 9 1
    Assembly:
  • Step A
  • Step B
  • Secure with nuts the structure
    Materials Needed:
    Piece Name Quantity
    Eje Y-Paso 10 B.png Assembly step 10 1
    Assembly:
  • Step A
  • Step B
  • Step B
  • Preparation of the aluminum base
    Materials Needed:
    Piece Name Quantity
    Base de aluminio.png Aluminum base 1
    Tornillo M3x10.png M3 x10 Screw - DIN-912 8.8 Class Black 2
    Assembly:
  • Step A
  • Step B
  • Secure the base aluminum with flanges
    Materials Needed:
    Piece Name Quantity
    Eje Y-Paso 11 B.png Assembly step 11 1
    Eje Y-Paso 12 B.PNG Assembly step 12 1
    Brida Negra.png Black bridle 100x2.5mm 3
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Step G
  • Step H
  • Prepare the Endstop of the base
    Materials Needed:
    Piece Name Quantity
    Eje Y final carrera base.png Y Axis Endstop 1
    Assembly:
  • Step A
  • Step B
  • Secure the Endstop at the base
    Materials Needed:
    Piece Name Quantity
    Eje Y-Paso 13 H.png Assembly step 13 1
    Eje Y-Paso 14 B.png Assembly step 14 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Place the belt of the Axis Y
    Materials Needed:
    Piece Name Quantity
    Brida Negra.png Black bridle 100 x 2.5 mm 4
    Assembly:
    Note: Turn the set
    Note: Tighten pulley with 2mm Allen wrench
  • Step A
  • Step B
  • Step C
  • Step D
  • Note: Screw out screw to slacken the tensioner
  • Step E
  • Step F
  • Step G
  • Step H
  • Step I
  • Step J
  • Step K
  • Step L
  • Note: Align belt
  • Step M
  • Step N
  • Step Ñ
  • Step O
  • Note: Tighten the belt tensioner bolt tightening
    Tighten all nuts
    Materials Needed:
    Piece Name Quantity
    Assembly:
    Note: It is necessary to file the burrs.
  • Step A
  • Place the methacrylate base
    Materials Needed:
    Piece Name Quantity
    Tornillo M3x25.png M3 x25 Screw - DIN-912 8.8 Class Black 4
    Assembly:
  • Step A
  • Step B
  • Prepare the Y Axis Endstop on the frame
    Materials Needed:
    Piece Name Quantity
    Eje Y final de carrera marco.png Y Axis Endstop 1
    Assembly:
  • Step A
  • Step B
  • Secure the Y Axis Endstop on the frame
    Materials Needed:
    Piece Name Quantity
    Eje Y-Paso 19 B.png Assembly step 19 1
    Tornillo M3x16.png M3x16 Screw - DIN-912 Class 8.8 Black 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Union Y Axis with the X and Z axes: Snap axes
    Materials Needed:
    Piece Name Quantity
    Eje Y-Paso 18 C.png Y Axis 1
    EjeXZ.png XZ Axis 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Union Y Axis with the X and Z axes: Fit and tighten nuts
    Materials Needed:
    Piece Name Quantity
    Eje Y-Paso 21 B.png Assembly step21 1
    Assembly:
  • Step A
  • Extruder
    Prepare the carriage
    Materials Needed:
    Piece Name Quantity
    Assembly:
  • Step A
  • Step B
  • Place the carriage in the X axis
    Materials Needed:
    Piece Name Quantity
    Extrusor-Paso 1 B.png Step assembly 1 1
    Eje Y-Paso 21 B.png Prusa 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Secure the carriage with a flange
    Materials Needed:
    Piece Name Quantity
    Extrusor-Paso 2 B.png Step assembly 2 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Place the belt on the X Axis
    Materials Needed:
    Piece Name Quantity
    Extrusor-Paso 2 B.png GT2 belt 6mmx1m 1
    Extrusor-Paso 3 E.png Step assembly 3 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Screw the Extruder support
    Materials Needed:
    Piece Name Quantity
    Assembly:
  • Step A
  • Step B
  • Montar el Extrusor
    Materials Needed:
    Piece Name Quantity
    Extrusor Witbox.png Witbox Extruder 1
    Assembly:
    Note: This step is necessary to remove the nozzle of the extruder.
    Nota: Secure with screws the Extruder.
  • Step A
  • Step B
  • Step C
  • Placing the blower nozzle and Hot end security
    Materials Needed:
    Piece Name Quantity
    Tobera.png Blower nozzle of the Witbox extruder 1
    Assembly:
    Nota: The Hot end security is a opcional complement and no necessary for the correct printer working, but its use is highly recommended to avoid burns.
  • Step A
  • Step B
  • Step C
  • Place the glass on the base
    Materials Needed:
    Piece Name Quantity
    Assembly:
  • Step A
  • Step B
  • Step C
  • Electronic
    Place the RAMPS 1.4
    Materials Needed:
    Piece Name Quantity
    Tornillo M3x20.png M3x20 Screw - DIN-912 Class 8.8 Black 2
    Assembly:
  • Step A
  • Step B
  • Step C
  • Prepare the LCD control panel
    Materials Needed:
    Piece Name Quantity
    Soporte LCD bq.png Printed support for lcd 2
    Bisagra LCD bq.png Printed hinge for lcd 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Mount the LCD control panel on the frame
    Materials Needed:
    Piece Name Quantity
    Electrónica-Paso 2 D.png Assembly step 2 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • =Tuck the wires in the X Axis chain stitch
    Materials Needed:
    Piece Name Quantity
    Cadeneta.png Cadeneta 25 eslabones 1
    Cadeneta.png Cadeneta 27 eslabones 1
    Kit de cables Extrusor.PNG Kit cables para extrusor (Cable motor Nema (con conector) + Cable termistor extrusor con conector + Cable para ventilador y blower + Cable cartucho calefactor) 1
    Assembly:
    Note: Introduce the wires singly
  • Step A
  • Step B
  • Step C
  • Step D
  • Place the X Axis chain stitch
    Materials Needed:
    Piece Name Quantity
    Electrónica-Paso 5 A.png Cadeneta Eje X con cables 1
    Assembly:
    Note: The 25 shackle chain stitch link the X Axis carriage with the X Axis left.
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Introduce the Z Axis wires in to the Z Axis chain stitch.
    Materials Needed:
    Piece Name Quantity
    Electrónica-Paso 5 F.png Assembly step 5 1
    Assembly:
    Note: Introduce in to the Z Axis chain stitch the X Axis motor and Endstop wires.
  • Step A
  • Step B
  • Note: The 27 shackle chain stitch link the X Axis left with the Z Axis left bottom support.
  • Step C
  • Step D
  • Step E
  • Prepare the fan
    Materials Needed:
    Piece Name Quantity
    Ventilador 50x50mm.png Fan 50 x 50 mm 1
    Tornillo M3x16.png M3 x16 Screw - DIN-912 8.8 Class Black 2
    Assembly:
  • Step A
  • Step B
  • Wiring and cable routing
    Cable connection diagram
    Materials Needed:
    Piece Name Quantity
    Brida Negra.png Black bridle 100 x 2.5 mm 11
    Preparación del cable de la fuente G.png Power supply wire 1
    Extruder wiring
  • Step A
  • Step B
  • Step C
  • Note: Use a flange with the extruder wires.
  • Step D
  • Step E
  • Motors cable routing
    Note: Use a flange with the motors wires.
  • Step A
  • Step B
  • Endstop cable routing
  • Step A
  • Step B
  • Step C
  • RAMPS Wiring and cable routing
    Note: Use the flanges with the wires.
  • Step A
  • Step B
  • Step C
  • Note: Guide the cables through the printed piece that holds the RAMPS and secure them with the flanges.
    Note: Connect the clamp plate the fan cables and power supply.
  • Step D
  • Step E
  • Step F
  • Place the fan
    Materials Needed:
    Piece Name Quantity
    Electrónica-Paso 8 B.png Assembly step 8 1
    Assembly:
    Note: Disconnect the LCD panel control Ramps before placing the fan and pass it through the hole in the workpiece.
  • Step A
  • Step B
  • Step C
  • Placement the filament holder
    Materials Needed:
    Piece Name Quantity
    Soporte rollos.png Filament holder 1
    Assembly:
    Note: Disconnect the LCD control panel of Ramps before placing the fan and pass it through the hole in the workpiece.
  • Step A
  • Step B
  • Step C
  • Printer settings
    Z Axis adjustment
    Before printing with your printer you must calibrate the screw that adjusts the height of the Z axis so that the extruder is to the correct height of the base. To do this, follow these steps:
    -Put the same height ends of the X Axis. Thread each axis manually until both are at the same height.
  • Step A
  • -Tighten the set screw everything without possible forcing the piece.
  • Step B
  • -Use the LCD control panel to bring the extruder to home.
    Control > Move Axis > Auto home
  • Step C
  • Step D
  • Note: Make sure that the Endstops are being touching correctly by their respective axes.
    -Adjusts the position of the endstop sensor adjustment screw and repeat the previous step (bringing the Z axis to home).
  • Step E
  • -If the adjustment isn't correct, repeat the previous step.
  • Step F
  • Level plate
    Once Z Axis is adjusted, is necessary level the plate.
    Using the LCD control panel, start the leveling program.
    Control > Level plate
    The program moves the extruder at four points of the base, where you must adjust the screws on each corner, so that you can pass a sheet between the extruder nozzle and glass. Must feel the friction produced by the extruder in the paper passing therebetween.
  • Step A
  • Step B
  • Step C
  • Step D
  • Extruder obstruction
    If a blockage occurs in the extruder, follow the next step:
    You must hate the extruder at 220 ° C and insert the 0.4mm needle into the nozzle until you see it come out the other end. After you must clean the needle of adhered plastic.
  • Step A
  • Hello world: Your first print
    If you followed all steps of this manual, you should have your Prusa i3 Hephestos ready to do his first print!
    First you must laminate the 3D design. The 3D designs must be in .stl. For this, you can follow our guides for some used programs.
    Slic3r guide: https://www-cdn.bq.com/file/Witbox/Manual_Slic3r_ES.pdf
    Repetier-Host guide: https://www-cdn.bq.com/file/Witbox/Manual_Repetier_ES.pdf
    Cura 3D guide: https://www-cdn.bq.com/file/Witbox/Manual_Cura_ESP.pdf
    Note: Remember that Prusa i3 Hephestos area is 215x210x180 mm.
    Once you have the g-code file, save the file in a SD card. Insert the SD card in the LCD control panel slot. In main menu select "Print from SD". Now select your g-code file. The printer will start automatically. You can view the progress of the piece and the extrusion temperature from the LCD panel of the printer. When printing is completed remove the glass base by removing the clamps. With the base resting on a glass table parts removed by pulling them tight.
    You need apply lac on the glass for the correct adhesion of pieces!
