Re: Ebay SINTRON Kossel Mini full kit March 17, 2016 10:13PM |
Re: Ebay SINTRON Kossel Mini full kit March 18, 2016 09:20AM |
Re: Ebay SINTRON Kossel Mini full kit March 18, 2016 10:08AM |
Electric ant
The way that these little strips have turned out is making me think I might have a chance of printing the plastic parts for my new RepRap Prusa i3
Apparently Cartesian printers are easier to set up than Delta's, so if I can print the plastics and get them something like, then I can put them on the i3 and print them again, and better, on the i3.
Re: Ebay SINTRON Kossel Mini full kit March 18, 2016 01:36PM |
Electric ant
I have finished making my led strip lights for my printer, and they have all turned out quite accurate considering my printer is no where near set up right.
It is on www.thingiverse.com
You can see some pics of them here
Re: Ebay SINTRON Kossel Mini full kit March 18, 2016 01:40PM |
Re: Ebay SINTRON Kossel Mini full kit March 18, 2016 02:45PM |
DRTak
Well slowly again, the Sintron Kossel is going to get replaced part by part. Today, I was printing and noticed oozing from the nozzle. I checked and the heatbreak tube and nozzle were loose. So I turned them with a wrench. Then under the pressure of just the heat and oozing PETG, the nozzle kept popping out. Bad news. I think I warped or ruined the aluminum heatblock. So now I have 2 choices. Buy a replacement heatblock and hope that it fits my nozzle and heatbreak throat tube or 2 just buy a whole new hotened.
Any ideas?
Re: Ebay SINTRON Kossel Mini full kit March 18, 2016 05:34PM |
Re: Ebay SINTRON Kossel Mini full kit March 18, 2016 10:28PM |
Re: Ebay SINTRON Kossel Mini full kit March 19, 2016 08:38AM |
nebbian
Most likely is that your steps per mm is wrong. This needs to be calibrated for your particular belts. GT2 belt is not exactly 2mm. You need to firstly get your frame 100%square, then measure carefully how far the carriages move, and adjust your steps per mm for each acis until the carriages move perfectly. Once this is done, and you've redone your endstops and delta radius numbers, you should get perfectly sized prints.
Re: Ebay SINTRON Kossel Mini full kit March 19, 2016 09:12AM |
Re: Ebay SINTRON Kossel Mini full kit March 19, 2016 06:06PM |
Re: Ebay SINTRON Kossel Mini full kit March 19, 2016 07:01PM |
Re: Ebay SINTRON Kossel Mini full kit March 20, 2016 03:49AM |
Re: Ebay SINTRON Kossel Mini full kit March 20, 2016 07:33AM |
Re: Ebay SINTRON Kossel Mini full kit March 20, 2016 03:42PM |
CrisCG
A valuable and logical explanation. Everyone can benefit from this. Thank you nebbian.
I also switched to a e3d v6 hotend. You get a bonus of 2cm extra build height with the v6, compared to the sintron hotend.
Re: Ebay SINTRON Kossel Mini full kit March 20, 2016 03:44PM |
DRTak
CrisCG
I thought the Sintron hotend was an e3d V6 clone? Is it e3d v6 lite?
Re: Ebay SINTRON Kossel Mini full kit March 20, 2016 07:21PM |
Re: Ebay SINTRON Kossel Mini full kit March 21, 2016 07:29AM |
Re: Ebay SINTRON Kossel Mini full kit March 21, 2016 08:14AM |
Re: Ebay SINTRON Kossel Mini full kit March 21, 2016 09:19AM |
Electric ant
My bed is mounted using 3x M3 nuts, the 3 small springs, 3x T-nuts and 3 of the supplied screws.
I have enough spring to cope with a small head crash and the M3 nut makes it easier to adjust than the square nut.
[attachment 75015 MK3SintronBed.jpg]
You could put a washer between the spring and the bed but I don't think it's needed.
I've lost count of how many different ways I tried to mount my bed, either permanent fit or removable, and this is by far the best way for mine. But there probably are better ways out there.
It has enough spring for that unexpected head crash and plenty of thread left for adjustments.
Hope this is of some use to you.
Ant
Re: Ebay SINTRON Kossel Mini full kit March 22, 2016 05:50AM |
thank you Electric ant ill try that, do you insulate the bottom on your heatbed?Quote
Electric ant
Ant
Re: Ebay SINTRON Kossel Mini full kit March 22, 2016 06:24AM |
forest
i bought a complete frame and heatbed hardly used that the guy was foxed by the large metal rod ends, and another sintron kossel in used bits that also beat the owner and he gave up with it , im building up a good one with the aid of the tips in this thread (which i thank you all for ) and my trusty 3dr delta , mine will be duet 0.6 powered does anyone have a working dc42's firmware that i could have a copy of please? that would save a bit of time for me
Re: Ebay SINTRON Kossel Mini full kit March 22, 2016 08:36AM |
Re: Ebay SINTRON Kossel Mini full kit March 23, 2016 09:48AM |
nebbian
Re: Ebay SINTRON Kossel Mini full kit March 23, 2016 04:24PM |
Electric ant
nebbian
I have done the Z axis and got it to 10.02mm carriage movement for every 10mm step on pronterface.
How do I do the X and Y axis ? these don't move like the Z axis. If you move the y carriage for example, the other 2 move as well.
How do I check if x and y are correct when the carriages don't move by the amount shown in pronterface.
Do I put a mark on the print bed and measure how far the head moves over the bed with a 10mm click ?
I think this is almost the last thing I need to do now before I get that (near) perfect print.
Ant
Re: Ebay SINTRON Kossel Mini full kit March 23, 2016 06:37PM |
Re: Ebay SINTRON Kossel Mini full kit March 23, 2016 10:39PM |
dc42
On a delta, the X Y and Z steps/mm should all be the same, unless you have any reason to suspect that your belts have different tooth pitches. Adjust the steps/mm of all three to get the correct height when you print a tall object. If you are using good belts, it should be extremely close to the theoretical value.
Getting the printed X and Y sizes correct is all about good machine geometry and having the correct diagonal rod length configured in the firmware.
Re: Ebay SINTRON Kossel Mini full kit March 24, 2016 03:07PM |
Re: Ebay SINTRON Kossel Mini full kit March 25, 2016 03:11AM |
Re: Ebay SINTRON Kossel Mini full kit March 26, 2016 09:19AM |
CrisCG
My Sintron effector warped as well. I got a ABS effector now, with the e3d v6 hotend.
