Re: Kossel Delta xxl build project HELP June 11, 2019 05:20PM |
Re: Kossel Delta xxl build project HELP June 11, 2019 11:42PM |
Re: Kossel Delta xxl build project HELP June 11, 2019 11:58PM |
Re: Kossel Delta xxl build project HELP June 12, 2019 12:12AM |
Re: Kossel Delta xxl build project HELP June 12, 2019 09:51AM |
Re: Kossel Delta xxl build project HELP June 12, 2019 04:42PM |
Re: Kossel Delta xxl build project HELP June 12, 2019 04:57PM |
Re: Kossel Delta xxl build project HELP June 12, 2019 06:04PM |
Re: Kossel Delta xxl build project HELP June 12, 2019 06:44PM |
Re: Kossel Delta xxl build project HELP June 13, 2019 12:35AM |
Re: Kossel Delta xxl build project HELP June 14, 2019 10:56AM |
dc42
In that case it sounds like either one of the LEDs or the series resistor has blown. Did you run the effector at 24V with the "on for 12V" jumper installed? If you did then the 604 ohm series resistor has probably blown. If not, then most likely one of the 3 LEDs has failed - which is unlikely but not impossible. The one with 12V or 24V across it is the one that has failed.
Re: Kossel Delta xxl build project HELP June 14, 2019 11:11AM |
Re: Kossel Delta xxl build project HELP June 14, 2019 03:05PM |
Re: Kossel Delta xxl build project HELP July 08, 2019 11:04AM |
Re: Kossel Delta xxl build project HELP July 18, 2019 09:40AM |
Re: Kossel Delta xxl build project HELP July 18, 2019 01:24PM |
Re: Kossel Delta xxl build project HELP July 18, 2019 05:27PM |
Re: Kossel Delta xxl build project HELP July 18, 2019 08:27PM |
Re: Kossel Delta xxl build project HELP July 18, 2019 09:53PM |
Re: Kossel Delta xxl build project HELP July 18, 2019 10:39PM |
Re: Kossel Delta xxl build project HELP July 19, 2019 06:38PM |
Re: Kossel Delta xxl build project HELP July 22, 2019 07:49AM |
Re: Kossel Delta xxl build project HELP July 22, 2019 07:56AM |
Re: Kossel Delta xxl build project HELP July 22, 2019 08:31AM |
Re: Kossel Delta xxl build project HELP July 22, 2019 12:07PM |
Re: Kossel Delta xxl build project HELP July 22, 2019 02:14PM |
Re: Kossel Delta xxl build project HELP July 29, 2019 11:33AM |
Re: Kossel Delta xxl build project HELP August 01, 2019 10:32AM |
Re: Kossel Delta xxl build project HELP August 02, 2019 08:20AM |
Re: Kossel Delta xxl build project HELP August 02, 2019 12:42PM |
