Re: New print surface material? July 01, 2016 04:59AM |
animoose
This is a question from idle curiosity: I can see why you would need to use a higher bed temperature with PrintBite (it's a bit more insulation between the heater and the surface), but why does the hot end need to be hotter as well? Shouldn't that just affect the viscosity of the extruded plastic?
Disclaimer: I am not a chemical engineer and probably talk nonsense about such things.
Re: New print surface material? July 01, 2016 05:27AM |
Re: New print surface material? July 03, 2016 06:26AM |
Re: New print surface material? July 03, 2016 10:41AM |
Re: New print surface material? July 03, 2016 11:58AM |
GrillSgt
@Mutley:
Are there any ideas how to remove the printbite surface from the heating bed? I don't want to damage the printbite. I've bought a new MK3 alloy printbed and want to use it on them.
GrillSgt
@all:
Can anyone share your experience printing PETG on the printbite surface?
Re: New print surface material? July 03, 2016 12:01PM |
Re: New print surface material? July 03, 2016 02:06PM |
Re: New print surface material? July 03, 2016 02:46PM |
Re: New print surface material? July 03, 2016 03:02PM |
Re: New print surface material? July 03, 2016 03:45PM |
Re: New print surface material? July 03, 2016 04:25PM |
Re: New print surface material? July 04, 2016 01:10AM |
DaveOB
Once you have the settings just right, and after using it for only a few prints, you'll be wondering how you ever printed without it.
This stuff is a total game-changer for printing. I used almost exclusively ABS for over a year and every single print just stuck and it worked as it should every time.
This was the best money I ever spent for my printer.
Re: New print surface material? July 04, 2016 03:02AM |
GRAYWOLF
DaveOB
My current settings are 230/100
How much will I need to alter it?
Re: New print surface material? July 05, 2016 03:45PM |
Re: New print surface material? July 06, 2016 01:42PM |
Re: New print surface material? July 08, 2016 07:05AM |
Re: New print surface material? July 08, 2016 01:21PM |
Re: New print surface material? July 09, 2016 12:20PM |
Re: New print surface material? July 09, 2016 04:08PM |
GRAYWOLF
One fail to hold print!
For some reason no matter what I try (printbite included) the Prusa i3 X-Axis tensioner will not stay stuck to the platform!
The part isn't ruined and is usable but some of the low layers are curved.
Apart from that, everything has stayed attached!
Re: New print surface material? July 10, 2016 06:55AM |
GRAYWOLF
Re: New print surface material? July 10, 2016 07:32AM |
Phytone
I find that once a week, a clean with acetone brings it back to full grip.
Origamib
Judging by that picture you posted, you have some major over extrusion problems. Try knocking back the flow rate by 10%, see what happens and then adjust it in increments up/down depending on the result.
In my experience, printbite doesn't like over extrusion, especially with ABS. PLA just merges together when overextruded, but ABS tends to ball up, which may be causing there to be too many gaps in the first layer, not giving a nice adhesion. A smooth, hot first layer to helps the print bond to the surface. So far I've had very few problems printing almost any shape with printbite.
Re: New print surface material? July 10, 2016 10:02PM |
Origamib
Re: New print surface material? July 11, 2016 04:48AM |
nebbian
Origamib
On the contrary, I believe the issue in that picture is too low nozzle height on the first layer. You can see that the parallel lines around the perimeter at the top of the print aren't squished together very well, which indicates that he is actually underextruding a tiny bit. I agree with you that the brim is way over-extruded, which in my experience is caused by a Z height that is way too low. I'd expect that it's at least 0.15mm too low judging by that picture.
To solve:
Raise your Z height by 0.1mm, try another print, then raise in 0.05mm increments until the brim is perfect. No need to print past the first layer.
Then when you're in the right ballpark, tune your extrusion factor until you get a solid top surface and retune the Z height.
Re: New print surface material? July 12, 2016 01:05AM |
Re: New print surface material? July 15, 2016 03:59PM |
Re: New print surface material? July 16, 2016 11:37AM |
Re: New print surface material? July 23, 2016 05:08AM |
Re: New print surface material? August 17, 2016 03:22PM |
Re: New print surface material? August 17, 2016 04:03PM |
Phytone
After going through PLA, ABS and PETG with great results - I'm trying Nylon (3DPrima Nylon)
Have cooked the Nylon for 10 hours in the oven to make sure it is dry, but every time the print gets more than 0.8mm thick, the darn thing lifts off the bed.
Have cleaned with Acetone - nope
Have put down a coat of hairspray - nope
Have put down a coat of PVA/water - nope
Have played around with nozzle heights, from well and truly squished to a nice bead - nope
Bed Temperatures between 70 - 100 deg - nope
Extruder temp is 250 and it comes out nice.
So can anyone share their setup for Print Bite and Nylon?
Thanks in advance!
Kevin
Re: New print surface material? August 17, 2016 05:29PM |
