Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 10, 2015 12:43PM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 10, 2015 01:48PM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 10, 2015 02:29PM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 10, 2015 02:30PM |
#ifndef CONFIGURATION_H #define CONFIGURATION_H // This configuration file contains basic settings. Select your: // - board type // - Mechanism type (cartesian-corexy-delta-scara) // - temperature sensor type // // Mechanisms-settings can be found in configuration_xxxxxx.h // Advanced settings can be found in Configuration_adv.h #include "boards.h" // Choose your board type. // Either an numeric ID or name defined in boards.h is valid. // See: [github.com] #define MOTHERBOARD BOARD_RAMPS_13_HFB // User-specified version info of this build to display in [Pronterface, etc] terminal window during // startup. Implementation of an idea by Prof Braino to inform user that any changes made to this // build by the user have been successfully uploaded into firmware. #define STRING_VERSION "4.1.2" #define STRING_URL "reprap.org" #define STRING_VERSION_CONFIG_H __DATE__ " " __TIME__ // build date and time #define STRING_CONFIG_H_AUTHOR "(none, default config)" // Who made the changes. #define STRING_SPLASH_LINE1 "v" STRING_VERSION // will be shown during bootup in line 1 #define STRING_SPLASH_LINE2 STRING_VERSION_CONFIG_H // will be shown during bootup in line 2 // SERIAL_PORT 0 // This allows the connection of wireless adapters (for instance) to non-default port pins. // Serial port 0 is still used by the Arduino bootloader regardless of this setting. #define SERIAL_PORT 0 // This determines the communication speed of the printer // 115200 - 250000 #define BAUDRATE 115200 // This enables the serial port associated to the Bluetooth interface on AT90USB devices //#define BTENABLED // Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines) // You can use an online service to generate a random UUID. (eg [www.uuidgenerator.net]) //#define MACHINE_UUID "00000000-0000-0000-0000-000000000000" // If you want test the firmware uncomment below. Use Serial arduino monitor... //#define FIRMWARE_TEST // ONLY BAUDRATE 115200 /***********************************************************************\ **************************** Define type printer ********************** ***********************************************************************/ //#define CARTESIAN //#define COREXY #define DELTA //#define SCARA /***********************************************************************\ /***********************************************************************\ ********************** Do not touch this section ********************** ***********************************************************************/ #if defined(CARTESIAN) #include "Configuration_Cartesian.h" #elif defined(COREXY) #include "Configuration_Core.h" #elif defined(DELTA) #include "Configuration_Delta.h" #elif defined(SCARA) #include "Configuration_Scara.h" #endif /***********************************************************************/ // This defines the number of extruder real or virtual #define EXTRUDERS 1 // This defines the number of Driver extruder you have and use #define DRIVER_EXTRUDERS 1 // This is used for single nozzle and multiple extrusion configuration // Uncomment below to enable (One Hotend) //#define SINGLENOZZLE /*********************************************************************** *********************** Multiextruder MKR4 *************************** *********************************************************************** * * * Setting for more extruder width relay system * * See pins.h for pin command relay * * * ***********************************************************************/ //#define MKR4 //********************************************************************** /*********************************************************************** *********************** Multiextruder NPr2 *************************** *********************************************************************** * * * Setting fot color meccanism NPr2 by NicolaP (www.3dmakerlab.it) * * Find angle setting by g-Code "M997 Cxxx" * * * ***********************************************************************/ //#define NPR2 #define COLOR_STEP {120,25,-65,-155} // CARTER ANGLE #define COLOR_SLOWRATE 170 // MICROSECOND delay for carter motor routine (Carter Motor Feedrate: upper value-slow feedrate) #define COLOR_HOMERATE 4 // FEEDRATE for carter home #define MOTOR_ANGLE 1.8 // Nema angle for single step #define DRIVER_MICROSTEP 4 // Microstep moltiplicator driver (set jumper MS1-2-3) off-on-off 1/4 microstepping. #define CARTER_MOLTIPLICATOR 14.22 // CARTER MOLTIPLICATOR (gear ratio 13/31-10/31) //********************************************************************** // The following define selects which power supply you have. Please choose the one that matches your setup // 0 = Normal power // 1 = ATX // 2 = X-Box 360 203 Watts (the blue wire connected to PS_ON and the red wire to VCC) #define POWER_SUPPLY 0 // Define this to have the electronics keep the power supply off on startup. If you don't know what this is leave it. //#define PS_DEFAULT_OFF //=========================================================================== //============================= Thermal Settings ============================ //=========================================================================== //================================ Thermistor =============================== //--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table // //// Temperature sensor settings: // -2 is thermocouple with MAX6675 (only for sensor 0) // -1 is thermocouple with AD595 // 0 is not used // 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) // 3 is Mendel-parts thermistor (4.7k pullup) // 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! // 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) // 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) // 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup) // 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) // 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup) // 10 is 100k RS thermistor 198-961 (4.7k pullup) // 11 is 100k beta 3950 1% thermistor (4.7k pullup) // 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed) // 13 is 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE" // 20 is the PT100 circuit found in the Ultimainboard V2.x // 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950 // // 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k // (but gives greater accuracy and more stable PID) // 51 is 100k thermistor - EPCOS (1k pullup) // 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup) // 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup) // // 1047 is Pt1000 with 4k7 pullup // 1010 is Pt1000 with 1k pullup (non standard) // 147 is Pt100 with 4k7 pullup // 110 is Pt100 with 1k pullup (non standard) // 998 and 999 are Dummy Tables. They will ALWAYS read 25°C or the temperature defined below. // Use it for Testing or Development purposes. NEVER for production machine. // #define DUMMY_THERMISTOR_998_VALUE 25 // #define DUMMY_THERMISTOR_999_VALUE 100 #define TEMP_SENSOR_0 0 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 #define TEMP_SENSOR_BED 1 // This makes temp sensor 1 a redundant sensor for sensor 0. If the temperatures difference between these sensors is to high the print will be aborted. //#define TEMP_SENSOR_1_AS_REDUNDANT #define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10 // (degC) // Actual temperature must be close to target for this long before M109 returns success #define TEMP_RESIDENCY_TIME 10 // (seconds) #define TEMP_HYSTERESIS 3 // (degC) range of +/- temperatures considered "close" to the target one #define TEMP_WINDOW 1 // (degC) Window around target to start the residency timer x degC early. // The minimal temperature defines the temperature below which the heater will not be enabled It is used // to check that the wiring to the thermistor is not broken. // Otherwise this would lead to the heater being powered on all the time. #define HEATER_0_MINTEMP 5 // (degC) #define HEATER_1_MINTEMP 5 // (degC) #define HEATER_2_MINTEMP 5 // (degC) #define HEATER_3_MINTEMP 5 // (degC) #define BED_MINTEMP 5 // (degC) // When temperature exceeds max temp, your heater will be switched off. // This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure! // You should use MINTEMP for thermistor short/failure protection. #define HEATER_0_MAXTEMP 275 // (degC) #define HEATER_1_MAXTEMP 275 // (degC) #define HEATER_2_MAXTEMP 275 // (degC) #define HEATER_3_MAXTEMP 275 // (degC) #define BED_MAXTEMP 150 // (degC) // If your bed has low resistance e.g. .6 ohm and throws the fuse you can duty cycle it to reduce the // average current. The value should be an integer and the heat bed will be turned on for 1 interval of // HEATER_BED_DUTY_CYCLE_DIVIDER intervals. //#define HEATER_BED_DUTY_CYCLE_DIVIDER 4 // If you want the M105 heater power reported in watts, define the BED_WATTS, and (shared for all hotend) HOTEND_WATTS //#define HOTEND_WATTS (12.0*12.0/6.7) // P=I^2/R //#define BED_WATTS (12.0*12.0/1.1) // P=I^2/R //=========================================================================== //============================= PID Settings ================================ //=========================================================================== // PID Tuning Guide here: [reprap.org] // Comment the following line to disable PID and enable bang-bang. #define PIDTEMP #define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current #define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current //#define PID_DEBUG // Sends debug data to the serial port. //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX //#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay // If the temperature difference between the target temperature and the actual temperature // is more then PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max. #define PID_FUNCTIONAL_RANGE 10 // degC #define PID_INTEGRAL_DRIVE_MAX PID_MAX // Limit for the integral term #define K1 0.95 // Smoothing factor within the PID // HotEnd{HE0,HE1,HE2,HE3} #define DEFAULT_Kp {41.51,41.51,41.51,41.51} // Kp for E0, E1, E2, E3 #define DEFAULT_Ki {7.28,7.28,7.28,7.28} // Ki for E0, E1, E2, E3 #define DEFAULT_Kd {59.17,59.17,59.17,59.17} // Kd for E0, E1, E2, E3 //=========================================================================== //=========================================================================== //============================= PID > Bed Temperature Control =============== //=========================================================================== // Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis // // Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder. // If your PID_dT is the default, and correct for your hardware/configuration, that means 7.689Hz, // which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating. // This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater. // If your configuration is significantly different than this and you don't understand the issues involved, you probably // shouldn't use bed PID until someone else verifies your hardware works. // If this is enabled, find your own PID constants below. //#define PIDTEMPBED // //#define BED_LIMIT_SWITCHING // This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option. // all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis) // setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did, // so you shouldn't use it unless you are OK with PWM on your bed. (see the comment on enabling PIDTEMPBED) #define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current //#define PID_BED_DEBUG // Sends debug data to the serial port. //120v 250W silicone heater into 4mm borosilicate (MendelMax 1.5+) //from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10) #define DEFAULT_bedKp 10.00 #define DEFAULT_bedKi .023 #define DEFAULT_bedKd 305.4 //120v 250W silicone heater into 4mm borosilicate (MendelMax 1.5+) //from pidautotune // #define DEFAULT_bedKp 97.1 // #define DEFAULT_bedKi 1.41 // #define DEFAULT_bedKd 1675.16 // FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles. //=========================================================================== //this prevents dangerous Extruder moves, i.e. if the temperature is under the limit //can be software-disabled for whatever purposes by #define PREVENT_DANGEROUS_EXTRUDE //if PREVENT DANGEROUS EXTRUDE is on, you can still disable (uncomment) very long bits of extrusion separately. #define PREVENT_LENGTHY_EXTRUDE #define EXTRUDE_MINTEMP 170 // degC #define EXTRUDE_MAXLENGTH (X_MAX_LENGTH+Y_MAX_LENGTH) //prevent extrusion of very large distances. //=========================================================================== //======================== Thermal Runaway Protection ======================= //=========================================================================== /** * Thermal Runaway Protection protects your printer from damage and fire if a * thermistor falls out or temperature sensors fail in any way. * * The issue: If a thermistor falls out or a temperature sensor fails, * Marlin can no longer sense the actual temperature. Since a disconnected * thermistor reads as a low temperature, the firmware will keep the heater on. * * The solution: Once the temperature reaches the target, start observing. * If the temperature stays too far below the target (hysteresis) for too long, * the firmware will halt as a safety precaution. * * Note that because the countdown starts only AFTER the temperature reaches * the target, this will not catch a thermistor that is already disconnected * when the print starts! * * To enable for all extruder heaters, uncomment the two defines below: */ // Parameters for all extruder heaters #define THERMAL_RUNAWAY_PROTECTION_PERIOD 40 // in seconds #define THERMAL_RUNAWAY_PROTECTION_HYSTERESIS 4 // in degree Celsius // To enable for the bed heater, uncomment the two defines below: // Parameters for the bed heater #define THERMAL_RUNAWAY_PROTECTION_BED_PERIOD 20 // in seconds #define THERMAL_RUNAWAY_PROTECTION_BED_HYSTERESIS 2 // in degree Celsius //=========================================================================== //============================ User Interfaces ============================== //=========================================================================== //==============================LCD and SD support============================= // Choose ONE of these 3 charsets. This has to match your hardware. Ignored for full graphic display. // To find out what type you have - compile with (test) - upload - click to get the menu. You'll see two typical lines from the upper half of the charset. // See also documentation/LCDLanguageFont.md #define DISPLAY_CHARSET_HD44780_JAPAN // this is the most common hardware //#define DISPLAY_CHARSET_HD44780_WESTERN //#define DISPLAY_CHARSET_HD44780_CYRILLIC //#define ULTRA_LCD //general LCD support, also 16x2 //#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) //#define SDSUPPORT // Enable SD Card Support in Hardware Console //#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) //#define SD_CHECK_AND_RETRY // Use CRC checks and retries on the SD communication //#define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder //#define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking //#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store. //#define ULTIPANEL //the UltiPanel as on Thingiverse //#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click //#define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click // 0 to disable buzzer feedback. Test with M300 S P // PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3) // [reprap.org] //#define PANEL_ONE // The MaKr3d Makr-Panel with graphic controller and SD support // [reprap.org] //#define MAKRPANEL // The Panucatt Devices Viki 2.0 and mini Viki with Graphic LCD // [panucatt.com] // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] //#define VIKI2 //#define miniVIKI // The RepRapDiscount Smart Controller (white PC // [reprap.org] //#define REPRAP_DISCOUNT_SMART_CONTROLLER // The GADGETS3D G3D LCD/SD Controller (blue PC // [reprap.org] //#define G3D_PANEL // The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC // [reprap.org] // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] //#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER // The RepRapWorld REPRAPWORLD_KEYPAD v1.1 // [reprapworld.com] //#define REPRAPWORLD_KEYPAD //#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click // The Elefu RA Board Control Panel // [www.elefu.com] // REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARDUINO library folder: [github.com] //#define RA_CONTROL_PANEL // I2C Panels //#define LCD_I2C_SAINSMART_YWROBOT // PANELOLU2 LCD with status LEDs, separate encoder and click inputs //#define LCD_I2C_PANELOLU2 // Panucatt VIKI LCD with status LEDs, integrated click & L/R/U/P buttons, separate encoder inputs //#define LCD_I2C_VIKI // Shift register panels // --------------------- // 2 wire Non-latching LCD SR from: // [bitbucket.org] //#define SAV_3DLCD // option for invert rotary switch //#define INVERT_ROTARY_SWITCH // Uncomment screen orientation ONLY FOR GRAPHICS DISPLAY #define LCD_SCREEN_ROT_0 // #define LCD_SCREEN_ROT_90 // #define LCD_SCREEN_ROT_180 // #define LCD_SCREEN_ROT_270 // SPLASH SCREEN duration in millisecond #define SPLASH_SCREEN_DURATION 2000 // Millisecond /** Display Voltage Logic Selector on Alligator Board 0 = Voltage level 3.3V 1 = Voltage level 5V */ #define UI_VOLTAGE_LEVEL 0 // Set 5 o 3.3 V //============================== Languages UI ========================= // 1 English // 2 Polish // 3 French // 4 German // 5 Spanish // 6 Russian // 7 Italian // 8 Portuguese // 9 Finnish // 10 Aragonese // 11 Dutch // 12 Catalan // 13 Basque-Euskera // 14 Portuguese (Brazil) #define LANGUAGE_CHOICE 7 //=========================================================================== //=============================Additional Features=========================== //=========================================================================== //=================================== EEPROM ================================ // The microcontroller can store settings in the EEPROM, e.g. max velocity... // M500 - stores parameters in EEPROM // M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily). // M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. //define this to enable EEPROM support //#define EEPROM_SETTINGS #define EEPROM_CHITCHAT // to disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out: // please keep turned on if you can. //#define DISABLE_M503 //=========================================================================== //==================== Bowden Filament management =========================== //#define EASY_LOAD #define BOWDEN_LENGTH 250 // mm #define LCD_PURGE_LENGTH 3 // mm #define LCD_RETRACT_LENGTH 3 // mm #define LCD_PURGE_FEEDRATE 3 // mm/s #define LCD_RETRACT_FEEDRATE 10 // mm/s #define LCD_LOAD_FEEDRATE 8 // mm/s #define LCD_UNLOAD_FEEDRATE 8 // mm/s //=========================================================================== //====================== Preheat Constants ================================== #define PLA_PREHEAT_HOTEND_TEMP 190 #define PLA_PREHEAT_HPB_TEMP 60 #define PLA_PREHEAT_FAN_SPEED 255 // Insert Value between 0 and 255 #define ABS_PREHEAT_HOTEND_TEMP 240 #define ABS_PREHEAT_HPB_TEMP 100 #define ABS_PREHEAT_FAN_SPEED 255 // Insert Value between 0 and 255 #define GUM_PREHEAT_HOTEND_TEMP 230 #define GUM_PREHEAT_HPB_TEMP 60 #define GUM_PREHEAT_FAN_SPEED 255 // Insert Value between 0 and 255 //=========================================================================== //============================= R/C Servo support =========================== // Number of servos // If you select a configuration below, this will receive a default value and does not need to be set manually // set it manually if you have more servos than extruders and wish to manually control some // leaving it defining as 0 will disable the servo subsystem #define NUM_SERVOS 0 // Servo index starts with 0 for M280 command // Servo Endstops // This allows for servo actuated endstops, primary usage is for the Z Axis to eliminate calibration or bed height changes. // Use M666 command to correct for switch height offset to actual nozzle height. Store that setting with M500. // #define SERVO_ENDSTOPS {-1,-1,0} // Servo index for X, Y, Z. Disable with -1 #define SERVO_ENDSTOP_ANGLES {0,0,0,0,90,0} // X,Y,Z Axis Extend and Retract angles //=========================================================================== /**********************************************************************\ * Support for a filament diameter sensor * Also allows adjustment of diameter at print time (vs at slicing) * Single extruder only at this point (extruder 0) * * Motherboards * 34 - RAMPS1.4 - uses Analog input 5 on the AUX2 connector * 81 - Printrboard - Uses Analog input 2 on the Exp1 connector (version B,C,D,E) * 301 - Rambo - uses Analog input 3 * Note may require analog pins to be defined for different motherboards **********************************************************************/ // Uncomment below to enable //#define FILAMENT_SENSOR #define FILAMENT_SENSOR_EXTRUDER_NUM 0 //The number of the extruder that has the filament sensor (0,1,2,3) #define MEASUREMENT_DELAY_CM 14 //measurement delay in cm. This is the distance from filament sensor to middle of barrel #define DEFAULT_NOMINAL_FILAMENT_DIA 1.75 //Enter the diameter (in mm) of the filament generally used (3.0 mm or 1.75 mm) - this is then used in the slicer software. Used for sensor reading validation #define MEASURED_UPPER_LIMIT 2.00 //upper limit factor used for sensor reading validation in mm #define MEASURED_LOWER_LIMIT 1.35 //lower limit factor for sensor reading validation in mm #define MAX_MEASUREMENT_DELAY 20 //delay buffer size in bytes (1 byte = 1cm)- limits maximum measurement delay allowable (must be larger than MEASUREMENT_DELAY_CM and lower number saves RAM) //defines used in the code #define DEFAULT_MEASURED_FILAMENT_DIA DEFAULT_NOMINAL_FILAMENT_DIA //set measured to nominal initially //When using an LCD, uncomment the line below to display the Filament sensor data on the last line instead of status. Status will appear for 5 sec. //#define FILAMENT_LCD_DISPLAY //=========================================================================== /**********************************************************************\ * Support for a current sensor (Hall effect sensor like ACS712) for measure the power consumption * Since it's more simple to deal with, we measure the DC current and we assume that POWER_VOLTAGE that comes from your power supply it's almost stable. * You have to change the SENSITIVITY with the one that you can find in the datasheet. (in case of ACS712: set to .100 for 20A version or set .066 for 30A version) * With this module we measure the Printer power consumption ignoring the Power Supply power consumption, so we consider the EFFICIENCY of our supply to be 100% so without * any power dispersion. If you want to approximately add the supply consumption you can decrease the EFFICIENCY to a value less than 100. Eg: 85 is a good value. * You can find a better value measuring the AC current with a good multimeter and moltiple it with the mains voltage. * MULTIMETER_WATT := MULTIMETER_CURRENT * MAINS_VOLTAGE * Now you have a Wattage value that you can compare with the one measured from ACS712. * NEW_EFFICENCY := (SENSOR_WATT*EFFICIENCY)/MULTIMETER_WATT * For now this feature is to be consider BETA as i'll have to do some accurate test to see the affidability **********************************************************************/ // Uncomment below to enable //#define POWER_CONSUMPTION #define POWER_VOLTAGE 12.00 //(V) The power supply OUT voltage #define POWER_ZERO 2.54459 //(V) The /\V coming out from the sensor when no current flow. #define POWER_SENSITIVITY 0.066 //(V/A) How much increase V for 1A of increase #define POWER_OFFSET 0.015 //(A) Help to get 0A when no load is connected. #define POWER_ERROR 3.0 //(%) Ammortize measure error. #define POWER_EFFICIENCY 100.0 //(%) The power efficency of the power supply //When using an LCD, uncomment the line below to display the Power consumption sensor data on the last line instead of status. Status will appear for 5 sec. //#define POWER_CONSUMPTION_LCD_DISPLAY //=========================================================================== //=================================== Misc ================================= // Temperature status LEDs that display the hotend and bet temperature. // If all hotends and bed temperature and temperature setpoint are < 54C then the BLUE led is on. // Otherwise the RED led is on. There is 1C hysteresis. //#define TEMP_STAT_LEDS // Increase the FAN pwm frequency. Removes the PWM noise but increases heating in the FET/Arduino //#define FAST_PWM_FAN // Use software PWM to drive the fan, as for the heaters. This uses a very low frequency // which is not ass annoying as with the hardware PWM. On the other hand, if this frequency // is too low, you should also increment SOFT_PWM_SCALE. //#define FAN_SOFT_PWM // Incrementing this by 1 will double the software PWM frequency, // affecting heaters, and the fan if FAN_SOFT_PWM is enabled. // However, control resolution will be halved for each increment; // at zero value, there are 128 effective control positions. #define SOFT_PWM_SCALE 0 // M240 Triggers a camera by emulating a Canon RC-1 Remote // Data from: [www.doc-diy.net] //#define PHOTOGRAPH_PIN 23 // SF send wrong arc g-codes when using Arc Point as fillet procedure //#define SF_ARC_FIX // Support for the BariCUDA Paste Extruder. //#define BARICUDA // Support for BlinkM/CyzRgb //#define BLINKM // Enable this option for Toshiba steppers //#define CONFIG_STEPPERS_TOSHIBA //=========================================================================== //============================= Filament Runout Sensor ====================== //=========================================================================== //#define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament // It is assumed that when logic high = filament available // when logic low = filament run out #ifdef FILAMENT_RUNOUT_SENSOR const bool FILRUNOUT_PIN_INVERTING = true; // Should be uncommented and true or false should assigned #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined. #define FILAMENT_RUNOUT_SCRIPT "M600" // Script execute when filament run out #endif //=========================================================================== //============================= Laser Beam Support ========================== //=========================================================================== //#define LASERBEAM //=========================================================================== #include "Configuration_adv.h" #include "thermistortables.h" #endif //__CONFIGURATION_H /* Below you will find the configuration string, that created with Configurator tool online marlinkimbra.it ========== Start configuration string ========== { "printer": "custom", "processor": 0, "version": 0, "serialnumber": 0, "bluetooth": "0", "baudrates": 115200, "customname": "none", "customconfig": "default config", "machineuuid": "00000000-0000-0000-0000-000000000000", "testmode": "0", "notimeouts": "0", "advancedok": "0", "motherboards": "BOARD_RAMPS_13_HFB", "mechanism": 3, "power": "0", "defaultpower": "0", "extruders": 1, "driverextruders": 1, "singlenozzle": "0", "mkr4": "0", "npr2": "0", "invertrelepin": "0", "E0E1pin": 5, "E0E2pin": 5, "E0E3pin": -1, "E1E3pin": 6, "pidtemp": "1", "pidextrusionrate": "0", "pidbedtemp": "0", "dangerousextrude": "1", "lengthextrude": "1", "extrudemintemp": 170, "tempsensor0": "1", "tempsensor1": "0", "tempsensor2": "0", "tempsensor3": "0", "tempsensorbed": "0", "heater0pin": "ORIG_HEATER_0_PIN", "heater1pin": "ORIG_HEATER_1_PIN", "heater2pin": "ORIG_HEATER_2_PIN", "heater3pin": "ORIG_HEATER_3_PIN", "heaterbedpin": "ORIG_HEATER_BED_PIN", "temp0pin": "ORIG_TEMP_0_PIN", "temp1pin": "ORIG_TEMP_1_PIN", "temp2pin": "ORIG_TEMP_2_PIN", "temp3pin": "ORIG_TEMP_3_PIN", "tempbedpin": "ORIG_TEMP_BED_PIN", "mintemp0": 5, "mintemp1": 5, "mintemp2": 5, "mintemp3": 5, "mintempbed": 5, "maxtemp0": 275, "maxtemp1": 275, "maxtemp2": 275, "maxtemp3": 275, "maxtempbed": 150, "pidkp0": 41.51, "pidki0": 7.28, "pidkd0": 59.17, "pidkc0": 100, "pidkp1": 41.51, "pidki1": 7.28, "pidkd1": 59.17, "pidkc1": 100, "pidkp2": 41.51, "pidki2": 7.28, "pidkd2": 59.17, "pidkc2": 100, "pidkp3": 41.51, "pidki3": 7.28, "pidkd3": 59.17, "pidkc3": 100, "pidbedkp": 10, "pidbedki": 1, "pidbedkd": 305, "E0coolerpin": -1, "E1coolerpin": -1, "E2coolerpin": -1, "E3coolerpin": -1, "Ecoolerspeed": 255, "Ecoolertemp": 50, "autobed": "0", "zprobingrepeat": "0", "gridmode": "1", "gridpoint": 2, "Zsafehoming": "0", "ZsafehomingX": 100, "ZsafehomingY": 100, "leftprobe": 20, "rightprobe": 180, "backprobe": 180, "frontprobe": 20, "Xprobe1": 15, "Yprobe1": 180, "Xprobe2": 15, "Yprobe2": 15, "Xprobe3": 180, "Yprobe3": 15, "Xprobeoffset": 0, "Yprobeoffset": 0, "Zprobeoffset": -1, "Zraisebeforehoming": 10, "Zraisebeforeprobe": 10, "Zraisebetweenprobe": 10, "Xmotor": { "name": "X motor", "step": "ORIG_X_STEP_PIN", "dir": "ORIG_X_DIR_PIN", "enable": "ORIG_X_ENABLE_PIN" }, "Ymotor": { "name": "Y motor", "step": "ORIG_Y_STEP_PIN", "dir": "ORIG_Y_DIR_PIN", "enable": "ORIG_Y_ENABLE_PIN" }, "Zmotor": { "name": "Z motor", "step": "ORIG_Z_STEP_PIN", "dir": "ORIG_Z_DIR_PIN", "enable": "ORIG_Z_ENABLE_PIN" }, "Y2motor": { "name": "Extruder 1", "step": "ORIG_E1_STEP_PIN", "dir": "ORIG_E1_DIR_PIN", "enable": "ORIG_E1_ENABLE_PIN" }, "Z2motor": { "name": "Extruder 1", "step": "ORIG_E1_STEP_PIN", "dir": "ORIG_E1_DIR_PIN", "enable": "ORIG_E1_ENABLE_PIN" }, "E0motor": { "name": "Extruder 0", "step": "ORIG_E0_STEP_PIN", "dir": "ORIG_E0_DIR_PIN", "enable": "ORIG_E0_ENABLE_PIN" }, "E1motor": { "name": "Extruder 1", "step": "ORIG_E1_STEP_PIN", "dir": "ORIG_E1_DIR_PIN", "enable": "ORIG_E1_ENABLE_PIN" }, "E2motor": { "name": "Extruder 2", "step": "ORIG_E2_STEP_PIN", "dir": "ORIG_E2_DIR_PIN", "enable": "ORIG_E2_ENABLE_PIN" }, "E3motor": { "name": "Extruder 3", "step": "ORIG_E3_STEP_PIN", "dir": "ORIG_E3_DIR_PIN", "enable": "ORIG_E3_ENABLE_PIN" }, "Ydualstepper": "0", "Y2vsYdir": "0", "Zdualstepper": "0", "Zdualendstop": "0", "Xminpos": 0, "Xmaxpos": 200, "Yminpos": 0, "Ymaxpos": 200, "Zminpos": 0, "Zmaxpos": 200, "defaultacceleration": 2500, "defaulttravelacceleration": 3000, "maxXYjerk": 10, "maxZjerk": 0.4, "maxE0jerk": 5, "maxE1jerk": 5, "maxE2jerk": 5, "maxE3jerk": 5, "deltasegmentpersecond": 200, "deltadiagonalrod": 220, "deltasmoothrodoffset": 145, "deltaeffectoroffset": 20, "deltacarriageoffset": 20, "deltaprinterradius": 70, "deltaheight": 210, "deltaautoprecision": 0.1, "deltaautogrid": 20, "deltaXprobeoffset": 0, "deltaYprobeoffset": 0, "deltaZprobeoffset": -10, "deltaXdeploystart": 0, "deltaYdeploystart": 0, "deltaZdeploystart": 30, "deltaXdeployend": 0, "deltaYdeployend": 0, "deltaZdeployend": 0, "deltaXretractstart": 0, "deltaYretractstart": 0, "deltaZretractstart": 30, "deltaXretractend": 0, "deltaYretractend": 0, "deltaZretractend": 0, "Xmicrostep": 16, "Ymicrostep": 16, "Zmicrostep": 16, "Emicrostep": 16, "Xcurrent": 1000, "Ycurrent": 1000, "Zcurrent": 1000, "E0current": 1000, "E1current": 1000, "E2current": 1000, "E3current": 1000, "Xstepspermm": 80, "Ystepspermm": 80, "Zstepspermm": 3200, "E0stepspermm": 625, "E1stepspermm": 625, "E2stepspermm": 625, "E3stepspermm": 625, "Xmaxspeed": 300, "Ymaxspeed": 300, "Zmaxspeed": 2, "E0maxspeed": 100, "E1maxspeed": 100, "E2maxspeed": 100, "E3maxspeed": 100, "E0retractionspeed": 150, "E1retractionspeed": 150, "E2retractionspeed": 150, "E3retractionspeed": 150, "Xhomingspeed": 100, "Yhomingspeed": 100, "Zhomingspeed": 2, "Xmaxacceleration": 3000, "Ymaxacceleration": 3000, "Zmaxacceleration": 50, "E0maxacceleration": 3000, "E1maxacceleration": 3000, "E2maxacceleration": 3000, "E3maxacceleration": 3000, "E0retractacceleration": 10000, "E1retractacceleration": 10000, "E2retractacceleration": 10000, "E3retractacceleration": 10000, "Xinvert": 0, "Yinvert": 0, "Zinvert": 0, "E0invert": 0, "E1invert": 0, "E2invert": 0, "E3invert": 0, "Xinvertenable": 0, "Yinvertenable": 0, "Zinvertenable": 0, "Einvertenable": 0, "disableX": 0, "disableY": 0, "disableZ": 0, "disableE": 0, "Xhoming": 0, "Yhoming": 0, "Zhoming": 0, "Ehoming": 0, "Xminendstop": "0", "Xmaxendstop": "0", "Yminendstop": "0", "Ymaxendstop": "0", "Zminendstop": "0", "Zmaxendstop": "0", "Z2minendstop": "0", "Z2maxendstop": "0", "Zprobeendstop": "0", "Eminendstop": "0", "Xminpullup": "1", "Xmaxpullup": "1", "Yminpullup": "1", "Ymaxpullup": "1", "Zminpullup": "1", "Zmaxpullup": "1", "Z2minpullup": "1", "Z2maxpullup": "1", "Zprobepullup": "1", "Eminpullup": "1", "fanpin": "ORIG_FAN_PIN", "sdsupport": "0", "eeprom": "0", "eepromchitchat": "1", "laserbeam": "0", "laserpwrpin": 42, "laserttlpin": 44, "toshiba": "0", "powerconsumption": "0", "powerconsumptionpin": -1, "filamentrunout": "0", "filrunoutpin": -1, "filamentrunoutsensor": "0", "filamentrunoutscript": "M600", "servos": "0", "numservos": 0, "Xservo": "-1", "Yservo": "-1", "Zservo": "0", "angleextendservosX": 0, "angleretractservosX": 0, "angleextendservosY": 0, "angleretractservosY": 0, "angleextendservosZ": 90, "angleretractservosZ": 0, "displays": 0, "invertrotaryswitch": 0, "uilanguages": 7, "uiprintername": "deltah", "easyload": 0, "bowdenlenght": 250, "lcdpurgelenght": 10, "lcdretractlenght": 5, "lcdpurgefeedrate": 3, "lcdretractfeedrate": 5, "lcdloadfeedrate": 20, "lcdunloadfeedrate": 20, "lcdprogressbar": 0, "lcdprogressbarbartime": 3, "lcdprogressbarmsgtime": 1, "lcdprogressbarmsgexpire": 0, "plahotendtemp": 190, "plabedtemp": 60, "plafanspeed": 255, "abshotendtemp": 240, "absbedtemp": 100, "absfanspeed": 255, "gumhotendtemp": 230, "gumbedtemp": 60, "gumfanspeed": 255, "filamentsensor": "0", "filamentsensorpin": -1, "filamentsensorlcd": "0", "filamentsensorextruder": 0, "filamentsensordia": 1.75, "filamentsensormaxdia": 2, "filamentsensormindia": 1.35, "drivesystems": 0, "lengthyextrude": "1", "maxEjerk": 5, "defaultaccelleration": 2500, "defaultretractionaccelleration": 3000, "filamentswitch": "0", "pausepin": 19, "sdsetting": "0" } ========== End configuration string ========== */
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 10, 2015 02:31PM |
// Define this to set a custom name for your generic Delta // Displayed in the LCD "Ready" message #define CUSTOM_MACHINE_NAME "deltah" //=========================================================================== //============================== Delta Settings ============================= //=========================================================================== // Make delta curves from many straight lines (linear interpolation). // This is a trade-off between visible corners (not enough segments) // and processor overload (too many expensive sqrt calls). #define DELTA_SEGMENTS_PER_SECOND 200 // Center-to-center distance of the holes in the diagonal push rods. #define DEFAULT_DELTA_DIAGONAL_ROD 158 // mm // Horizontal offset from middle of printer to smooth rod center. #define DELTA_SMOOTH_ROD_OFFSET 125.6 // mm // Horizontal offset of the universal joints on the end effector. #define DELTA_EFFECTOR_OFFSET 26.4 // mm // Horizontal offset of the universal joints on the carriages. #define DELTA_CARRIAGE_OFFSET 19.2 // mm // Bed Printer radius #define PRINTER_RADIUS 75 // mm //Uncomment to enable autocalibration debug messages #define DEBUG_MESSAGES // Precision for G30 delta autocalibration function #define AUTOCALIBRATION_PRECISION 0.1 // mm // Effective horizontal distance bridged by diagonal push rods. #define DEFAULT_DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET) // Z-Probe variables // Start and end location values are used to deploy/retract the probe (will move from start to end and back again) #define PROBING_FEEDRATE 100 // Speed for individual probe Use: G30 A F600 #define Z_PROBE_OFFSET {0,0,-10} // X, Y, Z, E distance between hotend nozzle and deployed bed leveling probe. #define Z_PROBE_DEPLOY_START_LOCATION {0,0,30,0} // X, Y, Z, E start location for z-probe deployment sequence #define Z_PROBE_DEPLOY_END_LOCATION {0,0,0,0} // X, Y, Z, E end location for z-probe deployment sequence #define Z_PROBE_RETRACT_START_LOCATION {0,0,30,0} // X, Y, Z, E start location for z-probe retract sequence #define Z_PROBE_RETRACT_END_LOCATION {0,0,0,0} // X, Y, Z, E end location for z-probe retract sequence #define Z_RAISE_BETWEEN_PROBINGS 2 // How much the extruder will be raised when travelling from between next probing points #define AUTOLEVEL_GRID 20 // Distance between autolevel Z probing points, should be less than print surface radius/3. //=========================================================================== //=============================Mechanical Settings=========================== //=========================================================================== // coarse Endstop Settings //#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #define ENDSTOPPULLUP_ZPROBE #define ENDSTOPPULLUP_EMIN #endif // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define E_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z_PROBE_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. // If you want to enable the Z Probe pin, but disable its use, uncomment the line below. // Z_PROBE_ENDSTOP must are active if you want Autocalibration #define Z_PROBE_ENDSTOP // ENDSTOP SETTINGS: // Sets direction of endstop when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 // MUST HAVE MAX ENDSTOP #define Y_HOME_DIR 1 // MUST HAVE MAX ENDSTOP #define Z_HOME_DIR 1 // MUST HAVE MAX ENDSTOP #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruder // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruder #define DISABLE_INACTIVE_EXTRUDER false //disable only inactive extruder and keep active extruder enabled // If you motor turns to wrong direction, you can invert it here: #define INVERT_X_DIR false #define INVERT_Y_DIR false #define INVERT_Z_DIR false #define INVERT_E0_DIR false #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false // The position of the homing switches #define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used #define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0) //Manual homing switch locations: #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 210 // Distance between nozzle and print surface after homing. // Travel limits after homing (units are in mm) #define X_MAX_POS PRINTER_RADIUS #define X_MIN_POS -PRINTER_RADIUS #define Y_MAX_POS PRINTER_RADIUS #define Y_MIN_POS -PRINTER_RADIUS #define Z_MAX_POS MANUAL_Z_HOME_POS #define Z_MIN_POS 0 #define E_MIN_POS 0 // MOVEMENT SETTINGS #define HOMING_FEEDRATE {100*60,100*60,100*60,0} // set the homing speeds (mm/min) // default settings // delta speeds must be the same on xyz #define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,100,625,625,625,625} // X, Y, Z, E0, E1, E2, E3 #define DEFAULT_MAX_FEEDRATE {530,530,530,100,100,100,100} // X, Y, Z, E0, E1, E2, E3 (mm/sec) #define DEFAULT_RETRACTION_MAX_FEEDRATE {150,150,150,150} // E0, E1, E2, E3 (mm/sec) #define DEFAULT_MAX_ACCELERATION {3000,3000,3000,3000,3000,3000,3000} // X, Y, Z, E0, E1, E2, E3 maximum start speed for accelerated moves. #define DEFAULT_ACCELERATION 2500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 10000 // X, Y, Z and E max acceleration in mm/s^2 for retracts #define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. //#define HOTEND_OFFSET_X {0.0, 5.00, 0.0, 0.0} // (in mm) for each extruder, offset of the hotend on the X axis //#define HOTEND_OFFSET_Y {0.0, 5.00, 0.0, 0.0} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 10 // (mm/sec) #define DEFAULT_ZJERK 10 // (mm/sec) #define DEFAULT_EJERK 5 // (mm/sec)
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 10, 2015 02:38PM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 11, 2015 02:42AM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 11, 2015 03:03AM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 11, 2015 03:59AM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 11, 2015 04:47AM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 11, 2015 04:53AM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 11, 2015 05:25AM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 11, 2015 06:12AM |
Re: Lo strano caso di X + 10= 3 mm e X -10 = 10mm.. September 19, 2015 01:19PM |
