Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 08, 2014 05:38PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 08, 2014 06:03PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 09, 2014 03:31AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 10, 2014 02:39PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 10, 2014 04:06PM |
Admin Registered: 9 years ago Posts: 3,096 |
ddseeker
SanjayM
We are also looking at a super compact mini water cooled hotend, for just one nozzle. Might name it after some fast sea fish/animal. Marlin is already taken though, suggestions welcomed!
Not sure if anyone gave any suggestions (I just scrolled back to see the side view image of the Kraken and noticed this)
W3D
Wahoo is the 3rd fastest fish in the world
(max. recorded speed of 78 kph)
this can also be a play off of Water Cooled E3D
maybe Wahoo sounds to silly and to close to yahoo, but it does give an aquatic breed theme to W3D
Note: Fastest fish is the Sailfish and 2nd fastest is the Marlin and those can't be used due to the firmwares, the link to 3 is cool too.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 10, 2014 04:12PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 10, 2014 05:27PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 10, 2014 06:30PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 10, 2014 07:39PM |
T3P3
I prefer to use axial leaded thermistors (like these) as they are more robust
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 10, 2014 07:53PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 11, 2014 12:27PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 11, 2014 12:58PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 11, 2014 01:49PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 11, 2014 01:54PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 11, 2014 01:56PM |
new to3Dbob
Wow, I can't imagine how it could get that hot. Mine is barly warm at the bottom fin. I had a jam during an overnight print and didn't notice until I checked on it the next morning. The drive gear stripped the filament trying to push it but nothing was blocked up near the heat sink. Maybe the fan stopped.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 11, 2014 02:04PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 11, 2014 04:06PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 11, 2014 10:30PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 12, 2014 11:47AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 12, 2014 11:53AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 13, 2014 02:51PM |
extent
If you have a separate mating surface in the heat block for the heat break then you have to torque it to make a seal, which will lead to people over torquing it and destroying the thin wall heatbreak. By mating the nozzle and the heatbreak inside the block you get all the sealing forces by torquing the nozzle against the heat block, both of which are much sturdier.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 13, 2014 03:14PM |
plexus
Either way you have to torque it together. using the current design, the filament entry of the nozzle butts up against the heat break tube. the nozzle is made of brass and the heat break is stainless. if you over torque then you risk deforming the brass nozzle. if the design of the heat block separated the nozzle from the break as I mentioned, then both components would not depend on the other for a good seal, it would also make nozzle changes much easier. I am still not seeing any benefits to th current design over my suggestion but then again what do I know..? I'm probably missing something, so perhaps a hot end designer can pipe in and let us know why the E3D design is superior.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 15, 2014 05:34AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 15, 2014 05:31PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 15, 2014 05:37PM |
AlexBorro
Guys, I've got my first clogged nozzle.
It is the 0.25mm version.. I could not push the filament through the hotend by hand.
I replaced the nozzle by the original one (0.4mm) and it worked like a charm.
So I drilled the clogged nozzle with a 2mm drill to remove all the plastic.. but I guess the small 0.25mm is clogged because even doing that, I cannot push filament...
Do you guys know any way to clean it??
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 15, 2014 09:27PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 15, 2014 10:20PM |
AlexBorro
After burning all the material inside the nozzle, I tried to pass a 0.2mm cooper wire through the hole, but no success.. it gets in about 1mm and then bends..,
Really difficult to clean theses nozzles.. It would be better if E3D provide us with a wire to clean the nozzle.. it is not that easy to find a 0.25mm diameter hard wire..
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 15, 2014 10:56PM |
AlexBorro
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 16, 2014 08:53AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() January 17, 2014 01:26AM |
