Re: Folger Prusa i3 Kit from ebay January 21, 2015 04:11PM |
Re: Folger Prusa i3 Kit from ebay January 21, 2015 05:12PM |
Re: Folger Prusa i3 Kit from ebay January 21, 2015 06:00PM |
Will be printing that extruder assembly and spool holder when I get home..Quote
MindRealm
One of the first replacements I made on my FolgerTech Prusa i3 was the extruder. I printed THIS ONE and never looked back! It uses the parts from the stock extruder, plus a couple screws and a spring. It puts sufficient pressure on the filament and facilitates filament changes and clearing of jams.
I have made several mods to my printer - take a look at the linked photos in my signature.
Also, check out the new group on Thingiverse dedicated to this printer >> HERE
Re: Folger Prusa i3 Kit from ebay January 21, 2015 06:49PM |
Re: Folger Prusa i3 Kit from ebay January 21, 2015 10:24PM |
JSR82
So I would like to do the auto bed leveling upgrade to my printer. I have the servo and I found where to jumper to enable servo control on the ramps and where to plug the servo in. My question is do I wire the switch I am going to use for my Z probe switch to NO or NC? Also, please confirm that with the Z probe I want to put the two wires for the switch on the outside two pins of the MIN Z axis endstop pins? Also, I have read various places you can use the regular Z endstop in conjunction with the Z probe switch to be sort of a failsafe. Can someone advise how to go about wiring that? Sorry if this is the wrong thread for this stuff...
Re: Folger Prusa i3 Kit from ebay January 22, 2015 04:08AM |
Re: Folger Prusa i3 Kit from ebay January 22, 2015 10:31AM |
Zavashier
Printrbot use Hall effect sensors because its printing bed is made out of steel. If you use glass, you won't measure the good distance. Your heatbed and your glass could have pretty different shapes.
Re: Folger Prusa i3 Kit from ebay January 22, 2015 02:17PM |
MindRealm
Re: Folger Prusa i3 Kit from ebay January 22, 2015 02:40PM |
Here you go. I printed it last night, exactly what I was looking for.Quote
NukedWorker
Final question. Do you have a link to that spool holder as well?
Re: Folger Prusa i3 Kit from ebay January 22, 2015 03:16PM |
Re: Folger Prusa i3 Kit from ebay January 23, 2015 01:03AM |
bengele
Not sure if this is confusing people or not but I took me a bit to figure it out.
What I realized is that in Pronterface you are not giving it a command to move left/right, forward/backward, and up/down you are telling it to move +steps or -steps. That means once you have homed your printer (moving the bed all of the way forward and the head all of the way to the right) the coordinates of your printer are at 0,0,0. If you want to move the head to the left (increasing the value of its coordinate) you need to use the +x button in the Pronterface interface which happens to be the right button. This is somewhat confusing but makes sense if you are not paying attention where the buttons are on the screen but what they do.
Re: Folger Prusa i3 Kit from ebay January 23, 2015 02:16AM |
louspinuso
bengele
Left should be negative. Left is always negative. Just like any Cartesian plane. And down is also negative. Your y axis position is the position of where the head is relative to the bed, not the direction that the bed moves. Moving the bed towards the back of the printer is moving down your y axis or negative. If your top right corner of the bed is 0,0,0 (home) then your bottom left is -200,-200,0. This will cause prints to be backwards and may not matter if you are printing certain items but if you print something that needs to face a specific direction you're going to have a bad day.
Re: Folger Prusa i3 Kit from ebay January 23, 2015 09:33AM |
Re: Folger Prusa i3 Kit from ebay January 23, 2015 09:39AM |
Re: Folger Prusa i3 Kit from ebay January 23, 2015 09:49AM |
Re: Folger Prusa i3 Kit from ebay January 23, 2015 11:09AM |
bengele
louspinuso
bengele
Maybe I am missing something but I can't see how this would mess up a print. If I am standing behind my printer then the top right becomes the bottom left. In fact that is probably an easier way of explaining what I was trying to explain before. That is that when using the Pronterface controls you have to imagine that you are behind the printer and not in front of it like I would expect most people are.
Like you said this causes the print to print on the bed backwards but it is a 180° rotation. If it was flipping the top and bottom but not the left and right I could see that as an issue.
BACK +--------------------+ | A B | | | R L | | I E | | G F | | H T | | T | | | | | | | C D | +--------------------+ FRONT
... Z Max ... Z Min ... Y Max ... Y Min ... X Max ... X Min
... Z Max ___ Z Min ___ Y Max ... Y Min ... X Max ___ X Min
... Z Max ___ Z Min ___ Y Max ... Y Min ___ X Max ... X Min
... Z Max ___ Z Min ... Y Max ___ Y Min ... X Max ___ X Min
... Z Max ___ Z Min ... Y Max ___ Y Min ___ X Max ... X Min
#define INVERT_FOO_DIR falsebut not both, as that will basically undo what you're changing. If you are going to flip the plug, make sure the power is off.
#define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR 1
Re: Folger Prusa i3 Kit from ebay January 23, 2015 05:01PM |
Re: Folger Prusa i3 Kit from ebay January 23, 2015 07:53PM |
Newtoprinting
Recently I've had longer prints fail because the extruder motor would get hot and then melt the PLA before going to the hot end and jam. I lowered the voltage on the pot and the motor would be cool but then there wouldn't be enough power to feed the pla into the hot end and it would jam. Then I tried a big desk fan to keep the motor cool and it worked but thats just a temporary fix. Does anyone have any suggestions. The 40mm fan the folger tech extruder comes with isn't powerful enough to keep the motor cool.
Re: Folger Prusa i3 Kit from ebay January 24, 2015 03:47AM |
Re: Folger Prusa i3 Kit from ebay January 24, 2015 12:40PM |
Re: Folger Prusa i3 Kit from ebay January 24, 2015 01:29PM |
Re: Folger Prusa i3 Kit from ebay January 24, 2015 08:09PM |
Tardisrepair
Hello everyone
Thanks for the thread, tons of great information here.
My kit should be arriving in about a week, this will be my first 3d printing venture.
Can anyone confirm what was stated earlier in the thread.... that the Folger configuration file works correctly.
Thanks
Re: Folger Prusa i3 Kit from ebay January 25, 2015 09:25AM |
Re: Folger Prusa i3 Kit from ebay January 25, 2015 02:31PM |
Anyone have any good pla settingS for slicer. My first layer seems to be the issue.
Re: Folger Prusa i3 Kit from ebay January 25, 2015 03:53PM |
Re: Folger Prusa i3 Kit from ebay January 25, 2015 07:18PM |
JSR82
Re: Folger Prusa i3 Kit from ebay January 27, 2015 10:13AM |
Re: Folger Prusa i3 Kit from ebay January 27, 2015 03:15PM |
Re: Folger Prusa i3 Kit from ebay January 27, 2015 04:24PM |
Re: Folger Prusa i3 Kit from ebay January 28, 2015 03:37PM |
