Re: Folger Tech 2020 3DPrinter July 01, 2015 02:37PM |
[email protected]
This file would be good for pimped my ride kind of show.
Imagin mounting your electronics in a transparent gerrycan and have fluorescent cooling non conducting fluids, fanned with bubles ). I call my. Projects landing a can on a plate.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 01, 2015 04:20PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 01, 2015 09:00PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 01, 2015 09:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 01, 2015 10:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 01, 2015 11:08PM |
msaeger
Working on wiring now and I am to the point where they ask you to connect the heated bed and hot end thermistors. The instructions say to attach the molex connector to them both yourself. Mine has the connector already on the heated bed thermistor but the hot end is bare and they didn't send any loose molex connectors.
How did everyone else's kit come?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 12:15AM |
Garben
msaeger
I had some old servo connectors that I cut and soldered to the end of mine. I think I recived the hot end connector and not one on the bed or maybe it was the same as yours, but I was missing one.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 02:22AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 08:40AM |
msaeger
therippa
Did anyone else have problems with step 16? The motor brackets are held in with three bolts/t-nuts (two on the top rail, one on the side). In the instructions, when they lift the motors all the way up, it looks like they remove the bolt on the side rail. Anyway, after putting it all together, and using all 3 bolts, the z-axis chrome rods are definitely bowing a little bit to fit into the acrylic motor mount and the mount on the bottom rails. The only way I can get it to not bow is remove the side rail screws. Also, how the hell are you supposed to tighten the screws begin the chrome rods?!
Also, does anyone have any tips on how to align the y-axis rods?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 11:39AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 12:27PM |
therippa
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 12:29PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 01:27PM |
animoose
Has anyone tried running the printer at faster speeds than the ones in the default Slic3r config supplied by Folger? (For example, 40mm/s for perimeters). Any risks in doing so?
go_gn
Just printed my first hollow cube and a batarang last night. Didn't heat the bed since I'm using PLA so having some first layer sticking issues but they came out nice.
I'm having a strange problem with the X axis which I'm 100% sure is software, but I can't seem to figure out how to fix it.
Whenever I switch on the printer, I home my axes first. If I try to home the X axis first, instead of moving to the right and hitting the endstop, the printer moves maybe 5 to 10 mm to the left and stops. The red numbers on the manual control turn black and become 200 ( which is the max value for X axis).
The printer thinks it has homed but it actually is far from it. I don't understand why it thinks it has homed without hitting an endstop. If I dont hit home and try moving it towards the endstop using manual controls, it does not move. For some reason it thinks it is on the far end of the limit without any input. Is there a way to set the initial software position(before homing) in the firmware?
The strange thing is: If I home the Y and Z axes first (separately) and then try the same procedures for X axis, it works fine.
I can't seem to deduce why this would happen from the config code.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 02:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 10:42PM |
Mine arrived a few days ago and I've finished the assembly - still need to get the electronics set up.
I've kind of been doing my own thing but the only dramatic alteration is the corner brackets.
So far the kit has been pretty good, the only complaint I've got is that the Z linear bearing holders were shitty prints and I had to carve them out with a knife.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 11:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 11:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2015 11:43PM |
mel0n
Just curious, is anybody else's printer really loud? Mine has been really loud, and getting progressively louder the more I print with it. Its completely related to the X-Axis and its a really loud vibration. I have tried messing with belt tension to make sure its not too tight, but the sound is still loud. If I grab the x axis stepper and hold it firmly, my hand absorbs most of the vibration and the sound goes away. I am looking into stepper motor dampeners, but none of my other steppers are anywhere near as loud... My Y is nice and quiet even during rapid movements that usually have my X axis screaming.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 12:14AM |
animoose
therippa
I found this tricky too. I didn't have to bow the rods, but it was a tight fit. It helped to loosen the set screw on the L-piece that holds the frame together and very slightly move the vertical piece of 2020 - just 1-2 mm made mine fit much better.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 12:50AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 01:56AM |
msaeger
I got it together and the wires connected. I was able to program the aurdino and tried moving everything manually in repetier host and manually hitting the limit switches makes it stop so I think I have it all connected right. Next I need to get the limit switches positioned right then I can clean up the wires.
I haven't tried the extruder motor yet. What's the consensus on how that should be plugged in red wire on the right or left? There seems to be a conflict in the instructions.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 10:27AM |
animoose
msaeger
Red wire towards the edge of the board where the screw terminal connectors are. Mine is the other way round because I have a different extruder set up from the normal one (nozzle under the left hand filament hole, when it's usually under the right hand one).
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 12:14PM |
The safety features shut down the printer if you turn the heaters on manually in Repetier.Quote
tadawson
Marlin1.0.3-dev or 1.0.2 should compile fine *BUT* you cannot just take your Configuration.h file over, you need to edit the values into the template that comes with the new version. (Configuration_adv.h too . . .)
And frankly, I have no idea what 'tripping' even means in your context, nor 'manual mode' . . . . more detail would help!
- Tim
Config_adv.h:78 #define EXTRUDER_0_AUTO_FAN_PIN 9 pins.h:61 #define FAN_PIN -1 temperature.cpp:364 #if EXTRUDER_0_AUTO_FAN_PIN == FAN_PIN #error "You cannot set EXTRUDER_0_AUTO_FAN_PIN equal to FAN_PIN" #endif
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 12:50PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 12:56PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 01:05PM |
msaeger
Any tips for mounting the Y carriage end stop before I modify the bracket or something? The carriage hits the switch mount before it hits the switch because the block protrudes slightly past the switch.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 02:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 02:04PM |
animoose
msaeger
I turned mine so that it's at a slight angle to the mount (about 15 degrees). Also check whether you get the same problem on the Z axis. I wasn't able to find an angle that worked for that, so stuck a small plastic bumper to the X motor mount.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 02:45PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 03, 2015 02:49PM |
hobbes
i'm anxiously awaiting for my 2020 prusa to arrive, today. Bought from Folgertech's ebay store and have been looking forward to this all week. I have to say i'm disappointed in the USPS tracking service as it doesn't give me any update other than the day which the label was made. What's the point of a tracking service if all it shows you is when it was shipped and when it arrives? This is by no means a complaint on Folgertech, of course.
