Re: FuseBox ~$300 CoreXY Printer March 05, 2016 03:56AM |
Re: FuseBox ~$300 CoreXY Printer March 05, 2016 03:45PM |
Re: FuseBox ~$300 CoreXY Printer March 05, 2016 04:39PM |
Re: FuseBox ~$300 CoreXY Printer March 05, 2016 06:15PM |
Re: FuseBox ~$300 CoreXY Printer March 05, 2016 06:41PM |
J-Max
Hi guys,
AlexY, you should try to flex your 1515 structure with a dial indicator. You'll see that the flex is not anecdotic![]()
There's some realy usefull hardware for 2020 or 1515 profiles. For example the 3 ways corners.
Light and cheap version :
Heavy and clean version :
Both minimize the use of extra hardware.
Note, for both of it you can add plugin caps for a clean look.
++JM
Re: FuseBox ~$300 CoreXY Printer March 06, 2016 01:08AM |
Re: FuseBox ~$300 CoreXY Printer March 06, 2016 06:54AM |
Re: FuseBox ~$300 CoreXY Printer March 06, 2016 02:45PM |
J-Max
Hi guys,
@Edvardas : that's not stronger, but it's pretty the same strenght, just you don't spend time to drill holes, and it realy unexpensive <$2/pc
++JM
Re: FuseBox ~$300 CoreXY Printer March 06, 2016 03:07PM |
Re: FuseBox ~$300 CoreXY Printer March 07, 2016 02:41PM |
Re: FuseBox ~$300 CoreXY Printer March 09, 2016 09:26PM |
Re: FuseBox ~$300 CoreXY Printer March 09, 2016 10:06PM |
Re: FuseBox ~$300 CoreXY Printer March 17, 2016 11:02AM |
Re: FuseBox ~$300 CoreXY Printer March 17, 2016 11:06AM |
rmrf
Ax
Just a quick one, Misumi EU is based in Frankfurt. So you can actually order direct. I basically did that for 2020s.
Did you buy through company? Misumi EU seem only to work with companies.
Re: FuseBox ~$300 CoreXY Printer March 17, 2016 02:49PM |
lkcl
rmrf
Ax
i'm getting 1515 extrusion frame through makerbeam.com (openbeam) as well as the corner brackets and corner plates. i'll be hand-cutting the 1m lengths to the required size.
Re: FuseBox ~$300 CoreXY Printer March 18, 2016 05:21PM |
lkcl
hi alex, i thought you might appreciate knowing that i'm creating a derivative of the fusebox, called the "foldable sandwich 200". as the name suggests, it's a foldable, portable 3d printer - there aren't very many of those out there. one thing i've done is raised the XY components up - the y-rod mounts are now on *top* for example - and the motors are on the outside edge not the inner edge. in this way there is a significant amount of extra clearance, so that the overall outer dimensions of the frame can be reduced. i have the width and height at 368 x 390, now.
LM8LUU bearings March 18, 2016 08:57PM |
Re: LM8LUU bearings March 19, 2016 04:59AM |
Re: LM8LUU bearings March 19, 2016 05:38AM |
J-Max
[www.zappautomation.co.uk]
You should consider also Igus Polymer bearings, which are quieter with less play IMHO.
++JM
Re: LM8LUU bearings March 19, 2016 06:46AM |
lkcl
btw does anyone know of a european supplier of the LM8LUU bearings? all the EU suppliers i've found so far only have the LM8UU smaller bearings.
Re: LM8LUU bearings March 19, 2016 06:55AM |
Edvardas
[www.dold-mechatronik.de] This is close and probably even better than lm8luu but it comes at a price.
Re: FuseBox ~$300 CoreXY Printer March 19, 2016 04:37PM |
So I've built one of these after having issues with my Delta printer's limited build size. I'm having Z homing issues.
With X and Y they are working as intended. I'm using the firmware alex included the only modifications are the Steps per MM due to using a Tr8*8 Leadscrew (8mm per rotation)
I can click home X and it moves X to the left toward the limit switch and stops when it hits it.
When I click Home Y it moves towards the back of the machine and stops on the limit switch as intended.
Before tinkering with anything clicking home z lowers the bed to where it sits almost halfway down the printer.
After tinkering it still wont head towards the limit switch for Z
Can someone post their Repetier-host->printer settings->Printer Shape settings? Here's mine.
I'm really stumped by this. I have a Delta printer and it took me quite a bit of googling to figure it out, but it seems like nobody has this similar issue for this type of (corexy) machine. It's probably something insanely stupid and easy to fix, i'm just not seeing it.
Also just in case someone needs it, my configuration.h
Configuration.h
Re: LM8LUU bearings March 22, 2016 12:24AM |
J-Max
++JM
Re: FuseBox ~$300 CoreXY Printer March 22, 2016 02:41AM |
Re: FuseBox ~$300 CoreXY Printer March 22, 2016 10:46AM |
Re: FuseBox ~$300 CoreXY Printer March 22, 2016 12:12PM |
godefroi
I've gotten the itch to build a printer, and I'd kinda like to build a CoreXY variant instead of a Prusa-type (which seems to be the standard default). If I wanted to get a set of the necessary printed parts for the Fuse Box, would that be possible, and where might I look?
Re: FuseBox ~$300 CoreXY Printer March 22, 2016 12:18PM |
Re: FuseBox ~$300 CoreXY Printer March 22, 2016 05:27PM |
Re: FuseBox ~$300 CoreXY Printer March 22, 2016 06:48PM |
widespreaddeadhead
try searching www.3dhubs.com for a printer near you!
Re: FuseBox ~$300 CoreXY Printer March 22, 2016 09:46PM |
godefroi
widespreaddeadhead
Ah, perfect, that's exactly the sort of thing I was looking for, thanks!
I also found a coworker who has a printer (XYZ da Vinci) who is eager to print the parts for cost, so I'm going to try that route for the first couple parts. I'm not sure he'll be able to do much troubleshooting if something's not perfect, though, but 3dhubs has quite a few "Hubs" very close to me, so I'm sure I'll get it worked out. Thank you!
