Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level
Posted by Kasahabo
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level
February 10, 2016 06:28PM
So doing a G30 returns this value:
Z-probe:11.31 X:0.00 Y:90.00 zCorr:0.00
Is the Z-probe value what I put into the calculator?
(Sorry for all these questions about something that should be fairly straight forward. I have a lot on my mind recently.)
Owner of a QUBD Two Up
And
Folger Kossel 2020
And
Tevo Tarantula
February 10, 2016 09:12PM
paul_delta
How many 3-pin black-red-white extension cables do you have in your kit?
Only one.
February 10, 2016 09:32PM
I guess this is the cause of misunderstanding.
You need minimum two extension cables - one 3-pin to connect the servo to RAMPS (without changes, you need all 3 pins/wires) and one more 2 or 3 pin cable to connect the z-probe mechanical switch to RAMPS.
Sven.L
paul_delta
Only one.
Edited 1 time(s). Last edit at 02/10/2016 09:33PM by paul_delta.
My [www.thingiverse.com] stuff, my configuration of Repetier 0.92.6: [forums.reprap.org] (use Arduino 1.6.5 to compile)
February 10, 2016 09:42PM
PS: if you already modified 3-pin cable, use it for switch. For servo you will need 3 pieces of wire to extend the servo cable so it will be able to reach RAMPS from the highest Z position. Just cut the servo cable and solder 3 wires connecting two pieces to make servo cable longer. Make sure to connect the same colors and insulate joints carefully to avoid shorts.
Edited 6 time(s). Last edit at 02/10/2016 09:52PM by paul_delta.
February 11, 2016 08:24AM
NOW this all begins to make sense to me. But here is the problem:
Earlier this week, I tried already, for other purposes, to get any such cable with a 3-pin connector. I live in Jamaica, as a small island it has a small economy. No one here really deals with such things. I went to over 15 different shops, and could not get those things anywhere.
I feel desperate. But I wonder, if any of you could send me such a cable with the correct connectors on both ends. I would pay through my PayPal account. Is here anyone who would assist me that way?
February 11, 2016 05:40PM
After probing the bed over 7 points using dc42's calculator, i get the following results:
Z-probe:20.07 X:51.94 Y:61.00 zCorr:0.00
Z-probe:20.16 X:0.00 Y:80.00 zCorr:0.00
Z-probe:19.99 X:69.27 Y:40.00 zCorr:0.00
Z-probe:19.30 X:69.27 Y:-40.00 zCorr:0.00
Z-probe:19.66 X:0.00 Y:-80.00 zCorr:0.00
Z-probe:20.36 X:-69.27 Y:-40.00 zCorr:0.00
Z-probe:20.38 X:-69.27 Y:40.00 zCorr:0.00
Z-probe:20.01 X:0.00 Y:0.00 zCorr:0.00
If, from my understanding, I use the Z-Probe value as the nozzle height error, then calculate, the suggested new Z-home position is 250.38mm, which is almost 20mm more then what I could set it as without it hitting the bed when I manually set it. Am I doing this right? I feel like it's wrong.
And
Folger Kossel 2020
And
Tevo Tarantula
February 11, 2016 05:41PM
Sven.L
[alofthobbies.com] - I bought from them couple of times. They ship to Jamaica via USPS and accept Paypal.
February 11, 2016 05:52PM
I guess your initial height was 20mm. AFAIK the calculator normalizes errors and you can ignore proposed height and put your value, or check it experimentally. It will not affect the bed leveling.
PS: things to remember - z-probe returns the distance that probe traveled. So, if your initial height was 20 and z-probe returned 19.30 - it means that nozzle will hit the bed at this point if you will go to Z0. If z-probe returns 20.5 - the nozzle will be 0.5mm above the bed if you will go Z0. This is the most confusing part.
Captain_Tim
Edited 1 time(s). Last edit at 02/11/2016 07:00PM by paul_delta.
February 11, 2016 06:02PM
PS: so, for initial height 20, to get the value for calculator - just deduct 20 from z-probe value. For example for z-probe 20.5 you will fill 20.5-20=0.5 to calculator fot this point. For 19.3 you will fill the value -0.7.
Edited 2 time(s). Last edit at 02/11/2016 07:01PM by paul_delta.
February 11, 2016 06:13PM
Actually, with new 0.92.8 Repetier it's much faster to use distortion matrix output (G33 L0), as spiffcow described recently.
February 11, 2016 07:11PM
paul_delta
Where is it getting the 20 from? I was doing all these probe points with 5 as the Z value.
Also, I'm presuming that the Firmware type on the calculator should be set to Repetier? As that's what I'm using. Stupid question to ask, but I love to double check.
Edited 1 time(s). Last edit at 02/11/2016 07:14PM by Captain_Tim.
And
Folger Kossel 2020
And
Tevo Tarantula
February 11, 2016 07:23PM
Captain_Tim
From firmware settings. What is your z-probe height value? You have to home first, then go to Z5, for example, and measure with G30.
Captain_Tim
February 11, 2016 07:25PM
Captain_Tim
paul_delta
That's the distance at which your printer starts actively probing. There's a few settings that impact this, and it varies by firmware. On Repetier I believe it is something like MAX_ZPROBE_DISTANCE - ZPROBE_HEIGHT.
paul_delta
[attachment 72353 facepalm.jpg]
Best reply ever.
I must have been around Z20 last time I did it. I just did it with Z 5 and got the following results:
I must have been around 20 for Z when I did it. I just did it at Z5, with 10 points, and there are some big changes.
Z-probe:5.39 X:0.00 Y:85.00 zCorr:0.00
Z-probe:5.24 X:73.61 Y:42.50 zCorr:0.00
Z-probe:5.39 X:73.61 Y:-42.50 zCorr:0.00
Z-probe:11.31 X:0.00 Y:-85.00 zCorr:0.00
Z-probe:17.69 X:-73.61 Y:-42.50 zCorr:0.00
Z-probe:16.34 X:-73.61 Y:42.50 zCorr:0.00
Z-probe:11.18 X:0.00 Y:42.50 zCorr:0.00
Z-probe:8.49 X:36.81 Y:-21.25 zCorr:0.00
Z-probe:14.68 X:-36.81 Y:-21.25 zCorr:0.00
Z-probe:11.32 X:0.00 Y:0.00 zCorr:0.00
Should I home it after every point?
And
Folger Kossel 2020
And
Tevo Tarantula
February 11, 2016 07:27PM
My Z probe height is set to 0.900, which I've never changed, so I'm guessing it's the same as you.
And
Folger Kossel 2020
And
Tevo Tarantula
February 11, 2016 07:34PM
No need to home every time.
Your result are very strange... more than 12mm difference. I doubt that your printer is so uncalibrated, looks like missed steps.
Captain_Tim
paul_delta
Best reply ever.
February 11, 2016 07:35PM
paul_delta
What would you recommend for troubleshooting and fixing?
And
Folger Kossel 2020
And
Tevo Tarantula
February 11, 2016 07:36PM
PS: you have to measure your z-height and put exact value.
February 11, 2016 07:44PM
paul_delta
Measure the Z-height after I do a G30 at a probe point?
And
Folger Kossel 2020
And
Tevo Tarantula
Try to measure the same point three-four times:
G28
G1 X-70 Y-42 Z5
G30
Captain_Tim
paul_delta
February 11, 2016 07:52PM
Sorry, missed "z-probe". You have to measure z-probe height using firmware and put it in eeprom.
0.9 was my value, your value can be different.
Captain_Tim
paul_delta
February 11, 2016 07:54PM
To measure the Z-probe height, I slowly lower it to the bed until it picks up the bed?
And
Folger Kossel 2020
And
Tevo Tarantula
February 11, 2016 09:59PM
Captain_Tim
You could.. Or you could just adjust the Z height at the end by slowly lowering the effector until the paper no longer slides. It doesn't matter how high the probe is, as long as it doesn't slam into the bed. After you have your printer calibrated you shouldn't have to use the probe again unless you modify/repair the printer.
I used this script when calibrating with the probe:
G28
G1 X0 Y90 Z50
G30
G1 X77.94 Y45 Z50
G30
G1 X77.94 Y-45 Z50
G30
G1 X0 Y-90 Z50
G30
G1 X-77.94 Y-45 Z50
G30
G1 X-77.94 Y45 Z50
G30
G1 X0 Y45 Z50
G30
G1 X38.97 Y-22.5 Z50
G30
G1 X-38.97 Y-22.5 Z50
G30
G1 X0 Y0 Z50
G30
Reverse the sign of each probe result and put it in dc42's calculator.
I've been working on a utility to help with this.. I might post it tonight if I can verify it's working correctly (short on time, so no guarantees).
February 11, 2016 10:03PM
I did the calculator again, this time lowering my bed radius. These are the Z-Probe Values from Z5, a lot better.
5.09
5.12
4.49
4.57
5.06
5.12
5.12
4.99
5.09
4.99
And
Folger Kossel 2020
And
Tevo Tarantula
February 11, 2016 10:16PM
For anyone who is still using Marlin 1.0.0 from Folger Tech, here is a working Marlin 1.1.0 RC3 I updated to work with our printers.
[drive.google.com]
-EB
February 12, 2016 02:27AM
Captain_Tim
5.09
5.12
4.49
4.57
5.06
5.12
5.12
4.99
5.09
4.99
That's great! If you're running repetier you should now use G33 to map the bed height.. After which you should try printing something tall and something wide, just to make sure everything actually works.
February 12, 2016 06:59AM
Is there much difference? Do you know what's been updated? I still use Marlin as I can't get the Repetier software to install on my machine.
EvilBetty
[drive.google.com]
-EB
February 12, 2016 02:36PM
Paul,
I just checked them. The cable costs 1.85 US$. But they really try to charge me 50 US$ to Jamaica.
If I send such a cable inside a regular letter, I pay less that 2 US$ for it.
I think, I still have to hope, someone here could send me such a cable in a regular letter at regular fees, and I would pay with PayPal.
February 12, 2016 02:44PM
Sven.L
Paul,
What cable do you want can't wade thru the full thread to find it but I may be able to help?
Also what lengths do you need or if I can send you the bare ends / Crimps can you make them up yourself
Doug
February 12, 2016 11:19PM
Dougal, this one:
Heavy-duty Servo Extensions (22AWG)
It's a triple wire (24 or 36 inch long), and has on each end a 3-pin connector. Please see the photo.
This cable is available for around 2 US$, and can fit a regular letter envelope.
Maybe it's better, if it comes with these 3-pin connectors already. I am not experienced with electricity and electronics, and also don't have these special tongues that would be so beneficial for such clamp processing. I am too afraid to do something wrong, I admit. That's why I prefer the easiest way (idiot-proof for me). :-D
Edited 2 time(s). Last edit at 02/12/2016 11:22PM by Sven.L.
