Re: New print surface material? May 11, 2016 09:40AM |
Re: New print surface material? May 11, 2016 09:42AM |
leadinglights
I am about to try PrintBite on two of my printers but Anna & Karl's question about sensors made me think: Is PrintBite O.K. with brief contact with a hot end? The reason I ask is that I am using a piezoelectric sensor for bed leveling and Z contact detect [forums.reprap.org]
Contact force is less than 100 grams and duration is less than 20ms. With the hot end at 260°C and the bed at 115°C there is no visible trace left on Kapton tape.
Mike
Re: New print surface material? May 11, 2016 09:53AM |
I have one of dc42s sensors and I am delighted with it, but the Piezoelectric sensor is user transparent, it corrects for changed nozzles and beds without having to have a fudge factor entered. The Piezoelectric sensors also have no X or Y offset.Quote
Treito
I am using dc42 mini height sensor board with PrintBite. Works as good as a direct contact switch.
Re: New print surface material? May 11, 2016 11:30AM |
Re: New print surface material? May 11, 2016 12:45PM |
ElmoC
Anna & Karl
Does anyone have any indications how PrintBite behaves with capacitive proximity sensors? I am thinking about installing one and would be interested in your experiences. What about inductive sensors with aluminium under the PrintBite - would that be likely to work?
I would avoid using a capacitive sensor. They can be effected by temperature and humidity so are really not a good choice for 3D printers.
I used an inductive sensor with PrintBite. However, because of the thickness of the material (0.7mm IIRC), that reduced the height difference between the nozzle and sensor and I was having issues with the sensor catching on the part if the edge of the print curled up any. This was with the standard 4mm approach sensor. If you can use the 8mm version (it has a wider barrel), that should take care of the issue.
Re: New print surface material? May 11, 2016 04:19PM |
Re: New print surface material? May 13, 2016 12:18PM |
Re: New print surface material? May 13, 2016 01:41PM |
Re: New print surface material? May 13, 2016 01:59PM |
Mutley3D
Trhuster - what bed construction do you have there - looks like round magnets? My thought is simply regarding your true top surface temp - maybe you need to increase bed temp a touch more, sounds like you almost have the adhesion fully switched on. is your heater in direct contact with surface underneath.
Printing ABS at 290 is going to degrade/decompose the ABS if it actually is 290 - Are you 100% sure it is a real 290c, and not a temp calibration/thermistor issue going on there.
Re: New print surface material? May 13, 2016 02:27PM |
Re: New print surface material? May 13, 2016 02:31PM |
Trhuster
Mutley3D
The black spots are just some markings on heated plate. I have Printbite on a glass plate because no way it is flat all over if i put it on the heated plate directly. So yes we lose some heat there. My ir-temp reader says 96c when bed is set at 110c. Not sure how exact it is. The ABS i used at first Z-ABS and are made for high temp printing. Zortrax uses around 280c on their M200.
The one in the pic is total oppsite and needs low temp and i print it at 230c.
Re: New print surface material? May 13, 2016 02:38PM |
Mutley3D
Trhuster
Mutley3D
Yes good it is on glass plate which is recommended, for the reason you mention, flatness
OK so your some 14-15 degrees undertemp according to IR gun on the bed.
In your case I would advise printing the bottom layer on your low temp ABS at 245, then you can drop to 230 if you need to, but also increase the bed temp so your getting 110-120 on the bed surface.
No two machines are the same, so it is a case of dialling in. Your very close. As someone mentions above, if it doesnt stick, increase temps. Top surface temp is *important*, actually no, it is critical, to getting the good adhesion.
Re: New print surface material? May 13, 2016 02:48PM |
Re: New print surface material? May 13, 2016 03:15PM |
Re: New print surface material? May 13, 2016 03:22PM |
Re: New print surface material? May 13, 2016 03:45PM |
Re: New print surface material? May 14, 2016 04:32AM |
Re: New print surface material? May 14, 2016 05:35AM |
Origamib
I'm surprised people have issues with this stuff, I received mine a few days ago and tried it out for the first time last night and wow does it stick!
What I've noticed is that you need to level the bed slightly closer to get it to stick, normally I use gauges to level the hot end to 0.08mm away, but with this it's more like 0.06 is needed. I never liked the paper method, far too inexact.
Re: New print surface material? May 14, 2016 07:13AM |
Trhuster
Origamib
Many things can be different between users. Z-ABS is abit different to most other brands off ABS for one thing. What filament do you use?
Re: New print surface material? May 14, 2016 07:22AM |
Re: New print surface material? May 14, 2016 07:31AM |
Trhuster
I will start testing this in a better way. Using this warp test part. [www.thingiverse.com] I will post about my findings when i am done.
Re: New print surface material? May 14, 2016 04:00PM |
Re: New print surface material? May 14, 2016 05:10PM |
Re: New print surface material? May 14, 2016 07:02PM |
Re: New print surface material? May 14, 2016 11:39PM |
Re: New print surface material? May 15, 2016 02:06AM |
Mutley3D
MightyMouth - Nice work and great example!
Trhuster - Given your bed shuts off at 120 meaning you have to limit to 118, can you increase your temp limit in firmware? Sounds like you are just shy of the temp threshold as your top surface temp may be -10ish from thermistor reading
Origamib - looks like your bit of lift there is from where the edge of the heatbed is not as hot, or possibly even finger grease, but nice work also.
Comparisons to buildtak - a relatively soft material, with adhesion so severe it is common to damage the sheet during part removal - hence sold in multipacks. PrintBite targets a different approach, being extremely durable with the single sheet lasting the lifetime of the printer, fit and forget!
Re: New print surface material? May 15, 2016 02:14AM |
nebbian
I can see that those blue parts that Origamib is printing has quite a bit of this effect showing.
The recommendations above are to have the bed surface at 110-120 degrees for the first layer. What is the recommendation for subsequent layers? Are you supposed to then drop the temperature to 90 degrees? Or just live with the cave in?
Re: New print surface material? May 15, 2016 03:33AM |
Re: New print surface material? May 15, 2016 03:52AM |
Origamib
Can't say I've seen this problem? the pieces above are almost a finished print. they are just pegs to hold up tools on a pegboard.
Re: New print surface material? May 15, 2016 06:28AM |
nebbian
How are you guys combating the lower wall cave in you get with a high bed temperature when printing ABS?
I know that I need to have my bed surface at 90 degrees or lower to prevent this effect from happening (calibrated with thermocouple) on my printer with a PEI build surface. If I have it set to 95 or higher then the lower wall cave in effect starts happening. I normally print with the first layer at 95 for good adhesion, then subsequent layers are printed at 90 degrees. This is surface temperature, my thermistor is on the bottom so my printer thinks that it's set to 105 / 100 degrees.
