Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 19, 2013 09:41PM |
tjb1
So...anyone printing with an E3D should probably know the limit is 300c or the thermistor dies.
Here are a few SS of Repetier when the thermistor died. This happened while attempting to print polycarbonate at 300-310c.
Maybe update the product page to say that? The datasheet has a 300c limit on the thermistor so maybe it isn't wise to have an assembly step run it to 300c where it can easily overshoot if this is the first use.
The purple line is the set temperature, the fat orange one is the average and the red is what the thermistor is recording. The green graph at the bottom is the PID power to the hotend. As you can see, the red line started bouncing around and reporting temps as low as 170C and then you can see at the same time this caused it to dump full power into the cartridge.
Here is a picture of the hotend on the printer, no damage that I can see.
[www.dropbox.com]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 19, 2013 11:50PM |
jaydmdigital
Looking at the Kapton tape and how it turned black and knowing I've taken my hot end to 310C (overshoot for the toque procedure) and both thermistor and tape are fine...I would say you went well above 300C
tjb1
[www.dropbox.com]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 20, 2013 05:05PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 20, 2013 06:37PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 22, 2013 04:43PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 23, 2013 02:56AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 23, 2013 09:31AM |
I pre-ordered the kraken hot end, and Im very excited, I already have a water cooled hot end so I should be able to provide some useful feedback on it.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 23, 2013 04:48PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 02, 2014 05:03PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 02, 2014 06:00PM |
phord
There's an "extra" hole bored through the heater block. What's that for? Not the extra thermistor hole. I get that. But parallel to the heater element hole there is a small hole bored all the way through. Not sure what that is to be used for. Is that for a nichrome option?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 02, 2014 10:01PM |
Found a photo [www.3dprintedsculpture.com] - that guy used it as a strain relief.
I added some "Arctic Silver" heat transfer compound to the thermistor hole
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 03, 2014 12:10AM |
phord
I added some "Arctic Silver" heat transfer compound to the thermistor hole since I had some nearby for stepper driver heat sinks. I expect it should make the temp reading more responsive and accurate, but I'm sure it would also work fine without it. I didn't add any to the heater core hole since I'm not sure it can take the stress. But it's a thought.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 03, 2014 07:19AM |
phord
Got back from vacation and found my new E3D hotend waiting for me. Assembly was pretty easy, but I did hit a couple of snags.
1. The Epcos thermistor was replaced in October with one from Semitec with different specs. The documentation still refers to the Epcos model, though, so when I followed them my thermistor table values were all wrong. This could be dangerous, but I think it biases downwards. That is, I think using the Epcos values on the Semitech thermistor causes it to read higher than it really is. I thought I torqued the head on at 300C, but it was really only about 240C; but I haven't double-checked that.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 03, 2014 07:48AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 03, 2014 09:51AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 03, 2014 11:55AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 03, 2014 01:15PM |
uGen
@Ohmarinus: I am using a 1.75mm E3D v4 hotend. PLA and everything else I throw at it work like a charm (except of PC-ABS and PC at the moment, which still need some calibration). Not a single jam, although I frequently change filament with the most varying properties possible. However, I think I might use the 3mm system for my next printer as some materials like PP, PE, PVDF and PA6 are available as plastic welding rod in 3mm. Conversely, PC-ABS isn't readily available in 3mm for me. So it might be a good idea to support both filament sizes for now.
@Sanjay: Nice to see that you are now offering thermocouples, too. As someone else pointed out already, the PTFE insulation of this specific model is a limitation. Is there any chance that you will start to offer other types e.g. with glass fiber insulation in the future? Or for even better thermal contact something like the model Ultimaker is using? This kind of thermocouple might be a little bit more expensive, but I suspect some markup going on as their other parts are similarly expensive.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 03, 2014 02:10PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 03, 2014 06:32PM |
uGen
@tjb1: yes, I am aware that Ultimaker provides minimal information about their parts in their shop. However, their BOM on github reveals more (still, no operating temperatures. A search for the part number didn't return useful results.).
What I intended to say, though, is that E3D could look into selling thermocouples similar to the Ultimaker one as the form factor is better for thermal transfer between heater block and sensor. Also, it would be easier to fit without having to use Kapton or high temperature silicone, making the whole heater block assembly much neater and even more reliable (not that I had any problems with Kapton tape not holding the thermistor in place).
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 05, 2014 05:05AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 06, 2014 04:37PM |
anixie
Has anybody ever tried one of these hot ends on a Velleman K8200 ? (think not, search returned nothing...)
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 07, 2014 06:31AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 07, 2014 07:40AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 08, 2014 01:24AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 08, 2014 01:54AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 08, 2014 06:37AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 08, 2014 06:41AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 08, 2014 06:49AM |
Admin Registered: 11 years ago Posts: 1,063 |
uGen
Looks like quite a bit of over-engineering on Makerbot's side for just printing the standard stuff. They are practically encouraging their customers to print PLA designed their filament spool holders in a way that it would be rather difficult to fit spools from any other supplier on to. So high temperature filaments seem more or less not (yet?) to be the intended purpose for this hot end. Maybe the lower extrusion temperature for PLA contributes to the reason why they get away with a shorter heatsink.
I like the detachable design, though - some RepRap user already did that on his Prusa X carriage, so I wonder why we are not seeing more of this. No demand maybe?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 08, 2014 08:14AM |
uGen
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] January 08, 2014 02:41PM |
SanjayM
We are also looking at a super compact mini water cooled hotend, for just one nozzle. Might name it after some fast sea fish/animal. Marlin is already taken though, suggestions welcomed!
