Re: LISA Simpson December 12, 2013 09:17AM |
Re: LISA Simpson December 12, 2013 09:50AM |
Re: LISA Simpson December 12, 2013 01:15PM |
Re: LISA Simpson December 13, 2013 10:43AM |
uncle_bob
Looking at growing the LISA in X and Y - the arms grow as roughly 2/3 the screw spacing if I read right in a post above. Taking that as an accurate number, for a 600 mm screw spacing one would need 400 mm arms. Those aren't going to print easily on a common printer. Even more so if you put a skirt / brim around them to keep things flat. I'd rather not go to a pair of printed parts mated in the middle with screws, my guess is that they would not be very accurate. Some sort of aluminum bar might work, printed parts plus thread rod might work, neither gets me real excited. Am I being overly concerned here?
Re: LISA Simpson December 13, 2013 11:30AM |
Re: LISA Simpson December 13, 2013 12:51PM |
nicholas.seward
Slight angular deflections can really add up.
nicholas.seward
Big machines will need serious members with solid joints.
nicholas.seward
Scale EVERYTHING proportionally.
Re: LISA Simpson December 13, 2013 02:36PM |
Re: LISA Simpson December 13, 2013 02:54PM |
Re: LISA Simpson December 13, 2013 03:14PM |
Re: LISA Simpson December 13, 2013 03:43PM |
Re: LISA Simpson December 13, 2013 04:15PM |
Re: LISA Simpson December 13, 2013 06:12PM |
Re: LISA Simpson December 13, 2013 07:37PM |
Dannydefe
Well, I ordered the screws today 7/16 steel , after talking to Roton they informed me that stainless steel was not available. I think the solution for me is to nickel plate for protection against rust. I can do this in my shop, it's actually quite easy.
I also inquired about the tap for the 7/16 -10 and they let me know that it was proprietary shape and that they were not going to sell it to us.
@ Nicholas I'm successfully printing part out but my question is how accurate do they have to be. The overall dimensions are good but it's very difficult getting the receptacles for the bearings to even get close to the proper diameter. (Always Undersized )
Re: LISA Simpson December 13, 2013 08:29PM |
Re: LISA Simpson December 13, 2013 09:28PM |
Re: LISA Simpson December 13, 2013 09:38PM |
The maximum difference in pitch for the two directions of travel is 2 %. We therefore recommend the use of positional sensors for positioning applications.
Re: LISA Simpson December 13, 2013 09:48PM |
Re: LISA Simpson December 14, 2013 03:45PM |
Re: LISA Simpson December 14, 2013 06:26PM |
Re: LISA Simpson December 14, 2013 06:30PM |
Re: LISA Simpson December 14, 2013 07:47PM |
Re: LISA Simpson December 14, 2013 07:54PM |
Re: LISA Simpson December 14, 2013 09:16PM |
Re: LISA Simpson December 14, 2013 09:18PM |
Re: LISA Simpson December 14, 2013 09:30PM |
Re: LISA Simpson December 14, 2013 09:32PM |
Re: LISA Simpson December 14, 2013 10:45PM |
Re: LISA Simpson December 14, 2013 11:16PM |
Re: LISA Simpson December 15, 2013 08:56AM |
Re: LISA Simpson December 15, 2013 09:42AM |
. It also seems to be compatible with the ABS epoxies. Back to the drawing boards for the end pieces.
