Re: P802M Prusa i3 Unofficial Support Thread February 14, 2016 04:25PM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 03:15AM |
Bobyni
If anyone have made an enclosure for the Printer,
you should consider to print this out and add on to your printer!!!
I find it to be a must have thing!!
[www.thingiverse.com]
Cheers
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 03:21AM |
Robkadett
And if you want upgrade your stability after assembly, you can use it too:
Thingiverse.com
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 03:46AM |
ErikL
Robkadett
Thingiverse.com
Did you try them yourself? Did you notice any changes in your print?
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 06:59AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 07:10AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 07:17AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 07:38AM |
@JimsFlight: Can you confirm, that your thermistor values are all right? You use the standard 100k Epoc B575xxxxx in the configuration.h, if the printer (as above written) uses the 3950 NTC's this configuration is very off in the high temperature region.Quote
JimsFlight
Not saying this is a definitive guide or anything, there’s a wealth of information in previous posts, this is just what worked for me. Here is a link to a google drive with everything I used in it. Thanks again to everyone on the forum for helping me out.
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 08:04AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 08:10AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 09:05AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 09:34AM |
but it may be just me
, but maybe i do it wrong
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 10:06AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 10:17AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 10:44AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 11:51AM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 08:10PM |
Re: P802M Prusa i3 Unofficial Support Thread February 15, 2016 09:23PM |
Re: P802M Prusa i3 Unofficial Support Thread February 19, 2016 05:38AM |
Re: P802M Prusa i3 Unofficial Support Thread February 21, 2016 01:28PM |
Re: P802M Prusa i3 Unofficial Support Thread February 22, 2016 07:17PM |
Never got feedback from you for this issue [forums.reprap.org]Quote
Scottjar
I'm after some help after printing in PLA I've come to use the printer again and it wont feed the PLA out of the extruder in program. When I feed it manually from the menu in the LCD it will feed no problem leaving a mess on my desk but wont on previously printed programs. Please help
The reset button on the board works a treat. Don't know why I didn't try that before
Re: P802M Prusa i3 Unofficial Support Thread February 23, 2016 04:57AM |
Re: P802M Prusa i3 Unofficial Support Thread February 23, 2016 05:22AM |
Re: P802M Prusa i3 Unofficial Support Thread February 23, 2016 05:24AM |
Re: P802M Prusa i3 Unofficial Support Thread February 23, 2016 05:27AM |
Re: P802M Prusa i3 Unofficial Support Thread February 24, 2016 08:48AM |
Re: P802M Prusa i3 Unofficial Support Thread February 24, 2016 09:18AM |
Re: P802M Prusa i3 Unofficial Support Thread February 24, 2016 09:30AM |
Seems like something might be binding. Bearings dry? Does the belt have schmutz on it? Something catching? Or possibly, stepper driver voltage--but that should show skipping early on.Quote
jnsbanman
All of the sudden my printer has start to shift on the Y axis mid print after several hours of printing. Attached is a photo of what it looks like...
It will shift in the same direction it seems every time then resume printing normally for a few layers then shift again etc etc... anyone know whats going on here?
Re: P802M Prusa i3 Unofficial Support Thread February 24, 2016 09:38AM |
Re: P802M Prusa i3 Unofficial Support Thread February 24, 2016 10:40AM |
