Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 12:27AM |
JoeH
Unshockable, try switching the Home X end stop in Repetier to max instead of min... it's under Printer Settings --> Printer Shape. It was late last night when I got it working, and I forgot I did that. If I change it to min, which is default, the printer behaves exactly as in your video.
My next issue is the Y axis keeps "skipping" after about 10 minutes of printing. I think the driver is getting too hot and going into thermal shutdown for a split second.
What voltages do you guys have set on your drivers (adjusting pot to ground)?
Mine are set to:
X:0.517 V
Y:0.647 V
Z:0.677 V
E:0.667 V
X is set lower because it keeps getting very hot.But the rest of the motors don't.
I'm going to add a fan to blow across the drivers and see if that helps any.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 01:34AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 03:23AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 09:15AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 11:24AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 11:43AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 02:01PM |
animoose
A follow up to an earlier post: if you want to see what I mean by the RAMPS board being horrible, look at this picture: [2.bp.blogspot.com].
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 02:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 02:38PM |
Dan_FolgerTech
animoose
We've switched vendors and our new ones are also color coded. We are pretty happy with them, I don't know what happened with our previous vendor but the soldering was starting to get pretty sloppy towards the end it seems.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 03:01PM |
JoeH
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 03:04PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 03:08PM |
Unshockable
JoeH
That gets the travel working, although I am still seeing the bounce on homing.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 03:09PM |
JoeH
Adding a fan to blow accross the drivers fixed the thermal shutdown issue. I'll try to lower the voltages and see if that works. I'll probably still keep the fan since it can't hurt
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 03:35PM |
markts
Unshockable
JoeH
You got a spare limit switch with the kit, right? Might be worth swapping it out. Sounds like strange behavior to me.
Or hit home then click the switch with your finger to see if you get the same "bounce" ?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 03:52PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 04:01PM |
Unshockable
markts
Unshockable
JoeH
Replacing the limit switch has no effect. Manually triggering the switch halfway through the home travel creates the bounce mid-run. If I hold it, it stops at the apex of the bounce. If I press and release quickly, it travels towards the limit switch for about 10 units at a much slower speed.
//homing hits the endstop, then retracts by this distance, before it tries to slowly bump again: #define X_HOME_RETRACT_MM 5 #define Y_HOME_RETRACT_MM 5 #define Z_HOME_RETRACT_MM 2
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors //#ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX // #define ENDSTOPPULLUP_XMIN // #define ENDSTOPPULLUP_YMIN // #define ENDSTOPPULLUP_ZMIN //#endif //#ifdef ENDSTOPPULLUPS // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN //#endif
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 06:34PM |
markts
Check these in configuration_adv.h?
markts
What apparently fixed it was this in configuration.h (mine is essentially the same):
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 08:11PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 08:55PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 11, 2015 11:50PM |
markts
stanger2k
markts
And for those that purchased the LCD display, don't bother trying to make it work with the version of Marlin on the Google drive. I fought with it for days then sucked it up and downloaded the latest version of Marlin. Had to go through all the pain of fixing the configuration.h file again, including direction/end stops, etc, but the display came right up.
Then the printer firmware immediately "rolled over" via kill(). I had to hunt down and disable the "kill" button in the code since my LCD panel doesn't have it populated and apparently it was triggering it. Now the display works.
Can you share your Marlin code?
Sure - what do you need?
I downloaded the latest Marlin code and made changes in configuration.h for the printer itself, then pins.h for the display. I made the change below:
#if defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL) #define KILL_PIN -1 <---- I don't remember what this was set to, but I changed it to -1 to turn off the pin #else #define KILL_PIN -1 #endif
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 12:31AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 01:55AM |
Unshockable
JoeH
markts
JoeH
Did you print a mount for it? I saw a couple that might work well that I'm going to print tonight.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 10:49AM |
Unshockable
markts
Yeah, I know (which is why I said mine was essentially that). When I ported my configuration file to the newer version of marlin I had to uncomment the right ones is all.
What's the correct set to have active?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 10:51AM |
stanger2k
I was looking to see if you could upload a copy of the Marlin code to save me the time of merging the settings from dropbox with the newest code of Marlin.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 11:38AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 03:22PM |
plrmaker7
Maybe I am reading this wrong but according to the tuning guide - the A4988's should be set to .280v? I have mine all set to .280v and all seem fine - except the stepper motor on the X axis gets very hot. The drivers, however, stay cool. Thoughts???
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 03:31PM |
JoeH
plrmaker7
I could be totally wrong, and feel free to correct me, but here's what I came up with...
I looked at the tuning guide, and the motor specs again (assuming the motors FogerTechs sells are the ones in the kit)... The X, Z, and E motors are rated at .4A, and the Y motor at 1.5A. Following the calulation in the guide, vRef for X,Z, and E should be around 0.160V (0.4*8*0.05). And Y should be 0.600V (1.5*8*0.05). But, the Z is running 2 motors, so you'd have to double the voltage to 0.320V, and effectively the current to drive both motors.
I think I'm going to try that tonight and see if it helps the X motor heating issue any.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 03:40PM |
markts
JoeH
plrmaker7
Can you post a pointer to this tuning guide?
I suspect you're mistaken in terms of doubling the voltage because you have two motors (though I may also be wrong). You want the same voltage to each motor and I have to believe they are wired in parallel, not series. True the current would be twice a single motor, but that would be at original 0.160v. I think doubling the voltage is only going to make things hotter.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 03:48PM |
dougal1957
markts
JoeH
plrmaker7
I also suspect that the 1.5A motor should be for the Extruder and not the Y Axis.
Can't comment on the way the Z motors are wired as I dont have one of these.
Doug
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 12, 2015 05:52PM |
markts
