Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 08, 2015 12:34AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 08, 2015 10:02AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 08, 2015 10:05AM |
animoose
I'm going to start on the electronics soon, and have been unpacking the boards. The quality of the RAMPS board is really horrible..
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 08, 2015 10:14AM |
animoose
I see back right in step 8 of the config guide. Where did you see back left?
Clip the 3D Printed End Stop Mount to the rear of the printer on the right most Chromed Rod about an inch from the SK8.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 08, 2015 04:50PM |
markts
animoose
I'm sorry! My bad - you're right - I'll edit my post for posterity.
As I thought about it, it finally dawned on me that the limit switches are at the home positions. Duh. But if the Y limit switch is in the back
won't the home position for Y be in the front? (bed moved all the way BACK) ??
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 02:36AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 04:59AM |
JoeH
So I finished assembling the printer LATE last night. Tonight, I followed the config guide, and everything went fine till I got to step 8... homing the X and Y Axis.
The Y axis homed fine, but the X did not. Every time I click home X, it only moves about 10 mm (didn't measure). I can keep clicking home till it get to the limit switch. When it gets to the limit switch and triggers it, it won't move left anymore. It basically gets stuck at the limit switch (trying to move it away), but the X position display changes as if it's moving.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 09:44AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 09:45AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 10:14AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 10:31AM |
The7ank
Man, I'm having all kinds of issues with this kit. One of my lower frame pieces is the wrong size and the bed bearing holders are just terrible. The bed doesn't move smoothly and bends the rods out of shape. Could someone please post the exact measurements for each of the components on the 2 375mm beams? The only thing that had an exact measurement was the upper frame.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 10:58AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 11:00AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 12:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 04:56PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 05:26PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 05:33PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 09, 2015 05:35PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 01:58AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 10:39AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 01:31PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 06:49PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 07:09PM |
retiredcompguy
Contrary to the pictures in Steps 9 and 14, the wire harness on the 4.8 motor (Y axis) should face the front of the printer, not the top. The wires would be uncomfortably close to the heated bed, and you would need to remount the motor. The builders corrected this by the picture in Step 20.
This is just a nit, I think the manual overall is great for this stage of the project!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 07:35PM |
markts
And for those that purchased the LCD display, don't bother trying to make it work with the version of Marlin on the Google drive. I fought with it for days then sucked it up and downloaded the latest version of Marlin. Had to go through all the pain of fixing the configuration.h file again, including direction/end stops, etc, but the display came right up.
Then the printer firmware immediately "rolled over" via kill(). I had to hunt down and disable the "kill" button in the code since my LCD panel doesn't have it populated and apparently it was triggering it. Now the display works.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 08:15PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 10:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 11:02PM |
stanger2k
markts
Can you share your Marlin code?
#if defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL) #define KILL_PIN -1 <---- I don't remember what this was set to, but I changed it to -1 to turn off the pin #else #define KILL_PIN -1 #endif
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 11:03PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 10, 2015 11:06PM |
