[Lots of pictures]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 01, 2014 10:10AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 01, 2014 10:12AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 01, 2014 10:25AM |
no it's the ground of the thermister port their talking about in other words one wire from the heater and one from the thermister. Try what I said plug it in but not attached to the machine or touching it make sure you didn't mix the wires between the heater and a thermister one of each in other words they have to stay as pairsQuote
cnc dick
Just check that the heater cartridge is not shorted to the metal on the cartridge. If I remember right solid doodle is all metal the original hot end was probably insulated from the machine with peak barrier. Try plugging it in and not attaching it to machine or touching it to the machine and see if it does the same thing. It is definitely something to think about for all of us who have all metal machines could be quite dangerous
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 01, 2014 10:32AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 01, 2014 02:59PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 01, 2014 03:16PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 02, 2014 08:45AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 02, 2014 09:05AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 02, 2014 09:19AM |
I do the same thing with every kind of hotend. I heat it up to roughly 80% or less of the normal extrusion temperature, then i pull out the remaining filament. This way you sometimes get the hotend completely clear or only very small remains. Afterwards i just feed in the new material.Quote
lions3
(Sorry, if this has been asked before.)
How are you guys handling changing filament types with this extruder? Do you have a different nozzle for each one? Do you just over heat the existing material and extrude it out with the new material? Anyway, just trying to figure out if I should order multiple nozzles if I want to print PLA, ABS, and anything else....
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 02, 2014 10:14AM |
Admin Registered: 18 years ago Posts: 7,883 |
Why would a board put power to something when not told to when it only does it with that specific heater?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 02, 2014 10:28AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 02, 2014 11:51AM |
you are right makes no sense the only thing I can think of is if he had a J head or something that was insulated electrically before and there is a chafed wire to the frame it would work okay. And if the new heater cartridge as a short two the metal part of the cartridge and because it is all metal is grounded would be the only possible thing that could be wrong. So sounds like two things are wrong it would have to be a shorted heater cartridge plus something else going to the frame. It's The only thing I can think of because he says he can plug-in is old hot end and it works. Unless there's a way for Mofset to go bad that I've never heard of with a certain amount of load to short out there either open or closed constantly when badQuote
nophead
I don't think it can. What you describe seems impossible.
Do you have a multimeter? If so measure the voltage accross the heater terminals before connecting the heater and after. If it reads zero with nothing connected and then goes to 12V with just the heater connected across the same two terminals then it breaks the laws of physics.
What happens if you connect both heaters in parallel?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 02, 2014 05:57PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 02, 2014 06:19PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 05, 2014 12:17PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 05, 2014 12:29PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 06, 2014 05:36AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 20, 2014 09:56AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 20, 2014 10:43AM |
s10blazed
Hi guys, I'm hoping someone out there can lend me some advice on how to fix my installation.
I started out with a 3DStuffMaker Evolution. I swapped in the E3D and used the stock carriage and wiring. Now my thermistor is reading strange and I cant find the reason why.
Here is my temp gauge from Repetier Host when I simply turn on the machine and open the program. I let it sit a few minutes without running anything to see how spiky the graph was at idle.
[attachment 33215 TempGraph-Idle.png]
Then I set the temp to 205 and let that simmer for awhile.
[attachment 33216 TempGraph-205.png]
Details:
Gen6 electronics
correct thermistor setting in firmware (#5)
Thermistor was originally seated with kapton tape.
After results above, I thought there was a contact problem so I sealed the hole with sodium silicate paste.(NO CHANGE)
Wires not routed with motor wires.
Soldered all connections
Wiring for hot end/thermistor is a shared 4 wire ribbon.
Tried 2 different power supplies.
Does anyone have any suggestions other than trying a different thermistor? I have a feeling I will need to do that in the future. I just am not looking forward to chipping out that paste and perhaps ruining the thermistor entirely.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 20, 2014 10:50AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] May 21, 2014 10:58AM |
s10blazed
I'll pull them apart along the length of the ribbon and see if it makes any difference. Would it still cause interference even if the heater is not active?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] June 26, 2014 04:23PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] June 26, 2014 06:00PM |
plexus
Has anyone with a v5 tried a v6? I use v5 and want to know if its worth the $100 to upgrade the relevant parts/nozzles to v6? (I am guessing not, but would like to know) specifically I am looking for data on print quality v5 vs v6. thanks!
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] June 26, 2014 06:07PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] June 26, 2014 06:43PM |
greenman100
plexus
The upgrade would be much closer to $60, since you can reuse the fan, heater, and thermistor. $61.46 from Filastruder, in fact.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] June 30, 2014 09:37AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] June 30, 2014 12:05PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] June 30, 2014 02:05PM |
Admin Registered: 17 years ago Posts: 1,472 |
MrDoctorDIV
I think he's due for a ban, other posts lead to spam pages placed oddly throughout his posts. Nothing subtle about it. But I'm no admin, nor do I claim real knowledge of things. Just what I see and what I think should be done.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] July 01, 2014 01:16AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] August 28, 2014 12:31AM |
drmaestro
Hi.
I'd like to ask a question about the length of the hot end. Is there a way to adjust it? I don't have access to my printer right now but it seems that my hot end might be longer than E3D and I am not able to mount a shorter one because the bearings are nearly at the ground level. I'd have to raise the heated bed and this would require longer bolts and springs. The reason for the height difference is a metal tube between the heater block and heatsink. I don't see this on E3D images (well there seems to be a similar tube on certain images but not on the final construction)
Thanks
