Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 06:28PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 09:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 09:32PM |
Sven.L
Only one.Quote
paul_delta
How many 3-pin black-red-white extension cables do you have in your kit?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 09:42PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 08:24AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 05:40PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 05:41PM |
Sven.L
I feel desperate. But I wonder, if any of you could send me such a cable with the correct connectors on both ends. I would pay through my PayPal account. Is here anyone who would assist me that way?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 05:52PM |
Captain_Tim
After probing the bed over 7 points using dc42's calculator, i get the following results:
Z-probe:20.07 X:51.94 Y:61.00 zCorr:0.00
Z-probe:20.16 X:0.00 Y:80.00 zCorr:0.00
Z-probe:19.99 X:69.27 Y:40.00 zCorr:0.00
Z-probe:19.30 X:69.27 Y:-40.00 zCorr:0.00
Z-probe:19.66 X:0.00 Y:-80.00 zCorr:0.00
Z-probe:20.36 X:-69.27 Y:-40.00 zCorr:0.00
Z-probe:20.38 X:-69.27 Y:40.00 zCorr:0.00
Z-probe:20.01 X:0.00 Y:0.00 zCorr:0.00
If, from my understanding, I use the Z-Probe value as the nozzle height error, then calculate, the suggested new Z-home position is 250.38mm, which is almost 20mm more then what I could set it as without it hitting the bed when I manually set it. Am I doing this right? I feel like it's wrong.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 06:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 06:13PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:11PM |
paul_delta
PS: so, for initial height 20, to get the value for calculator - just deduct 20 from z-probe value. For example for z-probe 20.5 you will fill 20.5-20=0.5 to calculator fot this point. For 19.3 you will fill the value -0.7.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:23PM |
Captain_Tim
Where is it getting the 20 from? I was doing all these probe points with 5 as the Z value
Captain_Tim
Also, I'm presuming that the Firmware type on the calculator should be set to Repetier? As that's what I'm using. Stupid question to ask, but I love to double check.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:25PM |
Captain_Tim
paul_delta
Where is it getting the 20 from? I was doing all these probe points with 5 as the Z value.
paul_delta
[attachment 72353 facepalm.jpg]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:27PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:34PM |
Captain_Tim
paul_delta
Best reply ever.
I must have been around Z20 last time I did it. I just did it with Z 5 and got the following results:
I must have been around 20 for Z when I did it. I just did it at Z5, with 10 points, and there are some big changes.
Z-probe:5.39 X:0.00 Y:85.00 zCorr:0.00
Z-probe:5.24 X:73.61 Y:42.50 zCorr:0.00
Z-probe:5.39 X:73.61 Y:-42.50 zCorr:0.00
Z-probe:11.31 X:0.00 Y:-85.00 zCorr:0.00
Z-probe:17.69 X:-73.61 Y:-42.50 zCorr:0.00
Z-probe:16.34 X:-73.61 Y:42.50 zCorr:0.00
Z-probe:11.18 X:0.00 Y:42.50 zCorr:0.00
Z-probe:8.49 X:36.81 Y:-21.25 zCorr:0.00
Z-probe:14.68 X:-36.81 Y:-21.25 zCorr:0.00
Z-probe:11.32 X:0.00 Y:0.00 zCorr:0.00
Should I home it after every point?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:35PM |
paul_delta
No need to home every time.
Your result are very strange... more than 12mm difference. I doubt that your printer is so uncalibrated, looks like missed steps.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:44PM |
Captain_Tim
paul_delta
What would you recommend for troubleshooting and fixing?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:52PM |
Captain_Tim
paul_delta
PS: you have to measure your z-height and put exact value.
Measure the Z-height after I do a G30 at a probe point?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 07:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 09:59PM |
Captain_Tim
To measure the Z-probe height, I slowly lower it to the bed until it picks up the bed?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 10:03PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2016 10:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 12, 2016 02:27AM |
Captain_Tim
I did the calculator again, this time lowering my bed radius. These are the Z-Probe Values from Z5, a lot better.
5.09
5.12
4.49
4.57
5.06
5.12
5.12
4.99
5.09
4.99
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 12, 2016 06:59AM |
EvilBetty
For anyone who is still using Marlin 1.0.0 from Folger Tech, here is a working Marlin 1.1.0 RC3 I updated to work with our printers.
[drive.google.com]
-EB
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 12, 2016 02:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 12, 2016 02:44PM |
Sven.L
Paul,
I just checked them. The cable costs 1.85 US$. But they really try to charge me 50 US$ to Jamaica.
If I send such a cable inside a regular letter, I pay less that 2 US$ for it.
I think, I still have to hope, someone here could send me such a cable in a regular letter at regular fees, and I would pay with PayPal.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 12, 2016 11:19PM |
