Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 16, 2013 06:41PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 16, 2013 08:43PM |
dtmille2
I wonder what the optimal speed is for steppers to get high throughput on a hotend like the E3D that can generate a lot of heat quickly. I'm thinking about very fast print speeds or high rates of material extrusion.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 05:43AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 05:46AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 07:31AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 08:16AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 08:31AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 10:06AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 10:08AM |
SanjayM
Just moved house, quit my job, gone full E3D, its been a crazy time. Thank you all for your patience, and I'm sorry if some people have been waiting for customer service a little longer than usual. It's been hard!
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 11:47AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 03:13PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 03:28PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 03:37PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 04:04PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 04:08PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 04:12PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 04:47PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 05:14PM |
J-Heads don't leak unless they are faulty.
The jhead is an immature design in comparison to the E3D from my limited experience :-)
the E3d is a lot longer than the jhead so I see lots of space.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 05:47PM |
crispy1
I have had some leak PLA from in between the mate between the brass and PEEK, if the brass is not adequately torqued down. If it's not fully torqued, after a few heating and cooling cycles it will loosen up enough to leak some PLA down the side of the brass block and onto the bottom face. I wouldn't really call this faulty, since all you need to do is heat it up to about 170C and torque the heater block down until it's fully seated.
What I do now is heat cycle them twice, then torque the brass down before any plastic is run through them. This nips the problem in the bud nicely, and it's similar to the "heat to 300C and torque down" step in the E3D instructions.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 05:58PM |
Sorry I'm a noob and missed that. E3D works better for noobs like me with operator shortcomings.Quote
crispy1
You do know Brian (reifsnyderb) has been at this for longer than 99% of people have been involved in 3D printing, right? The jhead is a very mature design that continues to improve with each iteration. I think you're blaming the tool for operator shortcomings.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 06:08PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 07:03PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 07:48PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 07:53PM |
tjb1
Up and printing again, no damage from what I can see.
The insulation on one of the thermistor wires was melted. Not sure if the thermistor failed and let the temp run up and do it or if it shorted to the heater block causing the failure. Still doesn't change the fact that the resistor is only rated for 300c.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 18, 2013 09:17PM |
tjb1
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 19, 2013 04:50AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 19, 2013 05:22AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 19, 2013 07:39AM |
SanjayM
Very busy right now getting ready to shut up shop for Christmas - just chipping in to say that yes, the thermistor is rated to a max of 300C, and that the 400C figure on the site was done with a thermocouple. Going back and re-reading the description it reads as if the hotend should be able to run at 400 out of the box, which is not representative of reality. I'll get that clarified and changed ASAP. Sorry for any confusion caused.
tjb1 - if your thermistor is damaged from that heating cycle then please do get in touch via the website feedback form and I'll get you sorted out with a replacement/reimbursemnet. Thanks for bringing the whole issue to my attention.
Vishay makes some higher temperature thermistors - looking into it. But really I think thermocouples are the way forward at that point.
Cheers,
Sanjay
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 19, 2013 01:59PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] December 19, 2013 08:12PM |
