Re: Design nearly done - construction started... February 19, 2014 05:23PM |
Re: Design nearly done - construction started... February 19, 2014 07:16PM |
Re: Design nearly done - construction started... February 19, 2014 07:25PM |
hollow would be less SAG but if you have to go with solid give it a try it should be rigid but tend to droop just a little in the middle. If you could find the right hollow rod and then just do stub ends that pressed in or threaded would be to best. Like I said in the above post it is TB 6600 which I think is the newer version. Yeah the Chinese new year sets them back a monthQuote
Maxx Mayhem
If it is the same chip, there could be an issue. The fellow who runs MassMind and I spoke last year when I was building the driver, and he told me that the particular Toshiba chip was a one off, and that he was in the process of developing a new product based on another chip. I had planned to get back to him as soon as I got things running, clearly the time frame has expanded slightly....We will see how things go with pololus on the 17s, because A. I need so many of them, and B. because I need to stuff them into a small space. With the 9 pololus and the one 6064, ( for the 2) 23s)I am hoping things will work the way I want. So far, the only thing I have tested is the 6064, with the 23s and only in a test mode, not with controls. My concept is - with the sheer amount of fabrication involved, even a catastrophic failure at the initial start up of the electronics ( which I doubt, as all turns on and lights light up) would be a small issue. As the extruder assembly nears completion, my prime interest now is finalizing the design of and completing the construction of the carriage, all without losing cubic inches. Your opinion on something please... I know you have a preference for hollow rods, but due to the fact I want to keep my adjuster system intact, I need to use a turned down solid rod. For my long axis I am planning to move to a 25 mm rod from a 12 mm rod. An online calc tells me to expect about 1/8 the flex... Wondering if you have any experience that you could share regarding this...Thanks On another note it seems I have been waiting forever for a barometric pressure gauge from china, I want to pair it with a picoduino and led matrix to make an altimeter for small rockets...
Re: Design nearly done - construction started... February 19, 2014 08:20PM |
Re: Design nearly done - construction started... February 21, 2014 01:45PM |
Re: Design nearly done - construction started... February 21, 2014 03:20PM |
Re: Design nearly done - construction started... February 21, 2014 06:58PM |
Re: Design nearly done - construction started... February 21, 2014 08:45PM |
Re: Design nearly done - construction started... February 21, 2014 09:28PM |
Re: Design nearly done - construction started... February 21, 2014 09:41PM |
Maxx Mayhem
Instead of using drive belts as belts, I will epoxy them to solid channels and use them to make a rack and pinnion drive for the X, Y axis.
In this way, I hope to eliminate slop, stretch, and the inherent backlash from the belts.
Re: Design nearly done - construction started... February 21, 2014 09:51PM |
Re: Design nearly done - construction started... February 22, 2014 02:43AM |
hello Maxx I think I would give the belt as a rack some more thought I think he's a right. Plus at best you're only going to have one tooth engaged, unless you have an enormous pinion one tooth of even a good size belt is very flexible. And If you go with a metal one I think it's going to be very noisyQuote
A2
Maxx Mayhem
Maybe this has been discussed already...?
Belts are designed to operate wrapped around a pulley, and when sized for the job the backlash is not significant.
Laying a belt flat, and using it as a rack with a pulley rolling on top will have some backlash.
A large GT2 belt, or multiples shouldn't have meaningful backlash.
Neat project, I enjoy your pics!
Re: Design nearly done - construction started... February 22, 2014 04:17AM |
Re: Design nearly done - construction started... February 22, 2014 08:03AM |
Re: Design nearly done - construction started... February 22, 2014 12:41PM |
Re: Design nearly done - construction started... February 22, 2014 01:21PM |
Re: Design nearly done - construction started... February 22, 2014 05:14PM |
Re: Design nearly done - construction started... March 01, 2014 11:41AM |
Re: Design nearly done - construction started... March 04, 2014 12:06PM |
Re: Design nearly done - construction started... March 04, 2014 12:22PM |
Re: Design nearly done - construction started... March 04, 2014 02:42PM |
Re: Design nearly done - construction started... March 04, 2014 03:58PM |
Re: Design nearly done - construction started... March 04, 2014 04:30PM |
Re: Design nearly done - construction started... March 04, 2014 04:44PM |
Re: Design nearly done - construction started... March 04, 2014 06:15PM |
Re: Design nearly done - construction started... March 12, 2014 06:48AM |
Re: Design nearly done - construction started... March 12, 2014 01:38PM |
Re: Design nearly done - construction started... March 23, 2014 07:53PM |
Re: Design nearly done - construction started... March 26, 2014 02:12PM |
Re: Design nearly done - construction started... March 26, 2014 02:33PM |
