Re: Precision Piezo Z-probe Now available. March 22, 2018 01:37PM |
Re: Precision Piezo Z-probe Now available. March 22, 2018 01:42PM |
Re: Precision Piezo Z-probe Now available. March 23, 2018 01:54AM |
Re: Precision Piezo Z-probe Now available. March 23, 2018 03:05AM |
// Speed for the first approach when double-probing (MULTIPLE_PROBING == 2) #define Z_PROBE_SPEED_FAST 400 // Speed for the "accurate" probe of each point #define Z_PROBE_SPEED_SLOW 400
#define X_HOME_BUMP_MM 5 #define Y_HOME_BUMP_MM 5 #define Z_HOME_BUMP_MM 2 #define HOMING_BUMP_DIVISOR { 2, 2, 1 } // Re-Bump
Re: Precision Piezo Z-probe Now available. March 23, 2018 08:13AM |
Re: Precision Piezo Z-probe Now available. March 23, 2018 08:33AM |
Re: Precision Piezo Z-probe Now available. March 23, 2018 02:22PM |
Re: Precision Piezo Z-probe Now available. March 24, 2018 04:20AM |
Re: Precision Piezo Z-probe Now available. March 24, 2018 04:33AM |
/ The number of probes to perform at each point. // Set to 2 for a fast/slow probe, using the second probe result. // Set to 3 or more for slow probes, averaging the results. //#define MULTIPLE_PROBING 2 // commenting out this disables bumping on probing
/ Homing hits each endstop, retracts by these distances, then does a slower bump. #define X_HOME_BUMP_MM 0 // zero disable bumping #define Y_HOME_BUMP_MM 0 // zero disable bumping #define Z_HOME_BUMP_MM 0 // zero disable bumping #define HOMING_BUMP_DIVISOR { 10, 10, 10 } // Re-Bump Speed Divisor (Divides the Homing Feedrate) //#define QUICK_HOME // If homing includes X and Y, do a diagonal move initially
Re: Precision Piezo Z-probe Now available. March 24, 2018 10:14AM |
Re: Precision Piezo Z-probe Now available. March 24, 2018 10:27AM |
Re: Precision Piezo Z-probe Now available. March 24, 2018 10:36AM |
Re: Precision Piezo Z-probe Now available. March 24, 2018 11:53AM |
Re: Precision Piezo Z-probe Now available. March 24, 2018 01:14PM |
Re: Precision Piezo Z-probe Now available. March 24, 2018 02:21PM |
Re: Precision Piezo Z-probe Now available. March 24, 2018 04:43PM |
Re: Precision Piezo Z-probe Now available. March 24, 2018 07:01PM |
Re: Precision Piezo Z-probe Now available. March 25, 2018 03:30AM |
Re: Precision Piezo Z-probe Now available. March 25, 2018 04:28AM |
Re: Precision Piezo Z-probe Now available. March 26, 2018 02:55PM |
Re: Precision Piezo Z-probe Now available. March 27, 2018 10:47AM |
Re: Precision Piezo Z-probe Now available. March 27, 2018 07:30PM |
Re: Precision Piezo Z-probe Now available. March 28, 2018 03:10AM |
Re: Precision Piezo Z-probe Now available. March 28, 2018 03:31AM |
Re: Precision Piezo Z-probe Now available. March 28, 2018 04:17AM |
Re: Precision Piezo Z-probe Now available. April 01, 2018 01:59PM |
Re: Precision Piezo Z-probe Now available. April 01, 2018 04:26PM |
Re: Precision Piezo Z-probe Now available. April 01, 2018 05:33PM |
DjDemonD
We haven't yet come up with a definitive solution for an original i3 mk2/3 machine mainly due to not having one to play with, but a mk1/1.5 rework type I3 can easily use the Piezo20 or the new Orion sensor, just insert it into the groovemount and insert the hotend into the sensor.
Re: Precision Piezo Z-probe Now available. April 02, 2018 03:41AM |
Re: Precision Piezo Z-probe Now available. April 02, 2018 03:50AM |
JoeK1973
DjDemonD
Sorry, how do you mean groove mount? The i3 rework (by emotiontech?} has a direct drive extruder (I think) - basically a single extruder body onto which the motor, inductive sensor, bearing, spring assembly etc all attach. This extruder body then bolts onto the x-carriage. Not sure which bit is the groove mount.
Great project by the way, seriously well done for getting it working as well as it obviously works.
