Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 09, 2015 05:45PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 09, 2015 09:11PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 09, 2015 11:09PM |
Sven.L
Thanks, König and DC42! :-)
What are the largest round heat beds available? I saw one with a diameter of 33 cm. Anything larger out there?
DC, can you post URLs for the items you purchased for the modified printer in your blog? I see some but not all. And what were the prices for the various items? What you did, is exactly the same thing I have in mind for my printer. But I also want to place my electronics on top, far away from the heat bed.
And I also need a URL where to purchases custom-sized acrylic glass. I am considering to build an attractive housing for the printer.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 09, 2015 11:55PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 10, 2015 12:32AM |
Sven.L
TheViseAd. thanks. It's about the heat bed? Do you have an e-mail for him? I am not located in the USA, that's why.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 10, 2015 02:36AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 10, 2015 07:41PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 12, 2015 05:34AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 12, 2015 09:12AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 12, 2015 12:14PM |
wrangellboy
I'm having a hard time getting my first layer z height nailed down. I've calibrated each tower and the midpoint and have flat movement after homing, but when I run autoprobe I get about 1mm of "slope" in my bed. Then when I print the extruder drags on the plate, every time. I've tried raising my z_manual_offset, but I don't think that's it since I'm auto-leveling. changing z probe offset seems to help, but I'm already at 0 and the comments in marlin config say to always use negative numbers. I'm running FST sensors and a johnsl board, and that has given me much more consistency in my probe numbers, but it didn't help at all with the head being to low after autolevel.
Any thoughts?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 12, 2015 12:21PM |
thevisad
wrangellboy
Any thoughts?
You have a couple of problems here, let's start by assuming you are still using the default Folgertech firmware. You should either roll your own or use a premade one such as mine with the settings you need in them.
1. Your slope on your bed indicates that your numbers are not correct. Here is how you check for your bed flatness and also assists in adjusting your bed. Assuming your end stops are correct, the bed is level (manually/[hysically leveled to the frame) and your using the proper firmware settings for your steppers.
a. Home your printer and place a piece of paper on your hot bed.
b. Turn on your hotend to your printing temperature.
c. Turn on your bed to your printing temperature.
d. Lower the bed until it "just pinches" the paper in between the tip and the bed. You should be able to slide the paper in and out, but have a "slight" drag on the paper. This indicates you are touching the paper at exactly the right height.
e. Look at your height, it should be relatively close to 0 + or - less then a mm.
f. Run your hot end in the X/Y positions by 50 mm in any direction and look for the height of the tip to be perfectly flat and maintain that drag on the paper. If it lowers or increases in height at all, follow this site until you have corrected it
2. If the tip touches the bed while printing then your Z height offset for the probe is incorrect so it is attempting to put the tip where it thinks it should be. Once your problem 1 is handled, you need to do the following.
a. Lower the servo (or whatever your using) until the probe is ready.
b. Lower the tip until the probe is activated by the bed.
c. Measure or read off the proper settings from your application and adjust the firmware and upload these settings.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 12, 2015 10:31PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 12, 2015 10:39PM |
wrangellboy
thevisad
wrangellboy
Any thoughts?
Thanks for the input. I'm using your firmware. I've done all the step 1 calibration you mentioned and everything looks good following those steps. It's not until after I do g29 that things get weird. I've been googling this morning and found some walkthroughs that show it being ok to use positive z probe offset values when you're using FSR's to lift the nozzle slightly above the bed. I'll try that when I get home.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 13, 2015 05:20AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 13, 2015 05:59AM |
Sven.L
Question: if I keep the rods long as they are now as delivered (Kossel 2020), without using the saw to cut them shorter, what printing area would I have, by diameter and height? Who can do these mathematics for me? Or, at least, provide me with the correct mathematical formulas so I can calculate by myself. Would be appreciated. Thanks.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 13, 2015 07:26AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 13, 2015 02:15PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 03:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 10:07AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 11:06AM |
SlowFoot
From what I understand the extruder that come with the kit is not the best one around. So what is?
I got a Mk7 and a Mk8 pulley, a reasonably working 3D.printer and a few kg of PLA.
Cheers!
Edit typo
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 11:27AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 01:49PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 01:52PM |
SlowFoot
Rattfink
thevisad
Eeee......extruder, not hot end. Other end of the bowden tube you know..
Thanks anyways
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 05:45PM |
thevisad
SlowFoot
Rattfink
thevisad
Thanks anyways
Doh!! i was reading that after waking up and didn't have a full cup of coffee in me. Yes! The extruder in this is junk, I think Tim pointed out a while ago it was designed to be on the hotend and pulling, versus pushing. I reworked this one a little and it works perfect for the job.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 05:49PM |
thevisad
SlowFoot
Cheers!
Edit typo
Nothing wrong with the hotend in this and unless you need to print something other then ABS/PLA (or higher then 235 degree) then there is no need to change it out. If you do need to change it out then you would want to use something like the e3d hot end or the budaschnozzle. These are the best hotends on the market. The primary reason is the removal of the PTFE tubing in the throat which allows the hotend to hit 400 degrees. You could do the same thing with the existing hotend by replacing the throat with a solid brass or stainless throat. I am waiting for my E3D hotend to come for my rebuild right now. It's one of the last pieces I need to complete the printer. As soon as that arrives I will wire up the hot end cable and I can start printing again on this. However, something to note, the existing hotend is not an exact duplicate of the e3d J head. The groove mount in the existing hotend is 5mm, in the e3d standard jhead it is 6mm. This means that the metal groove mounts will not work for the hotend that comes in this kit.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 06:52PM |
cman8
Thevisad, Mind sharing a pic of how you mounted your extruder to your frame?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 15, 2015 08:37PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 16, 2015 03:07AM |
thevisad
SlowFoot
Rattfink
thevisad
Thanks anyways
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 16, 2015 11:21AM |
cman8
thevisad
SlowFoot
Rattfink
thevisad
Thanks anyways
+1 On this rework. I downloaded and printed this design and works 10x better than the old extruder used to. Havent had any issues with it and prints are getting dialed in for sure. Between this and the dual fans on the hot end, everything is printing nice including overhangs which is what I was having issues with.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 16, 2015 03:32PM |
