Re: FuseBox ~$300 CoreXY Printer April 08, 2016 10:56AM |
Re: FuseBox ~$300 CoreXY Printer April 09, 2016 09:20AM |
lkcl
phord
I was hoping your redesign would include a useful extruder for 3mm
ok i've _had_ to replace the metal arm with a printed one so that's now in the repository. testing it now.
Re: FuseBox ~$300 CoreXY Printer April 10, 2016 03:12PM |
Re: FuseBox ~$300 CoreXY Printer April 12, 2016 11:27AM |
phord
Re: FuseBox ~$300 CoreXY Printer April 12, 2016 06:43PM |
lkcl
ok phord, i've created a set of build instructions for the 53:13 geared extruder, here: [hands.com] - it includes photos and a commissioning video, i got 120mm/min (12.75mm3/sec) at 210C cleany. at 150mm/min it started skipping. the usual maximum for standard E3Dv6 extruders is around 10mm3/sec. that's with a 0.4mm nozzle, 1/4 microstepping and a 1.1A current limit.
Re: FuseBox ~$300 CoreXY Printer April 12, 2016 08:28PM |
phord
lkcl
Nice!
You've clearly put a lot of design work into this and I'm excited to try it out. I have an extra MK8 gear here and about half the other needed parts. I'll start sourcing the assortment of screws, nuts and bearings next week.
In the meantime I reworked the schnozzle for 3mm but it is still direct drive. I haven't got as far as trying it out yet, and I have a catalog of about 19 things that can cause an extruder to fail, so I believe you when you say it will skip. :-)
It does make me wonder why I'm still using 3mm filament. Maybe it's because I have a half-dozen e3d's and J-Heads in my spares kit.
I assume you mean 120mm/sec instead of 120mm/min above.
But I'm not clear on how you calculated the volume rate. nozzle=0.4mm, radius=0.2mm, area = PI *r^2; 120mm * pi * (0.2mm)^2 = 15mm^3. That's not taking into account the layer height, but in your video you were only extruding into empty space, so I assume the normal "layer*nozzle*length" doesn't really apply.
Re: FuseBox ~$300 CoreXY Printer April 15, 2016 03:37PM |
Re: FuseBox ~$300 CoreXY Printer April 15, 2016 04:09PM |
ivo95
I will start to order parts for FB2020 by Ax printer in a few days, and since that is my first printer i have few questions.
Ax is planning to upgrade Z axis smooth rods from 8 to 10mm and i will do the same, but idk if i should also upgrade leadscrew to 10mm or stay with 8mm?
Is motedis.com&www.dold-mechatronik.de leadscrew/nut worth the price (leadscrew is 5€ & brass nut is 14€) or should i order cheap $7 chinese leadscrew/nut?
Is mk8 full metal extruder kit good or waste of money?
Re: FuseBox ~$300 CoreXY Printer April 15, 2016 06:29PM |
lkcl
z-rods to 10mm? mmm.... mehh. i wouldn't say that's a high priority. what completely overshadows that is a design flaw in the FuseBox, which i've documented here: [reprap.org]
Re: FuseBox ~$300 CoreXY Printer April 15, 2016 06:54PM |
ivo95
lkcl
I think that ax (http://www.thingiverse.com/thing:1313587) already fixed that problem in his design: [thingiverse-production-new.s3.amazonaws.com]
Re: FuseBox ~$300 CoreXY Printer April 15, 2016 08:48PM |
lkcl
ivo95
lkcl
he's made an attempt to do so, but that's not diagonal bracing, is it? yes he's moved the bar back, yes it's 20mm extrusion, but... let me think.... if the crossbar was soundly attached using the trick that Edvardas recommended, which is to machine the ends of the crossbar to ABSOLUTELY dead-flat, then drill holes in the side-bars and put allen-key bolts through, it's described here:
[forums.reprap.org]
*if* he did that, *and* the forward-facing bars were somehow rigidly attached to the plastic in several places, *then* any push on one side would turn into a rotation of the linear bearings, which would be resisted by the z-rods and you've solved the problem.
but otherwise, ax's design is critically-dependent on the shear-strength of the plastic connecting the cross-bar, and i don't believe it's in any way sufficient.
diagonal cross-bracing from the very top *and* bottom of the linear z-rail parts, all the way to the middle z-nut on both left *AND* right sides is about the only way to stop see-sawing. and even then, with the Fusebox only having a single 45mm bearing spanning 140mm it's still pretty touch-and-go.
with the Sandwich200 i at least stand a chance because i have had to put in a whopping 75mm worth of linear bearings (one LM8UU and one LM8LUU).on each side.
Re: FuseBox ~$300 CoreXY Printer April 16, 2016 04:54AM |
ivo95
He is also using longer supports with 4 LM8UU's.
BTW what do you think about removing printed z-rail parts and just use 50x20 angle bar (http://www.motedis.co.uk/shop/Semi-finished-products/Light-metal-profiles-not-anodized/Angle-bars-not-equal-sided/Angle-bar-not-anodized-50x20x2mm::999993422.html) with one SCS10LUU on each side (http://www.robotdigg.com/product/423/SCS10LUU+Slide+Unit)?
Re: FuseBox ~$300 CoreXY Printer April 16, 2016 08:15AM |
Re: FuseBox ~$300 CoreXY Printer April 16, 2016 08:35AM |
Or maybe 80x80x3mm (cut to 80x30) with 2 LM10UU per side in printed housing to reduce weight...
I never held those bearings in my hand so i don't know how stiff they are on the rods, so i would really like to hear your opinion.
Do we need one or two per side when they are connected with 2mm/3mm alu plate,
is that too much weight for z motor to handle...?
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 06:26AM |
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 07:17AM |
Ax
To clear things up with the FB2020. I've actually substituted out the plastic brace for another cross bar
using the standard bracing brackets, however, this is likely to change again and I'm probably going to change the brackets out to a different design and shift the brace back when I have sorted 3 point levelling and use more bracing or recommend a 3rd brace in the middle to stiffen it up if keeping with the 4 point version. I may slip a couple of plastic braces in mine in the middle to try and tighten it up a bit more as I'm finding that while the front brace helps, there's still movement, which I want to get rid of.
I may even look at getting an aluminium bed plate and brace cut, which would take a lot of the twist out as well.
As for the 10 or 12 mm Z smooth rods, I'm doing this too reduce wobble and stiffen the Z up further, after speaking to a few people 8mm rods on a cantilever bed = bad. Take a printer like the Ultimaker 2 or other higher end commercial printer that uses a cantilever design. The Z is will use 10 or 12mm rods. I'm yet to redesign things as I've not had time or money to get parts in, so it could be a little while, so I'd stick with the 8mm for the moment. I'll freely admit I have issues with the Z axis and levelling and I'm looking at improving it greatly.
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 10:37AM |
lkcl
Ax
photos would help, but i can tell you, right now, you're never *ever* going to get a stiff frame until you've braced *all five* frame faces (i filled them all in with hardboard, mounted on 16 points *per board*) and put original Misumi1515 brackets in the top corners or used those 50mm triangular folded steel right-angle brackets i mentioned earlier. they're a pain to find on ebay (keyword searches don't cut it) so here's a link [www.ebay.co.uk]
it's not clear here if you're referring to the frame or to the printbed.
yes i got an Alu MK3 from reprap.me, including the clear perspex mounting, and because of that i am wondering why the heck i put in the extrusion H (cross) bar under the middle of the bed. it's completely pointless where it is, and ineffective anyway. now with the Alu MK3 and perspex, the bed's absolutely rock-solid, the two forward-facing bars do not move *at* all.
but, more than that, remember that i've done a "folding" design so there are additional bars, left and right, at an angle of 45 degrees running *forwards* to the middle of the bed, running to the bottom of a 75mm long linear assembly (see picture below). these are waaaay more effective than having bits of plastic sticking out of 45mm vertical linear assemblies, where there are only 2 M3 mount-points a few centimetres apart. don't even know how much it is, i completely ignored the original Z-Rail design.
howeverrrr... i can put even a screwdriver into the corner of one of the adjustment screws and i must be getting around 0.1mm of see-saw effect, the cantilevering around the Z-Nut (70mm each side) is so large.
ok that's good to know, about using 10 to 12mm rods.
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 11:31AM |
Ax
I was talking about the bed. I've actually just converted it to 3 point levelling, with an extra plastic brace in the middle. This has made the bed a lot more rigid, so it doesn't see-saw from the main bed legs and so much more easy to level compared to a 4 point bed.
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 11:55AM |
lkcl
Ax
cool - that would be good to see, can you take some pictures?
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 01:13PM |
Ax
I'm planning on updating things on the Thingiverse page in a bit, once I have the RRD controller fixed properly. You can actually knock 15mm off the main legs of the bed with the 3 point system as they don't need to be as long, which may cause a little extra expense, due to them being shorter, but the pay off is that it's really simple to level.
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 05:13PM |
lkcl
Ax
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 05:29PM |
Ax
Thingiverse updated. Bed images uploaded..
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 05:35PM |
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 05:55PM |
lkcl
Ax
pppink - niiice! i'm a fan of bright colours too
ok so a long cross-piece to keep the cable out the way... what else is that for? if you have dual cross-bar (front and back it looks like) the plastic cross-piece shouuuldn't be needed.... instead of the corner-plastic pieces, have you thought to use the trick of drilling from the outside then putting an allen-key bolt down into the (self-tapping) end of the crossbars? edvardas tells me that that technique is amazingly strong, but you have to make sure the ends are machined (or filed) dead-level.
the bed looks pretty sturdy, so you'd not have the problem of bed-warping or twisting throwing the z-levelling out...
looks really nice, Ax.
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 06:57PM |
lkcl
oh, oh, another way you could do this, without needing to cut (large) aluminium L-brackets, is, use these [www.ebay.co.uk] right-angle corner-braces in combination with 2 upright 75mm (or so) extrusions, and a long horizontal extrusion to make an H, you could create a simple, small z-nut holder which would mount a z-nut close to the horizontal extrusion, and then create mounting brackets for 4 linear bearings. or, use that aluminium-drilling technique instead (put an allen-key hex-bolt through one extrusion into the self-tapping hole down the middle of the other). i really like the L-bracket way, though the cutting and drilling is making me think twice about using it.
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 07:54PM |
ivo95
filipe solution is the best: G&C Printer, you can probably sit on that bed , so i will do it like him.
12mm rods, 4xSCV12UU bolted to 20x60 profile
belt judder due to teeth being on bearings April 17, 2016 07:57PM |
Re: FuseBox ~$300 CoreXY Printer April 17, 2016 08:40PM |
Re: FuseBox ~$300 CoreXY Printer April 20, 2016 11:39AM |
Re: FuseBox ~$300 CoreXY Printer April 20, 2016 11:09PM |
