Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 07:13PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 08:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 01:28AM |
tadawson
How do you know you are at 80? Is that coming from Marlin, or are you reading it yourself? My first guess would be that your thermistor is defined incorrectly, or plugged in to the wrong port . . . . but neither of those would explain why you get a mintemp error (set at 5 by default) when the temp should be rising . . .
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 01:49AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 06:01AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 07:28AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 02:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 03:36PM |
tadawson
dc42 - Is there any chance that you can reply to *anything* here without whoring the damn Duet? Yes, it's an option, but it's not the only one, and it has nothing whatsoever to do with the question here, and I am really getting sick of the constant plugging. If you are trying to sell boards, please get a section in the vendor area . . . otherwise, please chill, OK?
tadawson
And duh, of course the motors are marked . . . but that won't tell me what *others* have, and frankly, short of taking one out of the printer, I can't see the markings on mine
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 03:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 04:10PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 05:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 05:37PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 06:01PM |
matthew900
I'm not sure what motors I have. I used the aluminum corners which will act as heat sinks so I'm not sure how much heat they are generating.
I have my steps at 80 and the z axis is coming out perfect. It is the horizontal plane in the x/y axis that's oversized. Which adjustments in the configuration will only impact the x/y plane without changing the z axis?
Thanks!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 06:04PM |
matthew900
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 06:34PM |
Koenig
matthew900
Thanks!
I'm in the same situation myself and I've found this: [delta-calibration.s3-website-us-west-2.amazonaws.com]
It also seems one of my towers is a bit off, my prints come out a bit skewed. I thought getting the aluminium-corners would help against this, how wrong one can be...
And still no heated bed above 90C, think this has something to do with the RAMPS (Duet underway)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 06:55PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 06:58PM |
tadawson
Koenig
matthew900
Thanks!
I can hit 110 on mine with ease in 6 or 7 minutes, and hold it indefinitely with the stock RAMPS. I was stuck at 100 before I insulated the bottom of the bed though . . .
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 07:44PM |
Koenig
tadawson
Koenig
matthew900
Thanks!
- Tim
Mine is insulated as well, but for some reason I get that error I described earlier and the printer shuts down and becomes non-responsive, 65C is no problem though so it's PLA only for now.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 19, 2015 09:26PM |
Koenig
When trying to heat up the bed I get this error when I reach about 80C:
"Error:MINTEMP triggered, system stopped! Heater_ID: 0
[ERROR] Error:MINTEMP triggered, system stopped! Heater_ID: 0
Error: Printer halted. kill() called!
[ERROR] Error: Printer halted. kill() called!"
Any ideas what it could be?
"Heater_ID: 0" isn't that the hotend? why do I get a mintemp triggered on that when the bed reaches 80C....??
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 20, 2015 01:20AM |
tadawson
Koenig
tadawson
Koenig
matthew900
Thanks!
- Tim
There are a lot of things that could be at fault on the temp error, but in my mind, the RAMPS card would be the last of them, since I don't recall any active components in the thermistor path. This almost has be be either a wiring or firmware configuration error . . . have you tried extending the MIN/MAX limits to see if it effects the problem? And even of there is a bad AtoD channel onyour Mega, you can reconfig to use T2 instead, and work around it.
The shutdown, for what it's worth, is Marlin acting as designed on a temp error . . . *that* in itself is not a problem, but rather a reaction to one.
You say you get the bed temp from Marlin/Pronterface . . . What is the extruder temp reading when all this is happening?
- Tim
I thought about this too, but wouldn't that report as the min_temp beeing triggered on "Heater_ID: 1" then?Quote
Ilamatrails
You could have a break in the thermistor wire(s) that is conductive when below 80C and not when above. When the system is off and cold, pull the thermistor from the RAMPS and meter it. Then run the system and meter the thermistor again after you see the error. Maybe meter it when the temp is about 60C to get a closer comparison.
Rick
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 20, 2015 02:13AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 20, 2015 09:36AM |
Koenig
Could be firmware as well.
"Heater_ID: 0" that is the extruders hotend right? agree on that?
It doesn't matter what temp the hotend is, I've tried having it at room-temp or heated to 235C (also read in pronterface, reported by marlin) but when the bed-temp reaches ~80C I get that error, sometimes before 80 sometimes after. Highest reading I got from the bed was 89.7C.
As a note I can add that the LED for the FET handling the heatbed is not acting well either, it goes out after a while when heating up the bed and never comes back on but the temp keeps rising, if heating the bed from room-temp to 110 it seems to go out at ~45C and never come back but the temp could still rise to ~80C.
Ilamatrails
Rick
Of course the firmware could poorly coded here and still report it as "Heater_ID: 0" even though the error is actually on "Heater_ID: 1"....
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 20, 2015 11:55AM |
llamatrails
Koenig
Ilamatrails
Rick
Check out this section of the Configuration.h file. It ties the 2 heaters together. Possible it is the heater thermistor that is pulling away from the heatbed, or the wiring is messed up? Maybe disable the protection to see.
//======================== Thermal Runaway Protection =======================
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 20, 2015 12:30PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 20, 2015 01:28PM |
tadawson
Crazy idea, but an easy test. I take it your electronics are under the bed, correct? Try laying the printer on it's side, and perhaps a small fan blowing at the RAMPS card, and see if it will heat. A bad solder joint set off by thermal expansion could cause your thermistor to glitch. If that works, edit pins.h and put the thermistor in question (E0) on the unused thermistor input. You might also try setting the MINTEMP values to 0 (not sure if negative values are alllwed) and see if it keeps heating.
For what it's worth, I am also on 1.0.3-dev, and use the runaway protection stuff, so unless there was a buggy moment in the dev tree, this isn't likely a firmware problem. If it is a bad RAMPS, Folger would have happily replaced it for nothing . . .
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 20, 2015 04:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 21, 2015 07:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 21, 2015 11:16PM |
cislom
So - one of my rails was terrible - no matter what I did the thing would bind up about 1/3 or the way up and ruined many a prints. I sent Dan at FolgerTech an email about it and he sent me a replacement (I love their customer service - They are responsive and there to help. A+) The one he sent me was better, but not "buttery smooth" as others have stated. I had even taken the suggestion of removing the small retaining wire that helped guide bearings around the track to see if it helped (it did a little, I think the rails need the groove cut in just a tad deeper). I use "super lube" on them and they seem to be working so far. Any tips or tricks on how to keep them happy? Are your rails super smooth, meh or crappy? Did I just get a bad bunch? Just wondering if they start acting up if there are other things I can do or should I replace them? There was mention of some new rails up a few post but taking a quick look it seems that those might put me back another $150 (which i wouldn't mind too much if it could guarantee the system would be like butter) I did buy the aluminum 2020 corners and carriage ends from RobotDigg (they are fantastic - BTW) so I already am in for a little more than base price, but I am having a blast (thanks mostly to the help here in the forums, otherwise I would be miserable).
Anyways - Thanks again!
- Mike
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 24, 2015 01:12AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 24, 2015 01:36AM |
