Re: Generation 7 Electronics Development April 07, 2012 10:25PM |
Re: Generation 7 Electronics Development April 09, 2012 06:15PM |
I'm a bit bummed that my ultra new Gen7T is already out of date
Would it be a good idea to change the bed/hot end power connector from molex to an atx +4 connector? That way you wouldn't need to solder wires to the board if you want to run a heated bed.
Why not lengthen the 5V jumper and route the serial lines more directly?
Is there a spot in the expansion header that is compatible with either SD RAMPS or sanquinololu SD card boards, or would that be difficult on this design?
TC
A couple of things to pay attention to when using N-FETs [...]
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Generation 7 Electronics Development April 09, 2012 10:05PM |
Re: Generation 7 Electronics Development April 10, 2012 04:48AM |
I don't know why you are so put off by 'information' and why you think what I posted was 'opinion'.
try a lower series gate resistor instead of the 1K you currently have in your schematic.
Re: Generation 7 Electronics Development April 10, 2012 09:54PM |
Re: Generation 7 Electronics Development April 11, 2012 05:39AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Generation 7 Electronics Development April 11, 2012 06:42AM |
Re: Generation 7 Electronics Development June 04, 2012 11:54AM |
Re: Generation 7 Electronics Development June 05, 2012 06:44AM |
In fact I would also be pleased about an already optimized Gen7 v1.4 board layout which I only have to print out, but I couldn't find it.
Re: Generation 7 Electronics Development June 12, 2012 04:00PM |
Re: Generation 7 Electronics Development June 13, 2012 04:18AM |
Re: Generation 7 Electronics Development June 13, 2012 09:14AM |
Re: Generation 7 Electronics Development July 07, 2012 04:57PM |
Re: Generation 7 Electronics Development August 01, 2012 12:56PM |
Re: Generation 7 Electronics Development August 03, 2012 07:38PM |
Re: Generation 7 Electronics Development August 18, 2012 06:37PM |
Re: Generation 7 Electronics Development October 10, 2012 08:48AM |
Re: Generation 7 Electronics Development October 10, 2012 12:41PM |
Re: Generation 7 Electronics Development October 11, 2012 06:49AM |
Re: Generation 7 Electronics Development October 11, 2012 04:38PM |
Re: Generation 7 Electronics Development October 11, 2012 05:07PM |
Re: Generation 7 Electronics Development October 12, 2012 07:50AM |
Re: Generation 7 Electronics Development October 12, 2012 08:25AM |
Re: Generation 7 Electronics Development October 13, 2012 06:55AM |
Re: Generation 7 Electronics Development October 13, 2012 07:04AM |
Re: Generation 7 Electronics Development October 13, 2012 07:37AM |
Re: Generation 7 Electronics Development October 13, 2012 07:48AM |
Re: Generation 7 Electronics Development October 13, 2012 07:55AM |
Re: Generation 7 Electronics Development October 13, 2012 12:33PM |
$ avrdude -c avrispv2 -p attiny85 -P /dev/ttyACM0 -B 100 -v -F ... avrdude: stk500v2_command(): command failed avrdude: initialization failed, rc=-1 avrdude: AVR device initialized and ready to accept instructions avrdude: Device signature = 0x000000 avrdude: Yikes! Invalid device signature. ...
Re: Generation 7 Electronics Development October 13, 2012 01:36PM |
