Re: New to 3d printing with smartrap need some help July 30, 2014 05:24AM |
Re: New to 3d printing with smartrap need some help July 30, 2014 07:52AM |
Re: New to 3d printing with smartrap need some help July 30, 2014 08:10AM |
Re: New to 3d printing with smartrap need some help July 30, 2014 04:16PM |
duranza
New smartrap probe/hot-end plate
Hey all, I have a little present for you guys. Take a look a this little mod. I will be testing it tomorrow and when all is good I will post some STLs for whoever wants to upgrade.
This will help out with eliminating the torque of the normal arm, as this only allows up/down movement.
Re: New to 3d printing with smartrap need some help July 30, 2014 06:47PM |
Re: New to 3d printing with smartrap need some help July 30, 2014 07:31PM |
Re: New to 3d printing with smartrap need some help July 30, 2014 10:13PM |
Re: New to 3d printing with smartrap need some help July 31, 2014 05:10AM |
Re: New to 3d printing with smartrap need some help July 31, 2014 07:50AM |
smartfriendz
I just printed but not installed for now, but already by hand it seems to be indeed very good.
Can i steel your idea and adapt for both heads? ( huxley type). I need also to adapt the top to all three driving systems ( fishing line, racks&pinions and GT2) so the model will be maybe changed, but basically, it would be a real idea steeling
You found just something i tried before and failed miserably ! cool work
Re: New to 3d printing with smartrap need some help July 31, 2014 01:26PM |
Re: New to 3d printing with smartrap need some help July 31, 2014 05:50PM |
Re: New to 3d printing with smartrap need some help July 31, 2014 06:03PM |
Re: New to 3d printing with smartrap need some help July 31, 2014 06:11PM |
Re: New to 3d printing with smartrap need some help July 31, 2014 10:05PM |
smartfriendz
Re: New to 3d printing with smartrap need some help August 01, 2014 07:47AM |
Re: New to 3d printing with smartrap need some help August 01, 2014 07:48AM |
Updated version now ready:Quote
duranza
Wow very cool fan cowl integration. I like it.
Re: New to 3d printing with smartrap need some help August 01, 2014 09:40PM |
Re: New to 3d printing with smartrap need some help August 02, 2014 01:12AM |
duranza
I like where this is going. Interchangeable hot-ends already bolted to the slide. Now if we can make the wires with some sort of plug in/ disconnect we would just move the switch, and slide the new one in.
Re: New to 3d printing with smartrap need some help August 02, 2014 01:00PM |
Re: New to 3d printing with smartrap need some help August 03, 2014 08:33AM |
Re: New to 3d printing with smartrap need some help August 03, 2014 09:05PM |
\Quote
BackEMF
Are there any original files available? My PC is not powerfull enough to convert the mesh back into a solid that i can edit in FreeCAD.
Re: New to 3d printing with smartrap need some help August 04, 2014 06:50AM |
Re: New to 3d printing with smartrap need some help August 04, 2014 07:38AM |
Re: New to 3d printing with smartrap need some help August 04, 2014 07:41AM |
Re: New to 3d printing with smartrap need some help August 04, 2014 08:42AM |
regpye
duranza
All parts
Fan cowl
Sliding base
The sliding base has been designed to be tapped with a M3 tap. Print this small part at 40% fill or more.
Re: New to 3d printing with smartrap need some help August 04, 2014 06:35PM |
Talle
regpye
duranza
All parts
Fan cowl
Sliding base
Thx for this!
I really like it!
Just a quick question.
Has the main part of this been edited aswell in the latest version?
Printed just the sliding base and that is a great deal smaller than the original part in my print.
or is it just my print that is bad (made 2 copies).
Main part is with 100% fill and Sliding base with 50%.
THX
Re: New to 3d printing with smartrap need some help August 04, 2014 07:33PM |
Re: New to 3d printing with smartrap need some help August 05, 2014 01:19PM |
Re: New to 3d printing with smartrap need some help August 05, 2014 05:23PM |
duranza
The original files had a .1mm gap between the main plate and the slide plate already built in.
Hey Reg, I think what would help on the Genie parts is to put a straight fillet on the corner of the 45 degree slide part so that only the sides make contact.
Re: New to 3d printing with smartrap need some help August 05, 2014 06:09PM |
