New print surface material? October 05, 2015 10:30AM |
Re: New print surface material? October 06, 2015 07:00AM |
Re: New print surface material? October 06, 2015 07:32AM |
Re: New print surface material? October 07, 2015 12:37PM |
Re: New print surface material? October 08, 2015 10:34PM |
Re: New print surface material? October 08, 2015 11:19PM |
Re: New print surface material? October 08, 2015 11:56PM |
Re: New print surface material? October 09, 2015 06:01AM |
Re: New print surface material? October 09, 2015 06:42AM |
Re: New print surface material? October 09, 2015 08:30AM |
gmh39
Do the parts unstuck so well that you could theoretically "swipe" your finished parts off with an arm remotely and print again?
Re: New print surface material? October 09, 2015 10:19AM |
Re: New print surface material? October 09, 2015 11:11AM |
Re: New print surface material? October 09, 2015 11:27AM |
Re: New print surface material? October 09, 2015 01:32PM |
Zedsquared
Thanks for the info! Have you tried tinsnips or aviation shears?
FYI: My bed is a spring-form baking tin base ( borosilcate ) and comes in at 230mm dia,
The standard for Kossel Mini seems to be 170mm to 180mm.
The actual printable dia of my bed is around 180mm.
Cheers,
Robin.
Re: New print surface material? October 09, 2015 02:13PM |
Re: New print surface material? October 09, 2015 02:47PM |
Re: New print surface material? October 09, 2015 07:37PM |
RGN01
Mutley, I currently have an aluminium heatbed with glass print surface held down with clips. Is there any reason I couldn't ditch the glass and stick the PrintBite straight onto the aluminium?
I sent you a similar query on a message from your site about an hour ago - but then thought it was possibly better to ask the question here so ignore that.
Thanks.
Richard
Re: New print surface material? October 10, 2015 03:58AM |
Mutley3D
RGN01
Thanks.
Richard
Hi Richard, Probably best to apply the printbite to the glass. Depending on the bed size we are only talking an additional 50-70 grammes. And glass is less likely to warp. Also easier to replace should anything get damaged.
BTW i think you might haqve just highlighted a minor issue on my mail server. Thx
Re: New print surface material? October 10, 2015 06:29AM |
Re: New print surface material? October 10, 2015 06:47AM |
RGN01
Mutley3D
RGN01
Thanks.
Richard
Thanks, but my problem is not adhesion as I have that sorted - I'm looking to get rid of the glass and the clips because this adds weight, restricts the available print bed size due to the clips, and adds the potential for the glass to move relative to the heat bed. By removing the glass and clips I will be able to get about another 25mm printable area in the Y axis.
What adhesive do you use on the printbite? Is it possible to peel it off and re-glue it? If so it would be worth trying on the aluminium.
Thanks.
Richard
Re: New print surface material? October 10, 2015 01:35PM |
Re: New print surface material? October 10, 2015 02:51PM |
Re: New print surface material? October 10, 2015 02:54PM |
Re: New print surface material? October 10, 2015 03:16PM |
Re: New print surface material? October 10, 2015 04:31PM |
Re: New print surface material? October 10, 2015 04:44PM |
Phytone
None of them, with my settings would "wipe off" when cool, ir room temp.
The flex print needed a fair tug to get off
The PLA print came off with a nice snap with minimal effort, but no swipe.
It needed the first layer to be fairly squished, I couldn't get a good first layer otherwise. Definitely no hairspray, or glue needed. To get it to swipe off when cool, is going to need some playing with, these are just the tests following this afternoons trial.
I'm sold - better than Kapton and hairspray. No more replacing tape!
Gives a nice finish too!
Oh = Richard, my tape stuck nicely to the aluminium bed and printbite. Its just cheapie stuff from B&Q, but yes is a bit of a pain to remove. I'm going to drill holes and bolt it down to my bed.
Re: New print surface material? October 10, 2015 04:50PM |
3DRapidClone
Im very interested in this for the fact to can adhere to nylon. How well can this adhere to nylon? And if you got around to circular discs I'd be all in .
Re: New print surface material? October 10, 2015 05:00PM |
Mutley3D
Phytone
Bolt down - Not sure I would go this route as the direct contact patch of the material, or lack of it without adhesion, may affect performance. You may have to increase temps significantly, although im not saying it wont work. Just take it into account if you do have adhesions problems after going to such an arrangement.
I'm not sure how using double sided sticky tape to fix printbite to my heated bed, is any different to bolting it to the heated bed. Or is there some chemistry which transfers heat through the sticky?
Thanks for the comments, will play more when the order comes through to see if I can reduce post print tack.
Re: New print surface material? October 10, 2015 05:57PM |
Phytone
Mutley3D
Phytone
Not quite sure either in honesty. In early testing it was quickly understood the material had to be stuck down good and proper, my bed heater hits 140+ no problems so it wasnt lack of heat that reduced adhesion performance. Heat could induce bowing into an unrestrained sheet since the top will be cooler than underneath.
As a supplier I have a "recommended usage" that I know works. I try to offer advice as the supplier aswell if people want to try something a bit different that might suit them better. Im happy to offer support in these cases aswell, but I keep to my fall back position of "recommended usage" which is a tested and known good usage.
Edited 1 time(s). Last edit at 10/10/2015 05:58PM by Mutley3D.
Re: New print surface material? October 10, 2015 06:20PM |
