Re: Migbot Prusa i3 Unofficial Support Thread August 15, 2015 06:56PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 15, 2015 09:18PM |
wallygator801
Alright guys,
I finally got the new ramps v1.4 board installed and everything is working. Now if someone could help me get the home position set I would be very grateful. I am using repetier host and when I hit the home buttons it tries to extend well beyond where it should stop.
Thank you.
Re: Migbot Prusa i3 Unofficial Support Thread August 15, 2015 09:20PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 15, 2015 09:29PM |
veaceonee
Got a new development...
Spent some time calibrating the extruder, and switched to a white PLA.
Turns out, the lumps Iv been getting is burned plastic. Anyone able to explain why this is occuring??
Re: Migbot Prusa i3 Unofficial Support Thread August 16, 2015 12:31AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 16, 2015 12:33AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 16, 2015 01:25AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 17, 2015 08:49AM |
Yakuza
Josh have you check to make sure the belt pulley isn't loose? Its sounds like that would be the cause. Check all of them to make sure you have that out of the way.
Re: Migbot Prusa i3 Unofficial Support Thread August 18, 2015 02:47PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 19, 2015 01:01AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 19, 2015 02:20AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 19, 2015 02:57AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 19, 2015 03:28AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 19, 2015 03:29AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 19, 2015 10:22AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 19, 2015 09:40PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 20, 2015 06:02AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 20, 2015 08:00AM |
evetanlm
Hi Josh,
here is the pump, hehe. It's beautiful, you are an artist..
Hi Everyone,
I have a question, I have just get a E3D V6 extruder, right now the extruder is fix on my migbot but the issue is it reverse, should be extruder but now it retruder, can anyone advise me on this. Appreciate anyone that can help... Have a nice day!
Re: Migbot Prusa i3 Unofficial Support Thread August 20, 2015 08:41AM |
Hope these help someone. |
Re: Migbot Prusa i3 Unofficial Support Thread August 20, 2015 09:28PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 20, 2015 09:30PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 20, 2015 10:04PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 22, 2015 03:30PM |
evetanlm
my sd card slot is only recognize one type of card call transcend, others never. see attach for reference
Re: Migbot Prusa i3 Unofficial Support Thread August 23, 2015 01:44PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 24, 2015 01:40AM |
I have had both x and y carriage endstop broken once. Well actually it was the soldering that broke off not the switch itself from the root of the pin. After the second one i made some modifications on the cable harness and now problem free for few months.
Anonymous User
Re: Migbot Prusa i3 Unofficial Support Thread August 25, 2015 10:18AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 25, 2015 12:48PM |
3DST
We also had to re-solder the terminals on ALL THREE (X,Y and Z) Limit Micro-switches. Then we coated them with a silicone paste and made sure they DON'T MOVE.
Re: Migbot Prusa i3 Unofficial Support Thread August 25, 2015 10:29PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 26, 2015 01:27PM |
jbehan
Ugh...dang ABS, why can't I print it as well as PLA? Getting nice looking ABS prints but they can be pulled apart, how do I get the layers to stick?
FYI: I had an ABS print that took a couple hours to complete, de-laminate on a few layers so I clamped it (layer compression) and wicked in some thin CA adhesive. Worked like a charm!
Josh
Re: Migbot Prusa i3 Unofficial Support Thread August 26, 2015 04:40PM |
